#99 | |
Drives: GT86
Cat temp has been logged in the more recent entries. Stock header, stock front pipe. Last edited by freerunner; 12-01-2015 at 05:49 AM. |
| The Following User Says Thank You to freerunner For This Useful Post: | steve99 (11-30-2015) |
#100 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#101 |
Drives: GT86
#102 | |
Drives: Scion FRS
#103 |
I suppose I can change the table to 35* degrees advance max and see if it will stick, or if it shifts up or down. From the logs, though, it seems to change at 2.5* increments. The exhaust cam seems to change smoothly through the range instead of increments of 2.5* from the looks of it.
Intent > Content
#104 |
eh... lol
Intent > Content
#105 |
Drives: car
cross posting from the other thread:
The AVCS intake side has the negative values @thambu19 and others were talking about because it is a mid lockpin AVCS. That means the intake side can retard, not just advance. The retard is a fuel economy thing. It's the same type of AVCS that's on the FA20DIT. In fact, it's the BorgWarner phaser technology that Ford uses on the 5.0 Mustangs. On those FA20DIT engines when you delete the tumble generator valves you need to advance the AVCS or it runs like crap without all that tumble motion in the combustion chamber. more details (mostly relevant to FA20DIT) here http://forums.nasioc.com/forums/show....php?t=2687550 |
| The Following 3 Users Say Thank You to arghx7 For This Useful Post: |
#106 |
@arghx7 Y U so Awesome!? lol
So I went ahead and changed my cam tables to be at 35* advance max. ![]() 4th gear pull: http://datazap.me/u/solidone/af-lear...zoom=7716-8003 3rd gear pull: http://datazap.me/u/solidone/af-lear...zoom=5197-5341 It seems even with the intake cam advance targeted at 35* from 2200~6000rpm it will fluctuate between 35~37.5 degrees. Is this due to the "tumble generator" effect you are talking about? It seems to be advancing by 2.5 and not retarding here. And in the previous logs where I have the intake advance targeted at 40* 2200~4600rpm then 35* 4800~6000rpm it would be as much as 5* more advanced than the targeted 35* from 4800rpm. ![]() 4th gear pull: http://datazap.me/u/solidone/af-lear...zoom=2699-3008
Intent > Content
#107 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Are you changing both Safe, and Normal tables. They both have to be the same or you'll get inconsistent results.
If I say yes, will that make you think I understand?
#108 | |
Drives: UK GT86
I guess what you log will vary what you see, the cams will never be perfect and follow the map due to the way they operate. There will also be variances between the banks too due to this. On ECUtek I have 2 sets of logging parameters, one shows "From Rest" values which are close enough to the values in the table, the others are cam angle which are a little different.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | solidONE (12-02-2015) |
#109 | ||
Intent > Content
#110 | |
Drives: UK GT86
As for the exhaust, it may well be a parameter that doesn't directly relate to the values in the table, and it could be that only one bank is suffering if that is an issue. I would't go changing tabular values to get the logs to read what you want as it may well be that the OFT is logging a different cam angle value. Just so you can see some of the full AVCS parameters:
.: Stealth 86 :.
#111 |
Drives: UK GT86
Resurrected this old spreadsheet of mine:
AVCS Viewing/Comparison Tool Paste in your own AVCS tables, it will show you overlap (based on suggested 0 positions of cams) and allows you to compare 2 different AVCS maps. It also has a tab to allow you to adjust axis scales if you desire and also one to convert normal/safe tables to a base table. The charts are taken from the max load column as these all usually set the same for WOT load areas.
.: Stealth 86 :.
#112 |
Drives: Sakura Miku
Does anyone know if this is an interference type engine and can make contact with the valves?
Niknej-jenkiN
| Timing chain issue? | Hardpack | Issues | Warranty | Recalls / TSB | 14 | 01-11-2016 12:25 AM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 04:01 PM |
| Stock Rom: Timing + Learn Value | sw20kosh | Software Tuning | 7 | 12-11-2013 08:09 PM |
| E85, Boost and Ignition Timing | jamesm | Software Tuning | 23 | 12-11-2013 03:19 PM |
| Timing belt shredded..?! | drei | CANADA | 5 | 12-06-2013 06:54 PM |
