Old 11-30-2015, 05:24 PM   #1
86Hiro
Disabling Turn Signals.........
Is there a way of disabling the turn signals from staying on, so that they ONLY come on when using the turn signal stalk itself? Im putting in 3K HID Fogs and only want the Fog Light itself on. That orange amber turn signal staying on is one of the dumbest "features" Toyota/Scion created.
86Hiro is offline   Reply With Quote
Old 11-30-2015, 05:27 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah you can swap the bulb (can't remeber the number) as the OEM one has 2 filiments (no idea how to spell it and to lazy to look it up)
or
You can cut the 12V wire that powers the "running" light part of the signal.
Old 11-30-2015, 05:29 PM   #3
86Hiro
I read somewhere a while back that disconnecting the green wire that runs to that bulb, at the bulb socket would do this for me. I will try this tomorrow and see if it works.
Old 11-30-2015, 05:30 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah that sounds about right. Enjoy your new fog lights!
Old 11-30-2015, 05:38 PM   #5
86Hiro
Thank you sir!
Old 11-30-2015, 05:58 PM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
put a piece of tape over the one bulb connector
ive had this done for almost 2 years now, best mod and its free!
http://www.ft86club.com/forums/showthread.php?t=70076
Old 11-30-2015, 06:09 PM   #7
86Hiro
Dude thats even easier then I thought!!!! Thanks alot!
Old 11-30-2015, 06:10 PM   #8
86Hiro
Weird question, but your Screen name looks very familiar to me from a different forum. You didn't by chance have a white srt4 did you?
Old 11-30-2015, 06:19 PM   #9
WhiteFRS69
WhiteFRS69's Avatar
i did
whiteSRT69 lol
Old 11-30-2015, 06:20 PM   #10
86Hiro
I knew it!! Its always nice seeing a fellow member
Old 11-30-2015, 06:31 PM   #11
WhiteFRS69
WhiteFRS69's Avatar
@STV3 was also on the forum, he actually still has his SRT
there are a few other people on here who came from the platform to this one
Old 11-30-2015, 07:21 PM   #12
86Hiro
Oh nice! I miss mine dearly lol. One day, I will have another Clean white SRT.
Old 12-01-2015, 01:52 AM   #13
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Yes, removing the green pin from the plug well disable the DRL feature on the signals.
You need to take apart eh plug to gain access to the pin. You'll also need something skinny to push the clip on the pin itself so that you can remove it. Once you remove the pin, just feed it back into the black tubing on the harness.
thatfilipinoguy is offline   Reply With Quote
Old 12-01-2015, 07:39 AM   #14
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
This is exactly the way I have my parking lights set up now; I felt like there was just too much "going on" in the front between the headlights, parking lights, side markers, and the fog light kit that I had just installed (also in 3K at the time, and like you said the amber conflicted with it).
What you simply need is a single filament bulb instead of your standard one. I requested this from the vendor that I purchased my LEDs from, so mine came like this, but I think it's as easy as simply clipping off one of the wires on a regular bulb (I'm not sure which, but it looks like others have chimed in with that information if you want to go the DIY route - the tape seems like a simple fix for it if you don't want to mess with cutting anything).
Here's a picture of mine for reference - the parking lights only function as turn signals when you engage them -
Ammunition is offline   Reply With Quote
(HELP) PROBLEM WITH TURN SIGNALS coolaron Issues | Warranty | Recalls / TSB 3 05-22-2015 05:36 PM
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Eyebrow Turn Signals PhastekSport Cosmetic Modification (Interior/Exterior/Lighting) 11 01-28-2013 01:52 AM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
