JDM Vaping Stance Nation
Drives: 2013 White
Spec-D Headlights Retrofit?
Did anyone do the Spec-D Headlights retrofit yet? I'm not a light output snob, but the stock projectors are pretty shitty even when I upgraded to D2S HID Bulbs.
Was planning on getting some projectors from TRS and installing, maybe Morimoto but not sure if the size will be too small or too big. |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
In for pics of the diffrence when you do this |
#3 |
be careful of using 55W HID bulbs in some projectors as not all projectors are made to handle 55W. if it isn't made to handle 55W, you will burn the bowl in the projector eventually and have a poor performing/useless headlight setup.
as for the spec-D, I'm pretty sure you can retrofit any type of projector from TRS in there but it will be a matter of how much work you are willing to put in. I believe the mini D2S projector is one of the easier to install
| The Following 2 Users Say Thank You to ryoma For This Useful Post: | FRSBRZGT86FAN (12-03-2015), go_a_way1 (12-03-2015) |
#4 | |
Not Bаnned Anymore
They have been in for over a year and so far so good. |
#5 | |
Drives: 2013 White
Only retrofit I've done is a projector install for motorcycles. Even then, the only projector I've used in those are the FX-Rs. Install was simple enough, just need to build a bracket to mount it on and retain the adjustment points, then throw a overlay shroud on it. |
#6 | |
DIMENSIONS Max Height:95mm Max Width:100mm Max Depth:145mm O Lens Diameter:3 inch X Lens Diameter:2.75 inch Mounting Shaft: Diameter = 35mm Lock Nut:Size = 46mm Housing Depth:Minimum = 117m Lens Diameter: 3" Size: Medium when I retrofitted the FX-R, all I did was cut a hole in the back of my housing and JB weld it all together lol. however, it was simple (just time consuming to align properly) since I had a sealed beam housing. the housing for the 86 might be a bit harder.
| The Following User Says Thank You to ryoma For This Useful Post: | YamahaR86 (12-04-2015) |
#7 |
Drives: 2013 Ultramarine FR-S
| The Following User Says Thank You to DustinS For This Useful Post: | YamahaR86 (12-04-2015) |
#8 | ||
Drives: 2013 White
One review on it and says Quote:
#9 |
I would imagine they are using the same projector. Makes it much easier/cheaper for them.
Note the addition message from TRS about fixing the brackets. You could call them up and ask, they have some of the best customer service you will find and can definitely help answer your question. If you do call, it would be worth placing your order over the phone and seeing if you can get the new Mini H1 7.0 projectors in it. I can't remember if they have started including them in the kits or not, but the new Mini H1 7s are out, and much better than the 6's. Just bought them to upgrade my stock headlights from the 6's. Morimoto Mini H1 7.0
#10 | |
Drives: 2013 White
#11 |
Interested in why you are going about it that way. Keep us updated.
#12 |
Drives: 2013 White
I want to see the sizing of the projectors, if it's the same for all of their products without having to actually open the headlights yet (no point in opening them up to measure and have to reseal when I don't even have aftermarket to put in).
#13 | |
- Edit: Contacted TRS, they said the reto-quik kit fits any spec-d headlight that uses a projector.
| HID Retrofit w/blacked out OEM headlights | Aztec | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 09-01-2015 11:03 PM |
| Spec D Headlights RetroFit | Wyattkb | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-04-2015 12:15 AM |
| DIY Retrofit Winjet headlights | post_break | DIY (Do-It-Yourself) Guides | 6 | 07-15-2014 12:13 AM |
| FS: TRS HID Retrofit Headlights for Sale | tonystewart | Exterior Parts (Aero, Lighting, Etc.) | 31 | 04-15-2014 06:51 PM |
