Old 02-04-2016, 06:26 PM   #57
ansibe
Drives: White BRZ
Awesome guys! Thanks for the advice.
Since I'll have to buy screws for my Sparco pedal, about how long were the screws? I'm guessing 1/2 inch or so?
ansibe is offline   Reply With Quote
Old 02-04-2016, 09:33 PM   #58
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
They were 1/2" or slightly shorter. Self-tapping and flat-headed with the bevel into the threads.
The Following User Says Thank You to EAGLE5 For This Useful Post:
ansibe (02-04-2016)
Old 03-04-2016, 12:13 PM   #59
Traktor
Drives: Subaru BRZ Limited
I just moved from Australia, where I had a RHD 86 to the USA where I now have a LHD BRZ. I had no problem heel-toing back home, but with the switch to LHD I have found the heel-toe technique I used back home doesn't work as well because my heel is obstructed by the transmission tunnel.
I am going to look into this, it looks like a worthwhile mod.
Traktor is offline   Reply With Quote
Old 03-04-2016, 11:20 PM   #60
ansibe
Drives: White BRZ
I installed my sparco pedal and I can hardly believe what a difference it makes. Thanks for the help everyone.
Sent from my Nexus 7 using Tapatalk
Old 11-14-2016, 11:34 AM   #61
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
pedal upgrade
did this mod, here is the reference to OEM pedal.
neilvosko is offline   Reply With Quote
Old 02-14-2017, 10:05 PM   #62
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Just did the full set myself.
"Pyramid Grid" texture in black from SRP.
Installation notes :
[a] removing dead pedal is a PITA. Pop out the large circles first,they are actually push-in connectors (like bumper connectors). I used a pick.
[b] cut along underside of all four edges with razor blade or exacto blade. Take you time, go slowly, separate the glue from the oem pedal. You will lose a little carpet but that's fine, it will be hidden.
[c] You will end up with the OEM hole on the carpet, plus whatever extra you cut away in the removal process. This hole should be much smaller than your new dead pedal. Under the carpet is a small wedge of Styrofoam that will absolutely get in your way and will complicate drilling the new holes. I recommend tossing it, your choice. My OEM dead pedal actually squeaked due to the styrofoam.
[d] Depending on how much the appearance matters to you, you can cover the carpet hole with some wide black tape (I had black Gorilla tape handy).
[e] mark new hole locations and drill in two increments, start with a small bit such as 1/16" per SRP instructions. Then go up to your larger size. I used a 9/64" final size after measuring the screws provided by SRP.
[f] Clutch and brake pedal covers come with inexplicably long bolts and jam nuts. You may need to shorten one or more of the bolts to clear the arm of the pedal. 5/8" length on the bolts was plenty for clutch and brake covers.
[g] optional: I wanted longer screws than the stock shorties provided by SRP. They only supplied three per pedal and that did not inspire confidence. So I sourced some 3/4" black screws in a compatible diameter from my local hardware store ( yes they stock black machine screws, who knew) The 3/4" screws gave very strong anchoring for both dead pedal and gas. See note below.
[h] optional: I kept the factory gas pedal intact because I wanted it a little higher for better heel and toe. So I covered the oem pedal with a trimmed up piece of Gorilla tape (black) and then mounted the SRP cover right on top using some 3/4" black screws. Worked great.
canyons is offline   Reply With Quote
Old 10-13-2017, 03:53 PM   #63
DomozitoLK
DomozitoLK's Avatar
Drives: 2018 Subaru Forester XT Touring
For all you guys who have removed the metal factory OEM dead pedal...anyone have one in good condition you want to sell? I'm in San Jose, CA.
Let me know...thanks!
Rob
DomozitoLK is offline   Reply With Quote
Old 10-25-2021, 02:27 PM   #64
86prime
Drives: 18 BRZ tS
Originally Posted by smbstyle View Post
One question when removing and then installing the pedal - what are the factory torque specs for the 10mm bolts?
Verus says 6 ft-lb
86prime is offline   Reply With Quote
Old 11-23-2022, 11:25 AM   #65
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
6mm bolts are easy to strip!
Most 6mm bolts, with 10mm hex heads are 56 inch pounds.
Don't listen to people who tell you to just wing-it until you have years of experience. Smaller bolts, like 6mm's, are easy to strip or break.
This is torque specs for an STI. They would generally apply to other Subarus.
Scargod is offline   Reply With Quote
Cusco Sports Accelerator Pedal Install + Review CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 25 03-27-2014 12:45 PM
Pedal Recommendation? swift996 Tracking / Autocross / HPDE / Drifting 24 04-09-2013 08:57 PM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 06:56 AM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 10:42 AM
JDM Gas Pedal for HeelToe dunphyjp Cosmetic Modification (Interior/Exterior/Lighting) 20 08-21-2012 02:57 PM
