Old 08-27-2014, 07:01 PM   #239
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
Wheel Directory: Enkei RPF1 18x9.5 +38
Originally Posted by Yui-Chan View Post
So what's the widest tire you can fit with these wheels without rubbing the front stock spring perches?
I'd like 255 at least...since 245 looks too stretched and I prefer meaty beef
Also I prefer extreme perf tires....ZII, RE11a, RS3...so idk if those particular tires in 255 would fit without rubbing the perches (since all tires have different widths)
Hai!
I'm pretty sure 255 will be too wide for the stock perches. Have you looked through all the pages of this thread? I'd be surprised if this wasn't already asked and answered.
eyedeez is offline   Reply With Quote
Old 12-11-2014, 04:56 AM   #240
rv1494
Drives: 2015 Asphalt FRS
I've read through this countless times, but better safe than sorry. Just to be extra sure, I just ordered some RPF1 18x9.5 +38 and I'm most likely gonna go with a 245/35 tire. Love driving hard in the canyons and I'm on coils, will I have ANY problems? From what I've read, it's a no. But I wanna make sure
rv1494 is offline   Reply With Quote
Old 12-22-2014, 05:35 PM   #241
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
245/35/18 18x9.5 et38 ST Coilovers w/ maxed out fronts.
you should be fine.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following 2 Users Say Thank You to mmmcambelsoup For This Useful Post:
BirgeyT1 (02-10-2015), trigger happy (11-14-2015)
Old 01-22-2015, 12:59 PM   #242
rv1494
you should be fine.
Thanks man! Ended up going with 245/40/18 and I still have no clearance issues!
Old 02-10-2015, 11:43 AM   #243
mmmcambelsoup
Finally getting some legit shots.
IG: @Lucky_FatPat
The Following 4 Users Say Thank You to mmmcambelsoup For This Useful Post:
Axis2011KR (12-18-2018), Hicklinc (02-18-2018), JonAvalon (02-10-2015), mike7792 (10-28-2015)
Old 02-20-2015, 01:36 PM   #244
OkieSnuffBox
Drives: '23 BRZ Limited
What do you have covering the center holes?
Car looks fantastic by the way.
Old 03-06-2015, 09:19 AM   #245
OkieSnuffBox
Need to lower it a bit more and give it a bath, but finally got mine on with 255/35 Direzza ZII.
Old 06-24-2015, 12:17 AM   #246
pf330ci
pf330ci's Avatar
I'm seeing a lot of 18x9.5 with +38 offset. Will a 18x9.5 +35 offset fit pretty much the same?
pf330ci is offline   Reply With Quote
Old 08-07-2015, 06:04 PM   #247
fueled by hate
3mm more clearance from struts, wheels will poke out 3mm more.
235/40/18 and wider tires will rub without camber of about -2 to -3. You need coilovers with camber plates to tuck them in.
fueled by hate is offline   Reply With Quote
Old 08-24-2015, 11:16 PM   #248
einrejosh
einrejosh's Avatar
Drives: 2014 Scion FR-S
Wait, so yes, this clears 17x9.5 +38?
einrejosh is offline   Reply With Quote
Old 09-07-2015, 05:12 PM   #249
JamesssSmith
Drives: '15 BRZ
Instagram: jimmyjimmyjimmy_
JamesssSmith is offline   Reply With Quote
The Following 2 Users Say Thank You to JamesssSmith For This Useful Post:
ajaxthebetter (09-07-2015), Impureclient (10-27-2015)
Old 09-20-2015, 08:19 PM   #250
86Hiro
Okay so Ive made up my mind on the SBC 18x9.5 et38, wrapped in 255/35/18 squared. BUT.....Does anyone have this exact setup (aside from color) with Sportline springs? If so, PM me them or post them!
86Hiro is offline   Reply With Quote
Old 10-27-2015, 01:10 AM   #251
Here2rock
Drives: 86 GTS
Originally Posted by Stance86 View Post
Hi guys, here is my setup.
Enkei RPF1 18x9.5 +38 5x100 SBC lowered on Eibach Sportlines.. no coilovers, was surprised it fit.
Front tyres are 235/40/18
Rear tyres are 255/35/18
No rubbing.... could be lower I know but I do 1,000kms a week..
[/IMG]
I am new to this and just trying to grasp some of the terms here, what are "Eibach Sportlines no coilovers"?
Here2rock is offline   Reply With Quote
Old 10-27-2015, 07:22 AM   #252
JamesssSmith
Drives: '15 BRZ
His car is lowered using eibach sportline springs, instead of using coilovers
Sent from my Nexus 6 using Tapatalk
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 05:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
