Old 10-08-2015, 02:16 PM   #1
jonnyfrank
Traction control tips
So I am new to the different traction modes in the modern day cars. My 2016 BRZ has them, and I need a short user tutorial from the forum members. Any tips or ideas on how and when to use the different modes and what I will experience? Does one mode allow for more drifting while another allows for a "smoother" ride. Yes, I will read the manual and google some other sites, but I feel like we are a fraternity here, so I am throwing this out there.
Keep in mind I am (a young) 53, but I have those teenage boys who will be learning how to drive a stick with this car. Any and all advice would be appreciated.
Thank you in advance.
jonnyfrank is offline   Reply With Quote
The Following User Says Thank You to jonnyfrank For This Useful Post:
Tcoat (10-08-2015)
Old 10-08-2015, 02:22 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Leaving it all on (no buttons pressed) = safest and like a normal car
VSC Sport button lets the tail slide a bit but will still save you
1 press of Trac will let tires spin a bit till a set speed then turns back on
Hold Trac button turns off all aids for the most part (use this to drift ect.)
Pedal dance turns off all aid 100% NOT FOR STREET USE!!!
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
jonnyfrank (10-08-2015), Tcoat (10-08-2015)
Old 10-08-2015, 02:29 PM   #3
If an auto it also has snow mode which starts you out in 2nd and smooth's out the shifts for more stability in ice and snow.
All setting address traction control only so there is no difference in ride.
Old 10-08-2015, 02:51 PM   #4
JS + BRZ
Drives: 2010 MS3
Normal mode = Street
VSC Sport = Canyon
Pedal Dance = Track
JS + BRZ is offline   Reply With Quote
The Following 8 Users Say Thank You to JS + BRZ For This Useful Post:
AZP Installs (10-08-2015), calmtigers (10-08-2015), jonnyfrank (10-08-2015), MisterSheep (10-08-2015), RL_BRZ (10-08-2015), soulreapersteve (10-08-2015), Tcoat (10-08-2015), Xiijuwa (11-09-2015)
Old 10-08-2015, 02:52 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
VSC Sport = Canyon
Pedal Dance = Track
Yup thats about right! I run VSC sport on 100% of the time TBH
Old 10-08-2015, 02:52 PM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Leaving it all on (no buttons pressed)= normal driver
VSC Sport button= driver who is not entirely experienced but wants to drive through a canyon road aggresively yet safely.
1 press of Trac = for all those times you "think" traction control is off yet you try to burnout anyways to impress all your immature friends.
Hold Trac button= no traction nor stability control. Use for mad drifts and all the burnouts. It will not save you. Proceed with caution.
Pedal dance turns off all aid 100% NOT FOR STREET USE!= for the track junkies that have the frs as their track car and do not plan to take it to the dealership because dealer can track when you go into this mode.
Fixed.
Instagram: trevor.parque
The Following 4 Users Say Thank You to MisterSheep For This Useful Post:
go_a_way1 (10-08-2015), jonnyfrank (10-08-2015), RL_BRZ (10-08-2015), shifter907 (10-08-2015)
Old 10-08-2015, 02:58 PM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I tend to turn of traction control a lot. VSC Sport seems to interfere occasionally when I have a hard shift, or push it a bit. I do, however, use this mode in the rain when I want minimal surprises.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
jonnyfrank (10-08-2015), perryair (10-08-2015)
Old 10-08-2015, 03:02 PM   #8
strat61caster
strat61caster's Avatar
TC buttons only change how much computers 'let you slide' no smoothness implied, it either rights you immediately, soonish, or almost not at all.
3 button presses deomonstrated in this video:
[ame="https://www.youtube.com/watch?v=j8qggahGNH0"]Toyota 86 Traction Control Demonstration [SKIDPAD] - YouTube[/ame]
IMO:
All on: public roads 99% of the time
'Sport': occasional street use, when scouting a new track
Off: HPDE/AutoX only
Edit: Pedal Dance, going to try it out for the first time in two weeks...
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
Jfheisenberg (10-08-2015), jonnyfrank (10-08-2015), MisterSheep (10-08-2015), RL_BRZ (10-08-2015), soulreapersteve (10-08-2015)
Old 10-08-2015, 08:42 PM   #9
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I drive in Sport nearly exclusively when it's dry out. It'll let you get a little bit of rotation before it kicks in, and I appreciate that.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Old 10-08-2015, 08:53 PM   #10
This was in with the video Strat linked. Tells the story very well.
Grim-Reaper (10-09-2015), jonnyfrank (10-08-2015)
Old 10-08-2015, 08:56 PM   #11
jonnyfrank
That traction control makes an ugly sound....tried all versions today except for pedal dance.....put 52 miles on my car and let my 15 year old drive it....he actually did well with the clutch. I love this car. Getting windows tinted and paint protected on Tuesday.
Thanks, BRZ fraternity
The Following 4 Users Say Thank You to jonnyfrank For This Useful Post:
jawn (10-08-2015), JS + BRZ (10-09-2015), Tcoat (10-08-2015), Toyarzee (10-08-2015)
Old 10-08-2015, 09:29 PM   #12
kch
Senior Misanthrope
kch's Avatar
yeah, it's using the ABS to stop wheelspin rather than limiting power. it sounds pretty terrible.
Old 10-08-2015, 09:36 PM   #13
perryair
junior mafia
Drives: ‘20 sti limited
you can't even chirp gears in vsc sport without the traction control kicking in. even with he one press traction off, traction control kicks in a lot when you're driving spiritedly. I used to drive a very tail happy mustang gt stick for quite a few years so I'm comfortable with the kind of driving that you do with tc held off. (though in rain I won't even mess with vsc sport, give me all the traction you can - hydro planing is just about the least fun thing that you can encounter)
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
The Following User Says Thank You to perryair For This Useful Post:
Old 10-08-2015, 09:53 PM   #14
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Pedal dance turns off all aid 100% NOT FOR STREET USE!= [COLOR=red]for the track junkies that have the frs as their track car and do not plan to take it to the dealership because dealer can track when you go into this mode.
wait wait wait
wtf?
honestly, I drive with this thing in vsc sport everywhere, hold trac for 5 sec in canyon, and pedal dance at race track. But this tracking when you do pedal dance is something i haven't read anywhere yet.
Is that something like if you take it in with a blown motor and the thing was in diagnostic mode RECENTLY they'll use it as leverage; or is it a once used and eff you?
Back on track, I find the intrusive nannies to be quite relevant on the regular street and recommend keeping in normal mode for the avg driver... if there is such a thing these days
Toyarzee is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction control help carmen.atil Scion FR-S / Toyota 86 GT86 General Forum 4 12-15-2014 11:14 AM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
