Old 11-21-2015, 07:06 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Back Up Camera - Reverse Wire broken what to do??
Guys, I need a wire with a female pin connector end... mine broke. I can't find it on ebay... what shall I do?
I removed the head unit,
I am trying to get a wire for my reverse to get the rear camera picture displayed when I go in reverse
I can't get the female pin connector inside the pin connector that is wired into my car.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 11-21-2015, 07:54 PM   #2
Mikeez
Engineering Student
Can someone tell me the name of this wire lol... I broke mine
Old 11-22-2015, 04:02 AM   #3
P3tras
Drives: Subaru BRZ '13 WRB
Umm, that is crimp connector. Wire should be crimped, not simply pushed in. Photo is showing it inserted correctly, it just needs to be crimped using special pliers (of course you can use bit of solder and normal pliers). Add a bit of solder, then crimp with normal pliers and then heat it up again, so solder would re-flow. Just be careful not to overdo it with solder as it might block connector.
P3tras is offline   Reply With Quote
Old 11-22-2015, 02:47 PM   #4
Mikeez
Engineering Student
I don't know the name of the things... but I did not explain correctly.
My wire came with a back up camera kit. Do not refer to the image, this is a image i searched for......
I want to connect the wire with that female pin to my pin connector in the car... it does not go in
and now my wire is cut.
Old 11-22-2015, 02:54 PM   #5
Mikeez
Engineering Student
I had the green wire (NOW it is broken) so I need a new wire like that!!!! HELP
Old 11-22-2015, 03:56 PM   #6
Heist
Heist's Avatar
Drives: 10 Series
More information on pin types on svxdc's site:
http://ae64.com/Pin_insertion_extraction.htm
Verify that you have the Type 'A' harness. That is the same one I had from the factory.
I just installed a backup camera kit. It didn't come with the correct pin (Aftermarket Type 'B'). So, a similar issue.
The one that you want for the OEM harness is available on AutoHarnessHouse. They have crimped connectors for the OEM harness. You just need to splice the wire back down to the reverse wire behind the kick panel.
http://www.autoharnesshouse.com/23416.html
Make sure you pick the OEM style one for Type A and Aftermarket Style for Type B. It seemed to work for me. Oh, and make sure you lift that latch before sticking the pin in. It won't fit in otherwise.
Heist is offline   Reply With Quote
Old 11-22-2015, 08:06 PM   #7
Mikeez
Engineering Student
So Shell type A and B are different, and I need the A? Just to confirm =p
And if I buy the one from autoharness, I must use the pin extraction tool before pushing it in the 28-pin connector to be able to clip it on?
Old 11-22-2015, 08:32 PM   #8
Heist
Heist's Avatar
Drives: 10 Series
Yes, Shell A and B are different:
http://ae64.com/images-e41/Compariso...hell_Types.jpg
Shell A is for OEM. Shell B is aftermarket.
You probably need the pin type for A. If you take a picture, we can compare.
Is the pin stuck in there? You shouldn't need the pin extraction tool unless you have the B type harness, even so, I think that a small jeweler's screwdriver will take care of it pretty easily.
Old 11-23-2015, 01:31 AM   #9
Mikeez
Engineering Student
Here
http://imgur.com/a/oNkUG
Old 11-23-2015, 02:01 AM   #10
Heist
Heist's Avatar
Drives: 10 Series
That's the Aftermarket 'B' type pin. Can you take a picture of the shell itself?
The Following User Says Thank You to Heist For This Useful Post:
Mikeez (11-23-2015)
Old 11-23-2015, 03:32 AM   #11
Mikeez
Engineering Student
The shell as in the pin connector inside the car? I will do that tomorrow morning :$
But I want to use that opportunity and thank you for helping me out . Its nice to see someone caring!
Old 11-23-2015, 03:44 PM   #12
Heist
Heist's Avatar
Drives: 10 Series
Yes, the shell as in the pin connector inside the car.
Also, you're very welcome. I had to fight with this for a while when I did it a couple weeks ago. It took a while to scrounge up all the correct information to do it properly.
Old 11-23-2015, 06:23 PM   #13
Mikeez
Engineering Student
Hehe I wish I could of went through it before and help you out! Iforgot to take the pic, but I got shell A
Old 11-23-2015, 06:35 PM   #14
Heist
Heist's Avatar
Drives: 10 Series
Shell A is OEM Style. So order the OEM Pin from Auto Harness House. It's surprising that you had an Aftermarket Pin that is supposed to only fit in Shell B crammed into the Shell A.'
So, yeah. You have Shell A. Order OEM Pin. Splice and run it to the reverse signal and you should be good to go. Don't forget to lift the latch before inserting. Mine went in pretty easily even though I bent the plastic a little.
Help: Sidemarker wire harness connector It's Jay Electronics | Audio | NAV | Infotainment 0 06-27-2015 11:51 PM
ECM Pin Connector simpleisbest Software Tuning 19 01-18-2015 03:13 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 02:13 AM
Help, what connector is this? Hayashi Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2013 02:39 AM
VSS Connector AlexTheGreek Engine, Exhaust, Transmission 15 02-02-2013 01:12 PM
