Old 02-09-2016, 11:45 PM   #1
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Mystery BRZ interior LED Lights?
Hey guys,
I just picked up a used 14 Limited BRZ, and I noticed the previous owner installed/had someone install footwell LED lighting.
I gotta be honest, I hate them. The fact that the dash and center console is red, and the LED lights are blue, really throw me off when driving at night.
I noticed they come on when I turn the BRZ's lights on, and I'm able to adjust the brightness along with the gauge and navi.
I did some searching and found that the dealers would charge $100 (what a rip off!) for interior illumination, however I couldn't find if one is actually able to disable these lights. Without cutting the wires obviously.
I could just electrical tape them, but I'm curious if anyone has these and are able to disable them.
Thanks for the help,
May not like the lights, but they make my indoor soccer shoes look cool!
Sent from my Nexus 6P using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 02-09-2016, 11:48 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by Bowen View Post
Hey guys,
Those shoes are on point!! I believe your only options is to cut them out. They may be plugged in somewhere or have a fuse that would make it super easy but don't waste too much time looking. I would just cut 1 wire and tape it to the other wire and wrap it with electrical tape, problem solved.
Old 02-10-2016, 12:28 AM   #3
ryoma
ryoma's Avatar
if it is the dealer option, there should be a plug under there that you can unplug.
Old 02-10-2016, 11:31 AM   #4
tobin
tobin's Avatar
Drives: '13 BRZ
I just responded to this in another thread. The easiest way to turn off the footwell lights is to unplug the connectors by the lights themselves. The connectors are a few inches of wire away from the lights and wrapped in adhesive foam tape. Peel the tape off and unplug the connection. I have blue ones in my '13 and hated them.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
SmartedPanda (02-11-2016)
Old 02-11-2016, 12:04 AM   #5
Bowen
Powered by Crickets
Bowen's Avatar
Thanks guys, Tobin was right, all I had to do was peel back that nasty tape and unplug the LED lights. Can't believe someone payed a hundred bucks to get these installed.
The Following 2 Users Say Thank You to Bowen For This Useful Post:
nickmerronesucks (02-12-2016), SmartedPanda (02-11-2016)
Old 02-11-2016, 02:59 AM   #6
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
These only work well if you have red, I have a red one on all the time and it looks a lot better when it's at night
KungFuWaffle is offline   Reply With Quote
The Following User Says Thank You to KungFuWaffle For This Useful Post:
Old 02-11-2016, 07:54 PM   #7
shodan
shodan's Avatar
Drives: MY15 Toyota 86 GTS
I was gonna get this, under the assumption they only came on when the door opened. Changed my mind when I found out that ran all the time AND just how expensive it was to install
shodan is offline   Reply With Quote
Old 02-11-2016, 08:12 PM   #8
Bowen
Powered by Crickets
Bowen's Avatar
Yea they don't come on until you turn your lights on. And you can't toggle them. I think Red would have been fine, but blue really throws me off.
Old 02-12-2016, 10:41 AM   #9
Ehokana
Drives: 2016 FRS
Anyone know if the wires are set in the FRS too? Certainly wouldn't pay a dealer to do it at that price, and if the connection is there, it would be easy to do. There's no way I could do the blue, but red might look good
Ehokana is offline   Reply With Quote
Old 02-12-2016, 10:46 AM   #10
KungFuWaffle
Drives: Whiteout
There's a DIY on how to wire a red light to the 12v in the glove box, and I wired a white strip to my dome light. Look up @ledworkz on Instagram and scroll down and you'll see what I mean.
The Following 2 Users Say Thank You to KungFuWaffle For This Useful Post:
Bowen (02-12-2016), Ehokana (02-16-2016)
Old 02-12-2016, 10:59 AM   #11
Bowen
Powered by Crickets
Bowen's Avatar
Cool I'll check it out.
Old 02-12-2016, 11:14 AM   #12
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I have these in red, Dealer installed I assumed all the highest optioned cars has it at first..I thought it was gay but i have come to enjoy it, aside from how sloppily drilled they are into my plastics.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Interior LED lights? djgalmalka Cosmetic Modification (Interior/Exterior/Lighting) 12 09-09-2015 11:24 PM
mystery body kit... (no longer a mystery) Alita Cosmetic Modification (Interior/Exterior/Lighting) 3 08-16-2015 07:10 PM
No interior lights except door panel lights (BRZ) BRZZZZZZZZZZ Issues | Warranty | Recalls / TSB 3 01-05-2015 01:46 AM
Wiring interior L.E.Ds to come on with the interior lights/headlights TEXAS_LE Electronics | Audio | NAV | Infotainment 2 12-13-2014 10:18 AM
Interior Lights xcelir8brz Cosmetic Modification (Interior/Exterior/Lighting) 18 09-05-2012 04:36 AM
