#3823 | |
Baby LFA
Drives: Baby LFA
Did this happen to your charger pulley?
#3824 |
Drives: Scion FR-S
anyone have a leak oil issue on the reservoir? i think mine leak from the top of the reservoir, either the cap or from the washer of the bolt that the oil returned into the reservoir.
#3825 |
Drives: Whiteout FR-S, Evo 8 RS
Yep! I replaced the copper seals on the line and cleaned up the gaskets on the cap and it went away.
#3826 |
#3827 |
Drives: 2013 FRS
#3828 |
Drives: 2013 FRS
During installation I had to replace a copper seal because there was a slight notch in the one that came with it which caused a minor leak. Once I switched that out it has been great for about 5k miles.
#3829 | |
BoostedBRZ
Drives: Turbo BRZ
also... for those who needs the belt...: https://www.mrosupply.com/synchronou..._gates-rubber/ |
#3830 | |
Drives: 2013 FRS
#3831 |
Baby LFA
Drives: Baby LFA
I have two of the smaller belts for sale if anyone needs some spares (IF you're using the old drivetrain). They don't fit with the larger pulleys so I have no use for them unless I get bored and use the smaller ones for the hell of it.
#3832 |
Drives: 2015 AOZORA EDITION
lol all these belts snappin is a joke
#3833 |
Drives: 2013 Subaru BRZ
i've pretty much given up on the kraftwerks system with all of my 4 broken belts. i could never get the system tensioned correctly, even after following kraftwerks instructions. they decided to give me a complete refund for the entire system so i can buy something else entirely. i will never in my life go with a manually tensioned system ever again.
#3834 |
Drives: 2013 Ultramarine FR-S
If no one has seen this thread yet. The OP lays out all the issues with the kit and a few ways to work around them.
a bit on supercharger drive systems and the Kraftwerks kit. http://www.ft86club.com/forums/showthread.php?t=104382 |
#3835 |
#3836 |
Drives: Late 2014 Subaru BRZ
The kit needs an auto pulley tensioner. The belt heats up and the belt is no longer tight enough. To cold and it's tomuch tension. For this very reason is why cars main serpentine belt as a auto pulley tensioner.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
