Old 11-29-2015, 10:54 PM   #1
Qwimby2
Drives: 05 Miata Mazdaspeed, 2015 BRZ
Track stuff
I'm eager to get the car to the track. I'll have to get some wheels and tires so any info on what works with these cars will be welcomed. Tires? Pads? I don't have an owner's manual yet but expect it here soon. If I don't see anything to the contrary I'll put in Castrol LMA synthetic brake fluid. I used the regular LMA in my turbo Porsche race car for six years and then the synthetic in my Miata with never a fade problem, and it was a lot cheaper than the blue stuff.
Any track-related chit chat would be welcome.
Qwimby2 is offline   Reply With Quote
Old 11-29-2015, 11:32 PM   #2
ryoma
ryoma's Avatar
you can find a lot of your track related answers in this section:
http://www.ft86club.com/forums/forumdisplay.php?f=39
tires, pads, and fluid is a good start. a lot of people say to not use the stock pads at the track as they will ruin your rotors. but stock rotors with upgraded pads are fine
The Following User Says Thank You to ryoma For This Useful Post:
JohnJuan (11-30-2015)
Old 11-29-2015, 11:42 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=25485
http://www.ft86club.com/forums/showthread.php?t=38926
http://www.ft86club.com/forums/showthread.php?t=23680
IMO sounds like you've got a fluid preference and all you need is a pad suggestion (no reason to change rotors, blanks>slotted from what I've seen and read), everything will be to taste, there is no singular solution. No reason to upgrade OEM wheels unless you want a different look/size/separate tires for street/track, OEM Michelins can take a few days of abuse, they're built to last but alignment will wear the outer edges. Have fun.
ineedyourdiddly
Old 11-30-2015, 10:19 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
First time?
Longacre tire pressure gauge
Carbotech XP10 Pads
Torque RT700 brake fluid
OEM camber bolt
alignment
OEM tires will be fine if they are the Michelin Primacy.
If you have the crappy bridgestones I'd get something else. Then that will start you down the rabbit hole. lol
Old 11-30-2015, 10:51 AM   #5
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
First time, just get pads, brake fluid and braided lines... once you know the car you can mess with better tires, and suspension
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
Ultramaroon (12-01-2015)
Old 11-30-2015, 02:30 PM   #6
Qwimby2
I use separate wheels with R-compound tires on the track, but I'm too lazy to swap pads every time so I need to find a dual purpose pad. Carbotech pads are the best, but should only be mounted with new rotors. I do hear that some guys have scrubbed the existing rotors with brake cleaner and have gotten away with it.
Old 11-30-2015, 04:03 PM   #7
strat61caster
Spent all year swapping XP10's in and out for autox and track with my OEM rotors, always worked great with minimal prep but they are overkill for my skills, XP8's would likely have served me just as well. Rotors still have tons of life left at 43k miles, 5x track days and a season of monthly autocrossing.
ineedyourdiddly
Old 11-30-2015, 08:34 PM   #8
Qwimby2
That's good to know that you successfully swapped the Carbotechs in and out. I like Hawk pads in general, but Hawk tells me they don't have a pad now that will work on the street and still stand up to the demands in, say, 17 and 1 at Sebring.
I've only had the BRZ a few days and have been too busy to get in back and look for possible ways to mount the shoulder harnesses for five-point belts. Some of the things I like most about the BRZ are the seats. Great bolsters and support. No need to look for other seats.
Old 11-30-2015, 11:20 PM   #9
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If your only going to do a track even once. Go as is. Just make sure your cat is in perfect running condition.
If you plan to run more than 3 times a year, I highly recommend getting a second set of wheels with sticky tires, better brake pads, a good tire pressure gauge not those $2 stick ones) and some 2x4s just so you won't use the parking brake after a hot lap. (That's how lots of people warp or explode their pads.)
Other than that just go out have fun. But more stuff if you want to. I'll rather spend more for track entry fees
Old 11-30-2015, 11:51 PM   #10
cookiesowns
Drives: WRB BRZ Series.Blue
If your on stock tires, I like the Winmax W3. Run them in my otherwise stock car. Plenty of track days ( mild ) and plenty of life left. Well over 50% after 6 track days.. ( I don't drive hard enough )
If you're on stickier EHP tires or r-comps, maybe step up to a W4 or W5. The only other pads I would try are Project Mu 999's or Club Racers.
Given the bedding squeal on Carbotechs I would never run them if you're planning on a dual purpose pad.
cookiesowns is offline   Reply With Quote
The Following User Says Thank You to cookiesowns For This Useful Post:
strat61caster (12-01-2015)
Old 12-01-2015, 01:03 AM   #11
ZionsWrath
Thanks
ZionsWrath's Avatar
Yea my XP10s sound like a freight train if I street drive them. I swap with 1521s for the street, they are silent.
If you are going to swap track pads you might as well have track wheels.
If not well I'm not sure. I don't think you can track regularly and not outgrow dual purpose pads. Unless you are just sunday driving at the track. Or use track pads on the street and deal with the noise and dust.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 12-01-2015, 07:45 AM   #12
Cartman
Cartman's Avatar
If you're switching to R-compund tires, you should get track pads... I used to fade my HC+800 on street tires... You can run hybrid pads in the rear and just switch the front pads... Switching all four tires and the front pads takes less than an hour using a jack and impact gun
I ran PMU club racers on the track this year and daily drive on stop tech pads, never replaced or cleaned my rotors when I swapped pads.
Old 12-01-2015, 01:20 PM   #13
strat61caster
Fried my OEM pads and fluid on my second ever track day, would not recommend. Sounds like OP would do the same given his experience. Doing a few laps with hard braking zones, say enough to downshift, scrubbing 20mph+ off either using ABS or threshold braking very close to the limit and they're gone, and that was OEM everything.
ineedyourdiddly
Old 12-01-2015, 01:21 PM   #14
Qwimby2
Just to clarify a bit, guys. I've been racing or running track in cars and on motorcycles for a long, long time. Probably before most on this forum were born. I've been an instructor for much of that time as well, and chief steward of a large Porsche Club region. I always run track pads and different wheels with track tires, along with a few odds and ends thrown in, like 5-point belts. I was just curious if there are certain wheel, pad and tire brands that are popular for this car. I appreciate everyone's input. It's very helpful.
CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff CruiseControl Member's Car Journals 4 07-01-2014 06:53 PM
Stuff ramiram1984 Engine, Exhaust, Bolt-Ons 13 01-04-2014 03:37 PM
JDM TRD Stuff daywheniwaschillin Scion FR-S / Toyota 86 GT86 General Forum 17 04-16-2013 06:53 PM
where is all the stuff at! youcantseeme24 Engine, Exhaust, Transmission 19 11-16-2012 10:05 PM
Help Me Get This Stuff OFF!!! wootwoot Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 09-07-2012 11:38 AM
