Old 12-19-2015, 06:36 PM   #463
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Tactrix's software is locked into their hardware. Some of the clones work with the hardware, but bricking your ECU is no fun. I strongly suggest real Tactrix or OFT. EcuTek is good for people getting a custom tune from a pro. The big boys often use an ECU replacement.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
Rossi (12-20-2015), thambu19 (12-19-2015)
Old 12-20-2015, 03:56 AM   #464
steve99
Drives: FT86
Originally Posted by Rossi View Post
Would it be possible to flash using a ELM 327 cable or a obd2 cable that can read data? Or do you have to have the tactrix cable?
ELM327 adapters can only do basic interaction with ECU using standard OBD calls, ie read cel codes clear cel codes and access basic engine data that the manufacturer has made available via standard obd call they are required to by law.
To flash the ECU with new ROM data you need a specialized device any one of the 3 below will work they are in order of cheapest to most expensive. Tactrix is the least user friendly
Tactrix adapter
OpenFlash Tablet -comes with free tunes
Ecutek Cable and Licience
Rossi (12-20-2015)
Old 01-04-2016, 06:04 AM   #465
dave-
Drives: 86 GT
Probably been asked before but info seems to be all over the place...
What/where are the most complete RR definitions for the A01G ROM? There are Td-d github repos, I've seen OFT ones from @Wayno dated late last year, revisions by @Kodename47 and various useful additions by @ztan.
I'm not using an OFT to flash but from memory that doesn't matter in the case of A01G def's?
Second question, can someone provide a working G series logcfg.txt file to do tactrix logs with boost? Think I have the wrong addresses or settings. Did try to generate a new logcfg file with that app but it gives me an error because the RR logger isn't configured correctly. I gather most boosted people are running ecutek here from my searches? Sprintex supercharger kit in my case.
dave- is offline   Reply With Quote
Old 01-04-2016, 09:28 PM   #466
steve99
Drives: FT86
kodename47 are probably the most upto date he has usually intergrated most of the other guys stuff.
you can only extract parameters the ecu uses with the logging, if you after some extra parameters you could try asking ztan
romraider logger not set up for our ecu
you might want to talk to @D-VO he has done supercharger open source
Old 01-05-2016, 01:09 AM   #467
ztan
Drives: Toyota 86
paramname = MAP
paramid = 0xFFF87C60
isfloat = 1
scalingrpn = x,0.133322368,*
Logs MAP in kPa
ztan is offline   Reply With Quote
Old 01-05-2016, 06:23 AM   #468
dave-
Drives: 86 GT
Originally Posted by ztan View Post
paramname = MAP
isfloat = 1
Logs MAP in kPa
That's what I had, didn't know it was kPa though which helps. But my logs still don't look right as WOT runs peak at 137.297 kPa so ~20psi?
It's a Sprintex SPS/210+ kit with 69mm pulley. Positive the peak was 12-13psi on the dyno.
Did some logs yesterday/today with some spirited driving.
http://datazap.me/u/dave/sprintex-tune
http://datazap.me/u/dave/sprintex-tune-log-2
http://datazap.me/u/dave/sprintex-tune-log-3
Old 01-05-2016, 06:29 AM   #469
ztan
Drives: Toyota 86
MAP is in kPa absolute.
137kPa absolute = 100kPa atmospheric + 37kPa (5.3 psi) boost.
Is your MAP sensor scaling right? Which sensor are you using and which ROM address did you adjust (the original def sensor scaling addresses were wrong). Just had a look at your logs - your MAP is pegged high at 137kPa which looks like a maxed out stock sensor. The psi boost value is in your logs as manifold_relative_pressure.
Stock sensor scaling = 250mmHg/V -150mmHg
Stock sensor at 5V = 1100mmHg ~= 145kPa
ps: you can delete the AF_Corr_3 and AF_Learn_3 values from your logcfg.txt - I'm sure the latter is an OL_enrichment value and I haven't traced the AF_Corr_3. You can also boost the sampling rate by dropping some of the parameters that you aren't really looking at and decreasing the calcsampinterval value - I am using 500 at the moment and log 32 parameters at 40ms interval.
Old 01-05-2016, 06:39 AM   #470
dave-
Drives: 86 GT
Yeah saw the ~5psi bit when I added this from some thread here:
paramname = Manifold_Relative_Pressure
paramid = 0xFFF88F78
isfloat = 1
scalingrpn = x,0.0193367747,*
Believe it is the OEM MAP sensor as the kit doesn't change it. Not 100% sure.
Manifold Pressure Sensor Scaling A/B/C are the same:
ROM def's are Kodename's metric & % one:
<table name="Manifold Pressure Sensor Scaling A" storageaddress="1000CC" />
<table name="Manifold Pressure Sensor Scaling B" storageaddress="1000E4" />
<table name="Manifold Pressure Sensor Scaling C" storageaddress="11CC20" />
Logged using:
paramname = MAP
isfloat = 1
Should add it isn't my tune and from my inexperienced eye, looking at the logs it isn't very good anyway.
Old 01-05-2016, 06:54 AM   #471
ztan
Drives: Toyota 86
isfloat = 1
The scaling at 11CC20 is the only one that affects MAP.
When you get a uprated MAP sensor, have a look at my boost fuel cut fix to protect you from major overboost. Boost protection at the moment with that stock sensor won't work, but not critical with supercharger compared to turbo.
Old 01-05-2016, 06:59 AM   #472
dave-
Drives: 86 GT
Scaling for C is the same so all good there.
Have all your opensource threads saved, as you said not critical with the blower but would def do it for a turbo.
Will have to confirm still stock sensor but not overly impressed with the setup so far so who knows how long the kit will stay installed anyway!
Old 01-05-2016, 10:35 AM   #473
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can't change the MAP sensor on the Sprintex, but there's no need. MAP just caps at the sensor limit.
What's wrong with the setup @dave-?
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-06-2016, 05:12 AM   #474
dave-
Drives: 86 GT
We're not seeing much of a difference to a couple cars with the standard kit and 75mm pulley after custom tuning. The canned tune that was supplied with the stage 2/plus kit is part of the problem (it's shit) but ultimately the claimed improvements of the stage 2/plus blower and extra boost from the 69mm pulley, I'd expect a lot more than we're seeing.
Need to get the car on a dyno again and put some decent effort into the tune. I'll report back once that is done. Haven't ruled out hardware or install issues either as yet. I do know the intercooler took a few go's to bleed completely. I wasn't present for the install so not sure what happened there or if its a common thing. Haven't read much of the sprintex thread TBH.
Old 01-10-2016, 04:05 AM   #475
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. QQ for you: Where exactly does the 'GDI Firing Angle Low Load Cold' become effective? Its a little confusing. Why would there be a designation of "High Load" and "Low Load" if both tables have an X-Axis of 0.20 -> 1.20 load? Also, where does "cold" start and end? @Td-d @Kodename47 @ztan Maybe??
D-VO is offline   Reply With Quote
Old 01-10-2016, 04:42 AM   #476
Kodename47
Kodename47's Avatar
Drives: UK GT86
I don't know the answer to your question, but like the PI Ratio tables they are all set to the same so I've only ever seen them set all to the same. There must be some form of hysteresis however I very much doubt anyone would go to the bother of changing SOI dependent on temps.
.: Stealth 86 :.
Kodename 47 DJ:
D-VO (01-10-2016)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
