Old 04-11-2016, 10:11 PM   #197
deuncos
Drives: AT Hot lava FRS
Originally Posted by Shiv@Openflash View Post
The N54 engine has been out of production for 5years. We officially stopped Procede piggyback development for the N54 just over 2 years ago when we launch OpenFlash and focused primarily on ECU flashing tools/map development. We still do plenty of N54 tuning. But only through OFT, not the Procede. The Procede has been repurposed for ESC control for GT86 and MX5 applications. For a number of reasons, piggybacks like the Procede are not ideal solutions for modern ECU tuning.
@Shiv@Openflash I want to get a custom etune the same time I purchase an OFT, is there a good time of the day to call y'all? Had some questions about the whole procedure, I've emailed sales@openflashperformance but never got a response.
deuncos is offline   Reply With Quote
The Following User Says Thank You to deuncos For This Useful Post:
D_Thissen (04-11-2016)
Old 04-11-2016, 10:15 PM   #198
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
In the past 3 months we have released 4 OTS map releases:
1/16/16
v2.073
-Added full tune and XML support for ZA1JF40C Calibration ID.
-Added full tune and XML support for ZA1J500D Calibration ID.
-Added full tune and XML support for ZA1JF00D Calibration ID.
2/7/16
v2.074
-Added full tune and XML support for ZA1JE00I Calibration ID.
-Added full tune and XML support for ZA1JF40D Calibration ID.
3/22/16
v2.075
-Added full tune and XML support for ZA1JA02N Calibration ID.
3/30/16
v2.076
-Added full tune and XML support for ZA1JF30J Calibration ID.
And as newer OEM calibrations hit the streets, we will add support for them as well. Things may come to halt if the engine/platform is discontinued by Subaru/Toyota. But I don't see any signs of that happening any time soon. So forgive me if I fail to see any evidence of us slowing down support for the OFT.
I'm with deuncos here, I've tried emailing and facebook messaging the openflash page several times to no avail to learn more about the e-tune process. As I said before that is my ONE and ONLY gripe with you guys, support is a big deal answering a simple email about one of your $200 services would be awesome! Could you maybe post more info on the e-tune process?
The Following 3 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
deuncos (04-11-2016), D_Thissen (04-11-2016), Yoshoobaroo (04-11-2016)
Old 04-11-2016, 10:20 PM   #199
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
1/16/16
v2.073
2/7/16
v2.074
3/22/16
v2.075
3/30/16
v2.076
Forgive me if I seemed overly pessimistic. I'm new to this platfirm and I didn't know this much activity was this recent. I'm very excited to be on a healty platform with lots of active development again, I'm not used to that anymore haha.
Great to hear that you're with us at least until the end of life of the engine. That should give most of us a nice warm fuzzy
Sent through a series of tubes
Old 04-11-2016, 10:25 PM   #200
steve99
Drives: FT86
Originally Posted by tracerit View Post
only for turbo?
If shiv releases the Flex tunes for NA, then if you wanted instead of a flex kit/sensor you could just install a switch or a variable resistor , to control the volts into the input to ECU. In this way you could simply switch between petrol and E85 maps no reflash . Or dial up an E% you want . Cost about $5, if you did not want to go the whole flex fuel kit setup.
Old 04-11-2016, 10:29 PM   #201
tracerit
Drives: '13 SSM BRZ Limited 6MT
If shive releases the Flex tunes for NA, then if you wanted instead of a flex kit/sensor you could just install a switch or a variable resistor , to control the volts into the input to ECU. In this way you could simply switch between petrol and E85 maps no reflash . Or dial up an E% you want . Cost about $5, if you did not want to go the whole flex fuel kit setup.
How does the volts pick up the ethanol content percentage?
tracerit is offline   Reply With Quote
Old 04-11-2016, 10:42 PM   #202
steve99
Drives: FT86
only for turbo?
using a switch is just a simple manual map switch, it just saves you having to reflash.
correct it doesn't detect any E% you just switch it to petrol or E85 and avoid having to flash
you would need to work out the volts required to set the ecu for say E40 or E65 or whatever, but I believe the oft will have and ethanol % readout.
again you would need to test or know what your fuel E% was, the tune could still use the ltft for about 15% or so correction either side of the set value.
however it doesn't replace a full flex setup, its just an option for NA guys who maybe cannot justify $500 plus for a flex setup and just want some simple map switching. Similar to an ecutek 4 map switch tune.
tracerit (04-11-2016)
Old 04-11-2016, 10:46 PM   #203
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
To be down that much hp is unusual.
either your getting heaps of knock due your fuel being poor quality
or your car is running very rich due maf scaling (or you have aftermarket intake)
neither of those issues will be fixed by the updates.
Running 94 octane fuel only since the day i bought the car with 93 tune. Zero knock on both street daily or under high load on the track multiple times.
The dyno was in fact before I rescaled the MAF to dial in the Greddy intake, so could be that case. But there is still definitely quite some room to play. If there wasn't, we wouldn't be waiting for these new improved stage2 maps
tdotBRZ is offline   Reply With Quote
The Following User Says Thank You to tdotBRZ For This Useful Post:
Ahsila (05-23-2016)
Old 04-11-2016, 10:59 PM   #204
D_Thissen
D_Thissen's Avatar
Which dyno where you using ??
The Following User Says Thank You to D_Thissen For This Useful Post:
Ahsila (05-23-2016)
Old 04-11-2016, 11:28 PM   #205
tdotBRZ
tdotBRZ's Avatar
Dynapack which tends to read about 10% lower than dynojet
The Following 2 Users Say Thank You to tdotBRZ For This Useful Post:
Ahsila (05-23-2016), D_Thissen (04-11-2016)
Old 04-12-2016, 12:37 AM   #206
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
We just got our stock of OFTs on Friday so we have been spending the last few days getting caught up on back orders. We should be caught up with emails by the end of the day tomorrow. Here's what we packed and shipped today:
Got a bunch more we need to get out tomorrow. Then we will finally have the time for emails
Shiv@Openflash is offline   Reply With Quote
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
B-R-Z (04-12-2016), BurnetRhoades (04-12-2016), deuncos (04-12-2016), D_Thissen (04-12-2016)
Old 04-12-2016, 12:44 AM   #207
FRSBRZGT86FAN
That's totally understandable, sorry for making it a big deal
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Shiv@Openflash (04-12-2016)
Old 04-12-2016, 01:11 AM   #208
deuncos
Thanks Shiv, we appreciate it
Old 04-12-2016, 02:28 AM   #209
Dru670
Drives: 2016 Scion FR-S
@shiv care to respond to of m emails? regarding cal id F00C
Dru670 is offline   Reply With Quote
Old 04-12-2016, 02:52 AM   #210
FRSBRZGT86FAN
Also is there a status update on this Stage 2 UEL tune?
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 12:56 PM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 01:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 02:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
