Old 01-11-2016, 02:48 PM   #519
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by Tor View Post
Thanks. But meanwhile I also checked the price on the Subaru parts.
Online they came out at 360 something euro. I can imagine it will be even more expensive from a dealer. Plus the fittings, hoses, coolant etc, it will end up at 400+.
For that kind of money I would rather take the Cusco option or a passive cooler. So, thanks again for your help, but I'm out again.
You can also use the throttle body method, it's less effective but also cheaper.
The only thing you would need then are the oil cooler, the bolt, 1.5m a 2m hose and 4 clamps. That was at around 250€ at the time for me.
Works also great for AT 86.
My post about it
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 02-08-2016, 01:05 PM   #520
N234
N234's Avatar
Drives:
I'm also wondering if other oil coolers are compatible. The FXT's 21311AA170 seems to be hard to get at a decent price.
Are the 21311AA180's and 120's going to work? Has anybody used a sandwich plate other than 21311AA170?
Originally Posted by ZZT86 View Post
Does anybody know if the oil cooler part #21311AA180 (off current WRX/FXT) is any different to #21311AA170 used in the 2014 FXT ?
N234 is offline   Reply With Quote
Old 02-09-2016, 09:33 AM   #521
ZZT86
ZZT86's Avatar
Drives: BR86
Yes part AA180 fits . . . . see my recent post 516 !
ZZT86 is offline   Reply With Quote
Old 02-26-2016, 02:15 PM   #522
nunonuna
nunonuna's Avatar
Anybody tried to use sandwich plate/block on top of this cooler unit for sensor for gauge??
nunonuna is offline   Reply With Quote
Old 03-10-2016, 01:27 PM   #523
sickmint79
Drives: bmw
i'm using one between cooler and filter, although between oem housing and cooler might be preferred (?)
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 03-10-2016, 02:37 PM   #524
nunonuna
nunonuna's Avatar
Thanks~
Yeah I was gonna put it between cooler and filter as you did. I don't think adapter between oem housing and cooler is possible as the oil cooler connector has male threads.
What kind of adapter did you put?
Do you have a picture??
Old 03-13-2016, 12:26 AM   #525
sickmint79
Drives: bmw
Thanks~
i have this beatrush one.
Old 04-17-2016, 10:38 PM   #526
Shinra Inc
Shinra Inc's Avatar
Drives: Tiny Bronco
I just installed this oil cooler. While I guess you can use the BRZ's heater hose with the Forester's pipe, I wasn't happy with the kink in the hose so I went to the parts store and got a heater hose with a 90 degree bend. Carquest/Dayco Part #: 19590336. I cut off one of the bends and had a 90 degree with a straight hose which worked.
I also decided to use the Forester's coolant pipe that bolts to the driver's valve cover. It was a PAIN to bolt on. I had to pop out the cam actuator harness ties which was tricky(they were anchored where the bolts thread in), then getting the upper bolt in was a nightmare. Also, the pipe was pointing straight up into the injector cover. I used a 1/4" drive extension and bent it out. I can see why Carnz's guide just had you use a long hose. I just didn't want to sling a heater hose down the side of my engine, so I went to painful route.
Shinra Inc is offline   Reply With Quote
Old 04-22-2016, 03:40 AM   #527
mb_
Ex-MR2 owner
Drives: Scion FRS
Anyone else running this setup but through the throttle body? Currently have mine setup that way, will monitor temps at track this upcoming summer and see how much it brings the oil temps down.
mb_ is offline   Reply With Quote
Old 04-22-2016, 10:49 AM   #528
sstfnv
sstfnv's Avatar
I'm running it on both my street FRS and my Spec86 BRZ race car through the throttle body. The highest oil temp I've seen on track is 254F and that was 85F outside temp.
I prefer the throttle body route due to the ease of installation and the results are pretty good.
sstfnv is offline   Reply With Quote
Old 04-22-2016, 09:49 PM   #529
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I'm running it on mine. Plenty of Autox and track events, so far oil temps have been good. I also have a CSF radiator so that is helping too.
Shneegle is offline   Reply With Quote
Old 04-25-2016, 03:59 PM   #530
CxG
Drives: Pearl White '13 ZN6
so if you're going to track a turbo car a sandwich plate and oil cooler is necessary but not if it's N/A? What about supercharged cars? I mean they do run cooler than turbos right?
CxG is offline   Reply With Quote
Old 04-30-2016, 01:57 AM   #531
mb_
Ex-MR2 owner
Drives: Scion FRS
Was hoping to monitor and report oil temps after today's track day but unfortunately it was raining/cold out so I couldn't get a good idea on how much it brought temps down by compared to having no oil cooler. Hopefully the next track day stays dry and warm
Old 05-09-2016, 11:01 PM   #532
mb_
Ex-MR2 owner
Drives: Scion FRS
Went to the Ridge Motorsports Park yesterday in Shelton, WA. Oil temps were at 100 degrees celcius (Total 0W-30) during and after each session. But then again, it wasn't every warm. We'll see what the temps are at in a July track day.
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
