Old 01-01-2015, 11:45 PM   #29
blown
Drives: ft86
Originally Posted by ybotspawn View Post
Timing cover... long story short, under boost your internal pressure is increasing. As it increases youre blowing the seal and forcing oil out. External pcv and a reseal of timing cover and potentially maincap.... @ptuning just fixed this on my car
external pcv?
blown is offline   Reply With Quote
Old 01-02-2015, 12:09 AM   #30
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
What build date are your cars?
hmong337 is offline   Reply With Quote
Old 01-03-2015, 11:19 PM   #31
Astroboy
Astroboy's Avatar
Drives: None
This shit is so frustrating. Every time I stick my hand under there, I just want to give up on the pos
Astroboy is offline   Reply With Quote
Old 01-05-2015, 01:12 AM   #32
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Mine is 1/13 IIRC
I heard that this is a common Subi boxer motor problem.
The Following User Says Thank You to solidONE For This Useful Post:
Astroboy (01-05-2015)
Old 10-03-2015, 12:37 AM   #33
Astroboy
Astroboy's Avatar
Drives: None
Well
Another bad leak
Old 10-03-2015, 12:38 AM   #34
Astroboy
Astroboy's Avatar
Drives: None
Any ideas on where it might be leaking?
Old 10-25-2015, 05:52 PM   #35
Griever423
Drives: 2020 BRZ PP
Chiming in here. I have the same leak at where the valve cover/timing cover/cam cover meet. Dealer has ordered valve cover gasket, timing cover gasket, and spark plug gaskets. They will be pulling my engine to replace sometime next week. I'm right at about 31,000 miles. Going to pay for spark plugs too while it's out.
Griever423 is offline   Reply With Quote
The Following User Says Thank You to Griever423 For This Useful Post:
Astroboy (10-25-2015)
Old 10-25-2015, 06:52 PM   #36
solidONE
solidONE's Avatar
4000 miles later, no leak. But... my engine run hotter by 5~10 degrees average than before. Not sure what they did that would cause this. Maybe a bit too generous with the silicon.
Intent > Content
Old 02-22-2016, 08:36 PM   #37
Trphotomediadotcom
Wooo can add me to leak list -_- and no more warranty. My oil is sitting right on the top of the head. Right where the intake manifold meets the block. Driver Side
Trphotomediadotcom is offline   Reply With Quote
Old 02-22-2016, 09:18 PM   #38
solidONE
solidONE's Avatar
yay welcome to the club?
After eating a bill for installation of new clutch assembly due to a faulty release bearing, I've now found a leaky CV boot AND a weak battery. I'm still under warranty but I'm hesitant to take it in. I dont need to pay for "inspection" or "diagnostic" or whatever bullshit after they refuse to cover the repairs under warranty.
Make's me want to punch someone in the throat.
Intent > Content
Old 03-06-2016, 04:22 PM   #39
Trphotomediadotcom
Intake Manifold gaskets were no good...
Old 09-17-2016, 02:43 PM   #40
Astroboy
Astroboy's Avatar
Drives: None
Leakiest motor I ever dealt with
Sent from my LG-D850 using Tapatalk
Old 09-17-2016, 02:45 PM   #41
Astroboy
Astroboy's Avatar
Drives: None
Do you know what sealant they used? Like, was it black or that special gray which they use
Old 09-20-2016, 11:21 AM   #42
solidONE
solidONE's Avatar
I believe it was a grey sealant IIRC.
Intent > Content
Oil Leak on driver side EINSTEIN562 Issues | Warranty | Recalls / TSB 3 08-09-2020 12:16 PM
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 04:43 PM
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-02-2015 11:51 PM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
