| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3025 |
Master Member
Drives: Subaru BRZ
A little inside is no big deal. If I go with a 17x8 with a 48mm I just want to make sure i'm not going to hit my suspension with a ~1" drop and some negative camber. I see 48mm on the chart is no where near ideal, so it has me a bit concerned. Then again 8.0 wide rim is not that much wider to begin with compared to a 9 or 10" wide.
#3026 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
a 9" wide rim with +35 is very close to the inner struits, so math tells us that an 8" with +48 will be about as close as the 9" With +35 if you can, rather take an 8" +32, this will fit way better on our cars
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#3027 | |
Master Member
Drives: Subaru BRZ
#3028 |
worst case, if you buy an 8" wheel, you can always run spacers. a 10mm spacer makes an +45 to an + 35. its not ideal, but you can get it workimg
| The Following User Says Thank You to Killerbee For This Useful Post: | unplugged (03-18-2016) |
#3029 |
Master Member
Drives: Subaru BRZ
I was thinking about the spacer and 10mm isn't that big of a change to be concerned about. Personally I rather just find another wheel that offers the better fitment.
#3030 |
Drives: 2013 FRS V1
ok with a 18x9.5-25 and a 18x11-35 can i fit a 295/35,305/35,295/30,305/30 in the rear and yes i do have a rocket bunny kit v1. for the front will a 265/35, or 255/35 fit ?
#3031 |
agree on this, i'm personally also not a big fan of spacers
#3032 |
#3033 |
Drives: 2015 Scion FR-S
I see on the wheel directory that a 17x7.5 +42 will fit on stock suspension. My question is, will fitting 205/50/17 tires (bridgestone potenzas) affect handling/speedometer significantly? Looking at a set of used rims/tires. Any help would be appreciated, thanks
#3034 | |
no real affect on handling
| The Following User Says Thank You to Killerbee For This Useful Post: | alvin545 (03-19-2016) |
#3035 |
Drives: 2016 CBS BRZ
@swarb I tried what you said with both 3 and 5 mm spacers still did not fit without rubbing. I want to keep my mpss they are 245/35 r18 but if I went down to an 18x8.5 what offset is garunteed at that wheel size? This would be my 3rd time trying to get wheels on my BRZ
#3036 | |
#3037 |
Well I'm back on stock now but the wheels were 18x9 +45 with 245/35r18 MPSS
Without spacers the wheel didn't clear the spring perch and rubbed the spring in the front with a 5mm spacer the tire would barely clear the perch when raised but when the car was lowered to the ground the tires didn't clear and were rubbing the springs. So the tire guy recommended to drop the offset to between 30-35 on stock suspension, is he correct? Also the wheel selection is much larger at 18x8.5 so what offset would be needed there? |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
