Old 03-30-2016, 04:24 AM   #491
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by SoCalArgento View Post
How can we adjust idle rpm on romraider for the oft? I want to raise it a little higher than the stock 750?
I did a quick Google search on phone and nothing.
Thanks for the help!
Open the Idle Speed Target tables and increase anything lower than 750 to 750.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-30-2016, 04:39 AM   #492
SoCalArgento
Drives: 2014 Argento FRS
If I want to raise idle rpm to say 850, still change all tables to 750 or the number I want idle to be (850)?
SoCalArgento is offline   Reply With Quote
Old 03-30-2016, 04:58 AM   #493
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You change all the values that are 750, 775 or 800 to 850, there should be 6 idle speed target tables A-F under the folder "Idle control", notice it's based on temperature if you try adjusting any of the idles speeds other than the ones I just said it may not even do anything due to the maf tables I believe:
If I may ask why are you changing the idle?
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
SoCalArgento (03-30-2016)
Old 03-30-2016, 05:14 AM   #494
SoCalArgento
Thanks for the info @FRSBRZGT86FAN
I got lightweight flywheel with clutch and idle has dropped to ~700rpm and drops slightly more when using a/c and rear defroster. Just trying to raise it a tiny bit to compensate rpm to stock rpm.
Old 03-30-2016, 05:18 AM   #495
FRSBRZGT86FAN
Hmm... I think there may be more compensation than just the idle tables for when a/c kicks on or a high power draw @steve99 would probably know, Try the tables regardless it doesn't hurt.
Old 03-30-2016, 05:23 AM   #496
SoCalArgento
I'll give this a try for the time being and thanks for screen shooting rr.
Old 03-30-2016, 07:11 AM   #497
steve99
Drives: FT86
correct their are lots of idle compensation tables as well, and their are lots of undefined unknown tables in the idle area for various compensations for alternator load ,a\c load etc.
when you put on lightweight flywheel\clutch assemblies its upsets the ecu idle compensations as it now lower mass and it can over and undershoot . The whole idea of a flywheel is to smooth out the rotation of the engine firing pulses.
Old 03-31-2016, 02:59 AM   #498
SoCalArgento
Yeah I suspected it would include numerous tables. I changed the idle control tables as mentioned above and it has helped. This is only a temp fix for the time being as I'm going s/c with EcuTEK and hoping tuner can adjust idle more meticulously.
Old 03-31-2016, 09:57 PM   #499
dtrop
Drives: Wrb 2014 limited brZ
Is it safe to run Jdl uel CATTED header with stage 2?
dtrop is offline   Reply With Quote
Old 03-31-2016, 10:32 PM   #500
renfield90
The Stig's German cousin
Yes.
But as always, log and verify the safety of the tune on your specific car.
Old 03-31-2016, 10:43 PM   #501
dtrop
Originally Posted by renfield90 View Post
Yes.
I'm referring to the shelf tunes. I'm completely new, but will be ordering the header and oft in April.
Old 04-01-2016, 05:33 PM   #502
choiboie
Drives: 2013 Fr-S UltraMarine
keep getting this message..tried to reset the ecu by removing negative terminal. And still ecu is in recovery mode. Any other suggestions besides taking it to dealer to figure out my ecu
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
Old 04-09-2016, 10:56 PM   #503
TheMedakaBox
[EUROBEAT INTENSIFIES]
TheMedakaBox's Avatar
Drives: 2015 Scion FR-S Steel
Having an issue with my OFT/Open Flash Manager.
I guess there was an update on the OTS tunes since it has been a while. (I had V 2.074) I downloaded the new tunes and unzipped them. Plugged it into my laptop and ran Open Flash Manager. Let it do it's thing and attempted to upload an updated EL Stg 2 E85 tune but it gave me an error.
I'm sending this from work so I don't have a screen cap. I even tried adding a .bin file from v2.074 and it wouldn't work either.
Anyone have this issue before?
TheMedakaBox is offline   Reply With Quote
Old 04-10-2016, 03:27 AM   #504
TheMedakaBox
Here is my error message. What do?
Sent from my XT1254 using Tapatalk
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
