Old 10-08-2015, 11:26 PM   #15
15limited
15limited's Avatar
I turn them all off, hold traction control button down for 5 seconds, first thing after I start up the car every time. I live in the Pacific NW, and granted just getting the car earlier this summer, I haven't had it in the rain very much yet but simple throttle control keeps this car exactly where you want it until you tell it otherwise. Haven't hydroplaned yet tho, that might change things up a bit.
Sent from my 831C using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 10-09-2015, 05:44 AM   #16
humdizzle
Drives: 2018 GT3 / 2015 M3
i turn them all off as soon as i start the car. the vsc sport still interferes too much for me.
Plus you never know when there will be an opportune drift moment and you can't spare 5 sec to turn off the systems.
2018 GT3 6MT
2021 M2 Comp DCT
Past: 458 Italia, R35 GTR, E36/E46/F80 M3, 335i, Scion FRS
humdizzle is offline   Reply With Quote
The Following User Says Thank You to humdizzle For This Useful Post:
jonnyfrank (10-09-2015)
Old 10-09-2015, 11:23 AM   #17
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by Toyarzee View Post
wait wait wait
wtf?
Is that something like if you take it in with a blown motor and the thing was in diagnostic mode RECENTLY they'll use it as leverage; or is it a once used and eff you?
I read somewhere that a dealership denied warranty due to the "pedal dance" Ill try to find that read.
Instagram: trevor.parque
Toyarzee (10-09-2015)
Old 10-09-2015, 02:03 PM   #18
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Please do...
Toyarzee is offline   Reply With Quote
Old 10-09-2015, 02:15 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Hold Trac button= no traction nor stability control. Use for mad drifts and all the burnouts. It will not save you. Proceed with caution.
Pedal dance turns off all aid 100% NOT FOR STREET USE!= for the track junkies that have the frs as their track car and do not plan to take it to the dealership because dealer can track when you go into this mode.
Fixed.
Hold trac button = will not allow you to drift properly, as it still kicks in when the car rotates excessively.
As for pedal dance = dealer issues, that is pure BS unless you are trying to warranty clutch, tires, differential, axle, or other engine issues that may be associated with car abuse.
Pedal dance or not, that is a DIAGNOSTIC MODE for a service tech to road test a car.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
B T (03-10-2016), Toyarzee (10-09-2015)
Old 10-09-2015, 03:00 PM   #20
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You know I've heard a few people echo this but I'm not 100% onboard, in my experience the trac-hold will not save you from a spin, should not affect drifting unless the EBD affecting brake bias is too disruptive with the trail braking required.
Seemed like CSG's testing pointed to the trail braking and lifting a wheel being the two cases where the trac-hold stepped in, shouldn't be any wheel lift while drifting.
ineedyourdiddly
Tcoat (10-09-2015)
Old 10-09-2015, 03:18 PM   #21
mav1178
mav1178's Avatar
Holding down trac button prevented me from doing simple figure 8s on a wetted skidpad about a year ago.
-alex
strat61caster (10-09-2015)
Old 10-09-2015, 03:29 PM   #22
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I leave all the nannies on when I do aggressive canyon carving and I still have a great time. *shrug*
Leaving it all on (no buttons pressed)= normal driver
VSC Sport button= driver who is not entirely experienced but wants to drive through a canyon road aggresively yet safely.
Originally Posted by humfrz
I'm old and lazy
Old 10-09-2015, 03:31 PM   #23
Toyarzee
Shibby!
Toyarzee's Avatar
I've run into issues with 5 sec trac off as well for some maneuvers. I'm starting to get annoyed enough to look into that box that replaces the need to do the whole pedal dance out of laziness
Old 10-09-2015, 04:33 PM   #24
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by kch View Post
yeah, it's using the ABS to stop wheelspin rather than limiting power. it sounds pretty terrible.
I'd rather hear the ABS kick in than the sound of my wheel slamming into a curb
Now THAT would be a much worse sound!
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
MisterSheep (10-09-2015)
Old 10-09-2015, 05:32 PM   #25
BRZ_Prague
BRZ_Prague's Avatar
Drives: 2015 Subaru BRZ Sport
I've read somewhere, that when car is not fully warmed up it will save you even with TRC fully off.
BRZ_Prague is offline   Reply With Quote
Old 10-10-2015, 07:31 AM   #26
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
That box is pretty awesome, especially for trackers.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 10-10-2015, 02:30 PM   #27
dalli
dalli's Avatar
Drives: Toyota
Even if you leave all controls on(no buttons pressed), you can still slide the rear out. Well i can on my brz and its pretty fun, esp in the rain
dalli is offline   Reply With Quote
Old 10-11-2015, 02:03 AM   #28
Chanpion
Drives: 13 FRS Satin
If you live up in the north:
I personally keep in is VSC sport the whole time. But disable your traction control when you leave the line, only way to get moving in the snow/ ice.
Basically, press right button when you get in car. Hold both down for a few seconds for track. Press just the left one for snow/ ice. The left button will disable or switch it back to normal after a few seconds/ over 50kmh.
I try to keep them off at all times. The car communicates so well, doesn't snap or anything.
Chanpion is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction control help carmen.atil Scion FR-S / Toyota 86 GT86 General Forum 4 12-15-2014 12:14 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
