Old 01-12-2016, 06:15 PM   #15
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Brake pedal switch, and gear position selector are the two things that immediately came to mind for me as well. Screw all these bandwagon people, lol.
Stang70Fastback is offline   Reply With Quote
Old 01-12-2016, 07:55 PM   #16
NahumCC
Drives: 2013 FR-S 10 Series
Brake light switch is the least likely because the same switch for the lights generally feeds the starter cutout logic.
NSS on the other hand can be notorious for being fine one minute and not the next. Saw it all the time with automatic saabs.
NahumCC is offline   Reply With Quote
Old 01-12-2016, 08:44 PM   #17
...........copy cat ..............
Stang70Fastback (01-12-2016)
Old 02-10-2016, 11:39 PM   #18
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Drives: Infiniti G20 / FRS
Send a message via AIM to Ak1m0to
Wanted to update and to help other members that may have the same issue.
We found out the issue was a faulty inhibitor relay. Car would start right up after jiggling the relay. Just order one and should come in soon . whenever the car doesn't start, I just start pushing on the relay again and vola!!!
Slowmatic Drfiterz, from P to D in a heartbeat.
Ak1m0to is offline   Reply With Quote
Old 02-11-2016, 08:48 PM   #19
BRZnut
Drives: BRZ DGM Limited
where is this relay located???
Old 02-12-2016, 12:59 AM   #20
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
@Ak1m0to said the inhibitor relay so using my shitty imgur editing skills I circled it Orient yourself so you are facing the car with the hood open:
It should be in the circled areas
Old 02-12-2016, 02:55 PM   #21
Ak1m0to
G20 Guru
Ak1m0to's Avatar
It's on the left side of the engine bay within the fuse/relay box.
Top, black relay on the right.
Right below the word "FUSE".
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
STI Push Start Inextirpable CANADA 1 03-15-2013 03:52 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 04:28 AM
