Old 12-11-2012, 09:13 AM   #43
swift996
swift996's Avatar
Has anyone attempted a staggered set up? Such as a 18x8.5 or 18x9 up front with a 18x9.5 in the rear?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 12-11-2012, 09:48 AM   #44
maj75
Drives: Blue FRS 6sp, 95 M3
There are no 18x9 RPF1 in our fitment. I have not researched the 17" applications though.
The choices are 18x9.5 or 8 in 5x100. My car has the 9.5 on the back and front but I will be switching to the 8 in front on Friday. Wheels should be here late Thursday.
Will post pics in my thread on the RPF1s
maj75 is offline   Reply With Quote
Old 12-11-2012, 09:55 AM   #45
IllusiveFRS
IllusiveFRS's Avatar
Drives: 13 Scion FRS, Asphalt
17x9 are available for our vehicles, can't run 255 without coilovers. Won't clear strut perches. I have RPF1 17x9 with 255/40/17 Hankook RS3 and chose Cusco Street Zero A w Pillowball mounts to fit the wheels. Handles like a dream.
13 FRS Asphalt
Jackson Racing Supercharged, Nameless Performance front pipe with cat and helmholtz resonator, Greddy EVO3 exhaust, tuned by Church Auto Testing. Cusco braces all around, KW V3 coilovers. Winmax brake pads with DBA rotors. Thank you CSG for all the useful help!
IllusiveFRS is offline   Reply With Quote
Old 01-10-2013, 07:11 AM   #46
Stance86
Drives: Toyota 86 GTS
Enkei RPF1 18x9.5 + 38 5x100 SBC without coilovers
Hi guys, here is my setup.
Enkei RPF1 18x9.5 +38 5x100 SBC lowered on Eibach Sportlines.. no coilovers, was surprised it fit.
Front tyres are 235/40/18
Rear tyres are 255/35/18
No rubbing.... could be lower I know but I do 1,000kms a week..
Stance86 is offline   Reply With Quote
Old 01-10-2013, 07:23 AM   #47
Stance86
I'm running a 255/35/18 without coilovers on 18x9.5+38.
Old 01-10-2013, 10:04 PM   #48
sal
sal's Avatar
Drives: 16 FRS
Camber settings are probably minimal on a spring drop. Wouldn't even say -1 in the front lol.
Looks really good with just springs!
sal is offline   Reply With Quote
Old 01-11-2013, 03:14 AM   #49
Stance86
Originally Posted by AusFt86 View Post
Any rubber issue at the rear bar?
Thanks
No rubbing at all.
Old 01-11-2013, 06:27 PM   #50
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
With 18x9.5 RPF1s +38 all around what size tires are recommended if I'd like to retain the ability to rotate? 245's based off this thread looks like it.... right?
Also, how would one go about special ordering a wheel in that size at 5x100?
Chewie4299 is offline   Reply With Quote
Old 01-12-2013, 08:01 PM   #51
PRORICAN
PRORICAN's Avatar
Correct me if I am wrong, but 255 won't fit up front without coilovers because they hit the factory spring perch. At least it did on my 17x9 with 255/40/17. Maybe different in 18 due to radius of bead sitting at a different position.
Your ride looks sicc sicc sicc! Keep it up. :beer:
I want to know if 255's fit up front with 18's aswell! I'll probably go with 245's but if I can fit a bigger tire ill go that route.
PRORICAN is offline   Reply With Quote
Old 01-12-2013, 08:14 PM   #52
PRORICAN
PRORICAN's Avatar
Originally Posted by OmarGC View Post
Why so much weight?
Ill be going turbo+e85 later with a goal of 400whp so I would like the added grip for one. Two I'm putting them on 9.5" rims (lighter than stock) and anything less than a 255 will look stretched. Lastly meaty tires just look better. It will be my street setup so for the track ill have 17's and save more weight.
Old 01-12-2013, 08:22 PM   #53
PRORICAN
PRORICAN's Avatar
Also Jesse from JDLautodesign posted this...
Originally Posted by Jesse@JDLAutodesign View Post
I let a buddy who's a fast driver take my stock FRS out to Chuckwalla raceway last month..ran it 100% bone stock, swapped on some 18x9.5's with 265/35/18 tires (nothing special, non r compound, just basic street tires) that a friend had laying around. Went 8 seconds faster a lap. They were very heavy Rota's too. I've been involved with some fast time attack teams, all running square setups on RWD cars..
Apparently the extra weight didn't hurt him at all
Old 01-12-2013, 08:23 PM   #54
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Think tire compound would be the main focus over the overall width...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-12-2013, 08:33 PM   #55
PRORICAN
PRORICAN's Avatar
A little bit of both I would assume. But since it'll be my street setup I won't be running sticky r-compounds or anything like that. Ill run something smaller with sticky tires on the track.
Old 01-24-2013, 03:20 AM   #56
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Picked them up today. Fitting next week with Cusco coil overs
Tyres are Pirelli P ZERO ROSSO Asimmetrico 245/35/ZR18
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
