Old 02-03-2016, 09:36 AM   #43
Car will not turn over check list:
1) Check/change battery
2) Do the 1,000 other things that people will say to try
3) See #1
ScoobsMcGee (02-03-2016)
Old 02-03-2016, 01:03 PM   #44
Davegixxer
Davegixxer's Avatar
Drives: 2016 Subaru BRZ
OK, @Tomahawk ...... how is your headache ....??
You haven't got back to us on the voltage of your car's battery.
The exact voltage is quite important, as you can see from the attached chart.
A battery with ONLY 12.0 volts WON'T engage a starter.
Have a beer, take a deep breath and ....... come back.
Bullchit. Even 10 volts can "engage" a starter. Sure it won't actually get it to fully turn the car on, but will do a couple of slow chugs to try.
Davegixxer is offline   Reply With Quote
Old 02-03-2016, 01:06 PM   #45
Davegixxer
Davegixxer's Avatar
I'm guessing this car is Push To Start based on his "will only go to acc" comment? My car is regular key, so I'm not 100% on your PTS procedure, but when the battery in the fob dies, where does the owners manual say to hold it to get the car to start with a dead fob battery? That is what I would try...
Old 02-03-2016, 01:17 PM   #46
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
I think that if the voltage is so low that the ECU does not have the number in its lookup tables, it won't even attempt to start.
mdm is offline   Reply With Quote
Old 02-03-2016, 02:21 PM   #47
I stand corrected ...... @Davegixxer is correct ..... a battery putting out only 10 volts will turn a starter over.
Old humfrz was a couple of volts off on that one ......
Old 02-03-2016, 02:44 PM   #48
Tomahawk
Drives: 13 FRS
I have a key to put in to start it. Wish it was push start. Would've been a nice touch but I didn't get it with one
Tomahawk is offline   Reply With Quote
Old 02-03-2016, 06:55 PM   #49
steve99
Drives: FT86
Ok if its key start, then when you insert and turn key the key symbol on dash should turn green, if its still red it means the car is not reading the security RFID tag in they key.
They are usually passive chips ie even if battery is flat in key it will still work, the battery just powers the bush button lock,,\unlock.
If neither key get the key symbol on dash to turn green the car is not going to start as security is still active.
Old 02-03-2016, 06:58 PM   #50
steve99
Drives: FT86
1- key fob unlocks doors (I have a tundra but the keys are completely different and the battery in the fob is brand new)
2- buying a new battery (optima red top)
3-clutch is fully pressed but still nothing
4- I did wiggle the steering wheel which is weird since I've never had to do that to any other vehicle I've owned.
5- I also have the base of the model so I don't have the fancy push start button 😕👎🏼
Once I get the new battery in I hope it fixes the problem
on the push button start cars the electrically operated steering lock pin can become jammed if theor is pressure on it from steering wheel and it does not release, car wont start.
on key start it likely mecanicaly operated by turning key so just make sure when you turn key to on position steering lock is released
Old 02-03-2016, 07:56 PM   #51
Davegixxer
Davegixxer's Avatar
Ok. So it is still not starting? What exactly happens? When you turn the key to crank do all of the gauge lights and everything drop out or stay on and bright? No crank at all right? I deal with tons of "no start" issues at work with bypass modules locking up or adding remote starts to integrate with factory immobilizers. With a multimeter and 10 minutes I'm sure I could tell you what is going on with it. If only you were near Chicago
Old 02-03-2016, 08:59 PM   #52
BRZnut
Drives: BRZ DGM Limited
Nope I only get the red one
Then you have a problem with the security system not recognizing your key. If the new battery does not cure this, then the dealer is going to have to trouble shoot the security immobilizing system of the car.
Old 02-03-2016, 09:18 PM   #53
Davegixxer
Davegixxer's Avatar
You've tried both keys. Also random question, but you don't have any other random keys on that key ring that have chips do you? Mostly a Toyota issue I have seen, but other car manufacturers keys sometimes have stronger RFID that are sending out their signal and in worst case scenarios the car sees that other chip and freaks out. Normally not an issue, but I have tried to program a bypass module before and the car didn't like it because of a benz and ford key on the same ring.
You said you had a turbo installed? What are you doing for electronics/fuel management?
Old 02-03-2016, 10:49 PM   #54
Tomahawk
Drives: 13 FRS
Unfortunately I think that's what's going to happen
Old 02-03-2016, 10:50 PM   #55
Tomahawk
Drives: 13 FRS
I don't have other keys on the key ring just the one for the scion. The kit is from Fullblown Motorsports stage 1. I haven't added anything else to it other than what came with the kit
Old 02-04-2016, 01:34 AM   #56
ryoma
ryoma's Avatar
have you tried to change out the battery on the key fob?
Car only starts when primary 02 is unplugged j0hnnybk01 Issues | Warranty | Recalls / TSB 22 08-28-2017 11:13 AM
Random tip - cold starts Dammod AFRICA 34 09-22-2015 01:38 AM
jerky starts goshem BRZ First-Gen (2012+) — General Topics 14 01-19-2014 11:21 PM
Jerky / shaky starts Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2013 01:27 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
