#604 |
Drives: 2014 Subaru BRZ
Niice! Got the same keyboards. Awesome!
Sent from my SM-N900W8 using Tapatalk |
#605 | |
Proud of BOXER
Drives: Subaru Boxer
Anyone other than me still playing BF4?
#607 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Just got all my parts in for my first PC build. Should have it put together this weekend! Time for some R6:Siege and Rocket League!
#608 | |
Proud of BOXER
I'm not great.
#609 |
Guest
Posts: n/a
I'm getting CPU temps of 70 on r6 siege on ultra settings. Running a cool master evo 212, Intel i7 4790k and a msi 970
Is this good, bad or normal? |
#610 |
Dismember
Drives: 2013 Red Scion FR-S
Sounds high. Re-seat the heat sink with fresh thermal paste. Make sure the fan is working and blowing. I usually use a credit card to get paste off.
#611 |
Guest
Posts: n/a
#612 |
Dismember
Sorry. Been a while since I've done this. Yes, a credit card to scrape (bamboo would do too) and then a cotton swab and alcohol to get any oils and gunk off. Just make sure you get all lint off at the same time. Canned air helps, but it's not worth buying. Air dry. Then new paste. It doesn't take much paste. I usually spread it out a little, but I've heard varying theories on the right way. There are differences in paste quality, but anything more than 5 or 10 bucks is scamming you. Under load, it should probably get down to 50 degrees C. I usually just use stock intel heat sinks. They work great for anything but overclocking.
#613 |
Drives: Neptune GR86
Just a pea sized drop in the center is all you need for a good even spread. Don't bother smearing it around.
There's a good video on YouTube that shows it with a piece of clear plastic.
#614 | |
Drives: '13 Hot-Lava FR-S
By the way, 70c is up there but it's not in danger territory yet. You still have about 20c or so until you hit the thermal limit. What temps are you getting under a stress test? |
| The Following User Says Thank You to Vladimir Tutin For This Useful Post: | fumanchu1 (12-18-2015) |
#615 |
Dismember
70c can probably lead to CPU throttling and will definitely limit things like overclocking.
#616 |
CPU throttling occurs around 90c-100c and has a max temp rating of 105c on the 4790k. If he gets throttled when as low as 70c then there is something wrong with the CPU. Yes if that's idle temps it'll limit overclocking. Hell, many overclockers are comfortable licking 80c. 70c isn't a good temp and yes he should remount the cooler, but it's not a dangerous temp.
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 04:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 06:37 PM |
