| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Rotating tires if one is newer than the rest, how?
So normally the two rear tires come straight forward, same side. And the two front tires go back, opposite sides.
For me, I had to replace the front passenger side tire (hit a hard bump and popped the sidewall). This was at like.. 3000 miles? Currently at 4400 miles and probably doing rotation soon. How should I rotate? |
#2 |
if your tires aren't directional, they are supposed to go in an X pattern I believe. driver's front goes to the passenger rear, etc. if they are directional, just swap from front to back on the same side.
#3 |
Here ya go ........ pick one .........
![]() http://www.tirerack.com/tires/tirete...160127074826:s Personally, I'm stuck in the 80s with rotating non-directional radial tires ..... I rotate them front to rear and rear to front, keeping them on the same side. Why? Heck, I donno ...... someone convinced me way back when, that radial tires should always spin in the same direction ..... ![]() humfrz |
#4 |
Drives: '13 Ultramarine
Personally, I would start with the newer tire on the right rear, then rotate as normal at your next oil change.
#5 |
Drives: 2013 Pearl White 6MT
If you have directional tires (look for arrows) you have no choice, else your treads will be backwards.
#6 | |
This is actually very important because if you have one or more (if one is then at least one other has to be) on backwards things can go wrong in a hurry if/when you lose traction.
| The Following User Says Thank You to Tcoat For This Useful Post: | PandaSPUR (01-27-2016) |
#7 |
Ah ok. So since I have the stock primacy tires, which are directional, I have no choice in how I want to rotate them anyway?
But im confused, that means I'd end up with backwards treads if I followed the manual. And again, my main issue is that one of my tires is brand new compared to the other three |
#8 |
The idea behind rotation is to even out the wear.
For example, if the fronts wear faster than the rears then when you rotate front to back that will even out. In your case since you have a new tire on the front it will naturally have less wear than the rear. If you know that your fronts wear faster than the rears then don't rotate that side this time. It will eventually even out. |
#9 |
Drives: Full race 4cyl boxer
#10 |
Front to back and keep on. Directionals can't be rotated diagonal because you'd be reversing tread. Treads are designed to funnel water. With 3k miles I wouldn't worry about it. I don't know about stock tires. I have different ones. Most have catoony arrows in them that show direction
#11 | |
humfrz |
#12 | |
not a twin owner
Drives: 2016 Veloster Turbo DCT
Which manual? 2016 FRS manual says |
#14 |
I stand by my original statement...the stock primacy tires are NOT directional. They do have an inside and outside for tire mounting purposes, but once mounted on the rim, it doesn't matter which corner of the car the wheel is placed on.
For rear wheel drive vehicles (non-directional and not staggered), I cross the front two to the opposite rear, then the rears straight up on the same side. I rotate mine at every oil change. When I have the front jacked up for the oil change, I swap the 2 front tires side-for-side while the oil is draining, then when I am done the oil change, it is a simple front to rear exchange to finish the tire rotation...works for me. Again, I would put the newer tire on the right rear to start, then rotate as normal at your next oil change. It sounds like there is a 1400 mile difference between the original tires and the new one...that's not likely enough to make any difference. I wouldn't sweat it.
| Edge Insight CS Monitor (1996 & Newer OBDII Enabled Vehicle) | FBPARTS | Exterior Parts - The Rest | 3 | 12-02-2015 04:08 PM |
| Looking to move to a newer tool box | Concorazon | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-01-2015 09:53 AM |
| How to use newer revisions of OFT maps? ie 700I to A01I | derka-derka | Software Tuning | 3 | 09-05-2015 08:21 AM |
| Rotating Directional Tires for track and autocross | RMP | Tracking / Autocross / HPDE / Drifting | 7 | 12-03-2014 12:26 PM |
| Rotating Tires/Wheels | ap5512 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-15-2014 01:38 AM |
