Old 02-16-2016, 11:46 AM   #1
cupcake917
cupcake917's Avatar
Whining noise when pressing clutch?
Anyone else have this problem..what is going on with my clutch?
cupcake917 is offline   Reply With Quote
Old 02-16-2016, 11:54 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
probably a throw out bearing like everyone else's issue. I didn't watch video BTW
MisterSheep (02-16-2016)
Old 02-16-2016, 12:15 PM   #3
cupcake917
cupcake917's Avatar
Is the bearing a part that can be replaced or do I have to put a whole new clutch in?
Old 02-16-2016, 12:16 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
If I remember right its a son of a B to change so you may as well put a new clutch in while you are in there
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
cupcake917 (02-16-2016), MisterSheep (02-16-2016)
Old 02-16-2016, 12:23 PM   #5
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
@go_a_way1 usually your throw out bearing will make a noise when you do not have the clutch pressed. It will go away when the clutch is pressed. He is saying is problem occurs when the clutch is pressed down.
It could be a throw out bearing because our cars are notorious for having bad throw out bearings. Normally when you are considering a TOB change you should change the clutch as well.
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
cupcake917 (02-16-2016), go_a_way1 (02-16-2016)
Old 02-16-2016, 03:14 PM   #6
tracerit
Drives: '13 SSM BRZ Limited 6MT
Kinda hard to hear the noise in the video, but it sounds like a creaky noise? Could be your clutch fork drying out. I have the same noise, brought it in to be inspected and they ended up replacing my throw out bearing (covered under warranty). Noise is still there, but oh man the car engages so much better now. It's amazing.
Now 6 months ago, I also brought it in for a crunchy feel when I depressed the clutch and they replaced the TOB then (also under warranty), the noise went away but the car drove the same (although I wasn't complaining about any driveability issues then).
tracerit is offline   Reply With Quote
The Following 2 Users Say Thank You to tracerit For This Useful Post:
Old 02-16-2016, 03:47 PM   #7
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Hard to hear from the video.
Have you checked this thread out?
Old 02-16-2016, 04:40 PM   #8
I can't hear anything on the video that helps me figure what is bothering you.
Did you buy the car new ..??
How many miles on your car .. ??
Can you give another description of the sound .. ??
Old 02-16-2016, 04:43 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
hahaha thats what I was going for. "what you have a clutch noise? Throw out bearing" lol
Old 02-16-2016, 06:35 PM   #10
bottle
Wear headphones guys, there's clearly a whirring noise when the clutch is pushed in.
As per @MisterSheep's comment, I do not believe this is correct. If you push the clutch in the noise occurs because there is load on the TOB, releasing the pedal also relieves the load and therefore no noise.
The noise that disappears when you disengage (press in) the clutch is usually flywheel/gear rattle, which is not what this sounds like.
To the OP, as previously mentioned you have to drop the transmission in order to access the TOB in the bell hosing. This is labour intensive (about $400-600 labour alone) so most people opt to change the clutch, pressure plate, and flywheel (or resurface it at least) at the same time.
This thread is the one you want to read.
bottle is offline   Reply With Quote
The Following User Says Thank You to bottle For This Useful Post:
VenomRush (02-19-2016)
Old 02-16-2016, 06:50 PM   #11
MisterSheep
Killed Scion
I got my TOB replaced under warranty because of that noise (rattle coming from trans area and goes away when pushed down on clutch) as well as a new trans
Old 03-02-2019, 12:12 AM   #12
Lav
Drives: Frs
Can you upload the video again so i can see if its the same noise as mine?
bibbity boppity give me the zoppity
Lav is offline   Reply With Quote
Old 03-02-2019, 01:11 AM   #13
Upload yours. We'll be here.
Lav (03-02-2019), spike021 (03-12-2019)
Old 03-12-2019, 02:38 AM   #14
Lav
Drives: Frs
I tried to put captions right when the noise hits but my airbnb wifi is down and i was stuck with windows photo gallery app. I did match the volumes of the 4 clips though.
I put details in the description. I think its pretty easy to hear but i know exactly what im listening for.
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 12:04 PM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 12:42 PM
Pressing brakes hard in snow (Terrible Noise) Benschneider06 Issues | Warranty | Recalls / TSB 10 01-20-2016 09:15 PM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 09:24 PM
Clutch disengage whining sound? Bach415 Issues | Warranty | Recalls / TSB 7 07-12-2013 08:52 PM
