#687 | |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
hahahaha...Yeeepppp. It has the relay. What can you tell me about it?
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#688 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
It has a couple of quirks.... As of right now the relay doesn't work correctly. I would snag a simple relay like Rob recommends earlier in this thread. And then rewire it. Or get rid of the relay completely and just manually turn it on and off. I would also snag the big crank batteries. You said you ordered the procede? Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#689 | |
CAR-AHOLIC
I already have the PC680 batteries. I had them from my last setup. What other quirks can i expect? I will have to rewire the pedal switch, it has been cut off. But no biggie, I think.
#690 |
Nah you should be good.
#691 |
CAR-AHOLIC
As always thanks for your help. From what i gather from Lord09 I shouldnt really have any issues. The unit worked good for him. But, regardless, if someone has a harness they want to sell. I am willing to buy.
#692 |
Time Traveller
If I can track it down and it's the right part, no charge. Just need to mail it. I'll look for it tonight after work.
| The Following User Says Thank You to DAEMANO For This Useful Post: | brzaapi (03-15-2016) |
#693 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Generalizations are inherently wrong
If I say yes, will that make you think I understand?
#694 | |
Drives: 2013 Firestorm FRS
Massively expensive(see; overpriced lol) and the minute benefits of it wouldn't be worth the trouble. Heat soak and reducing intake temps are two different things(although, very similar). The phantom kit does not really suffer from heatsoak. There is no easy/reasonable way to add an IC to this kit, that works well enough to offset the cost and trouble. Air to air ic: Although I have not tested it of course, I'm fairly certain any mild(if ANY) decrease in intake temps would be offset by reduced flow from a normal air to air intercooler. |
#695 | |
CAR-AHOLIC
It will save time from me having to solder everything the way i like. And i hate to go back to the baby thing, but its hard to find the time right now to do certain projects. I save my kitchen pass days for AX or HPDEs.
#696 | |
Drives: FR-S,GTI
#697 |
CAR-AHOLIC
Whhhaaatttttttt, i never forget.
No, your probably right. The good news is Lord09 let me know that the relay worked fine for him and that he didnt experience any problems after install. So i can leave the relay and I will just resolder connections. UNless, Daemano can find an extra harness (fingers crossed) and then i dont have to worry about it. I guess i am just a cable snob. Lord09 did a fine job terminating everything, but I will redo all the wiring if I dont get another harness. The rest of the kit is in great shape.
#698 |
CAR-AHOLIC
Does anyone know if Shiv is on a vacation or something. I know he works all the time, but i have been trying to get in touch with him(PMs, emails, calls) for about a week now and no response.
#699 | |
Time Traveller
![]() Although it sounds like Lord09's will work just fine. A well soldered connection can be as good as a solid wire. I wouldn't worry about it one bit TBH. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | brzaapi (03-16-2016) |
#700 |
CAR-AHOLIC
I appreciate you checking. I am still waiting for an answer from Rob if he has one available. But yes, I will solder and use heat shrink wrap on the connections.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 08:08 AM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
