Old 02-09-2016, 01:25 AM   #1
danny_d19
danny_d19's Avatar
Drives: Whiteout RBv1 FRS
FRS front grill modification
So I like the look of some 86's without the front grill, but hate the look of the styrofoam painted or stock crash bar painted. So I'm wondering if anyone has any pictures of the front grill cut out below the solid section that covers the styrofoam/crash bar?
Poor photo shop example of my car to illustrate what I mean
danny_d19 is offline   Reply With Quote
Old 02-09-2016, 01:35 AM   #2
Brayden_23
Drives: Asphalt 2015 FRS
An alternative to painting the foam or crash bar would be to swap out the crash bar for an aftermarket one (such as the beatrush option). Obviously this isn't as safe as the OE bar but racecar. They are more narrow so you can't see it from the grill area
Brayden_23 is offline   Reply With Quote
Old 02-09-2016, 01:44 AM   #3
danny_d19
danny_d19's Avatar
Yes I've considered that, it's an option. The plus side would be sweet Beatrush bling, downside would be an even bigger opening showing off my lack of FMIC or oil cooler haha
Old 02-09-2016, 02:09 AM   #4
zeal86
zeal86's Avatar
Drives:
Install the Beatrush front beam brace and polish the radiator and AC condenser lines/ends as well as powder coat the surrounding brackets to add some visuals to the opening.
Here mine...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 10 Users Say Thank You to zeal86 For This Useful Post:
8R6 (02-09-2016), Brayden_23 (02-09-2016), Clipdat (02-09-2016), cwpbrz-ji (02-09-2016), danny_d19 (02-09-2016), go_a_way1 (02-09-2016), Kris86 (02-22-2016), mixtape (06-01-2016), olsonpg (02-10-2016), Teseo (02-09-2016)
Old 02-09-2016, 02:18 AM   #5
Brayden_23
You should probably get an oil cooler anyway since these cars run hot. The Maximal option is relatively cheap.
You could also just switch out the entire grill for some kind of wire mesh from the home improvement store to switch up the look. I think the FRS looks good with the open mouth regardless of what it's filled with
Old 02-09-2016, 02:47 AM   #6
danny_d19
danny_d19's Avatar
I almost bought the Mishimoto kit a couple months ago but the CAN-USD conversion is absolutely killing me right now! Before I cut the stock one I'll definitely give it a shot with it totally out to see how I like it
Originally Posted by zeal86 View Post
Install the Beatrush front beam brace and polish the radiator ends and AC condenser lines as well as powder coat the surrounding brackets to add some visuals to the opening.
Here mine...
That does look really good.... nice work man
Old 02-09-2016, 10:51 AM   #7
Teseo
Drives: frs
Here mine...
You are not worried about hitting something on the road and damage rad or oil cooler?
I would like to remove mine because it gettin dull. Clean build by the way
Old 02-09-2016, 11:28 AM   #8
zeal86
zeal86's Avatar
Drives:
Not worried...my 86 is not a daily driver... plus, HKS intercooler is going to occupy that spot soon.
OP...I cut off and dremeled the tabs off the bumper that the grille mounts to as I did not plan on re-installing it. As long as you don't do that you could always go back if you don't like how it looks.
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Old 02-09-2016, 11:33 AM   #9
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I'm loving the polished and powder coat idea. I will definitely be doing this with the remaining winter months.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
zeal86 (02-09-2016)
Old 02-09-2016, 01:13 PM   #10
T_Scott
T_Scott's Avatar
Drives: 2013 Raven FR-S
Use it as an excuse to go turbo. Can't go wrong with a polished or anodized black (what I will be using) FMIC...
Three pedals, six gears, and nothing but time.
T_Scott is offline   Reply With Quote
Old 02-09-2016, 01:19 PM   #11
zeal86
zeal86's Avatar
Drives:
The polishing I did by hand using blue magic and a microfiber cloth... I also used a Dremel with felt polishing wheels.
You don't even have to powder coat... I did because I was having some other things coated so I just added the brackets... you could just use duplicolor metal cast paints... duplicolor has many colors avaliable...this paint works pretty well at mimicking an anodized finish. Check it out.
Painted tow hook with Duplicolor Metal Cast
Takumi788 (02-09-2016), Teseo (02-09-2016)
Old 02-10-2016, 12:27 AM   #12
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Here mine...
Here comes zeal with his car porn again. Always making my car jealous I'll have to delete my history.
Heres a cheaper alternative to the Beatrush crash bar that I just ordered.
http://www.enjukuracing.com/products...scion-frs.html
Plan on giving it a shot of red for some extra bumper opening sweg for anyone that cares to look.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
The Following 2 Users Say Thank You to olsonpg For This Useful Post:
Uplink (03-17-2016), zeal86 (02-10-2016)
Old 03-15-2016, 12:32 PM   #13
danny_d19
danny_d19's Avatar
Finally found someone who has the grill modified like I was thinking of doing. Since I have fogs now I think the leftover honeycomb would look out of place (IMO). Won't be doing it anymore
Old 03-15-2016, 12:54 PM   #14
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Looks like the car has a big dirty buck tooth.
BDotG is offline   Reply With Quote
The Following User Says Thank You to BDotG For This Useful Post:
RedEdTed (03-15-2016)
Is the FRS front grill removal? mit_peid DIY (Do-It-Yourself) Guides 23 02-27-2016 01:00 AM
front grill PipeLovoo Exterior Parts (Aero, Lighting, Etc.) 8 05-28-2014 11:11 AM
front grill PipeLovoo Cosmetic Modification (Interior/Exterior/Lighting) 1 05-21-2014 12:53 PM
BRZ Front Grill Photoshop mikeTee BRZ Photos, Videos, Wallpapers, Gallery Forum 16 11-16-2013 06:18 AM
Front bumper grill. |-Goku-| Issues | Warranty | Recalls / TSB 20 09-04-2012 08:42 PM
