Old 09-28-2015, 03:45 AM   #1
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Just had an "OH SHIT" moment
So I had plugged the bottom portion of my inlet hose with a PVC cap and crimped. Recently, I was under the impression that it had fallen out since I was getting lean conditions (due to a hole in the intake system post-maf
I naturally plug the hole with a rubber slightly tapered plug that would adhere better to the rubber of the inlet hose. @Ultramaroon helped me fasten.
HOWEVER.... Today on my way home from getting dinner with my gf, I gave it WOT around a corner and got a check engine light and the car went into limp mode. I pulled over and plugged my tablet into the OBD2 port to see what as up.
It was throwing primarily this code: P2109 code. Dealing with the throttle body.
I ended up taking off my inlet hose and this is what I find....... LOL FUCK ME
This piece that I was using to be a stopper for one of the resonator spots had been sucked into the inlet hose, however, it was JUST big enough to not be sucked into the engine unless I was giving it 100% throttle, at which point it got wedged.... scared me shitless lol
Nothing else to this post, just sharing my horror story and the good that came of it!
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
raven1231 (09-28-2015)
Old 09-28-2015, 04:14 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
In hindsight it would've been safer to have a cap that goes OVER not inside the hole
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
RobertPaulson (09-28-2015), Wayno (09-29-2015)
Old 09-28-2015, 04:33 AM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
That sounds inappropriate. Also, you are right.
The Following 12 Users Say Thank You to EAGLE5 For This Useful Post:
BCTV93 (09-28-2015), cdrazic93 (09-30-2015), DustinS (09-28-2015), FRSBRZGT86FAN (09-28-2015), JEDI (09-28-2015), JonAvalon (09-28-2015), Packofcrows (09-28-2015), ScoobsMcGee (09-28-2015), SlammedSilly (09-28-2015), soulreapersteve (09-28-2015), Sportsguy83 (09-28-2015), Ultramaroon (09-28-2015)
Old 09-28-2015, 01:40 PM   #4
Uggh... I asked you if you were sure it didn't get sucked in.
Now I think you understand why I insist we cut down the bigger stopper we bought so it has a shoulder and then clamp that in place. I still have it.
That was damn lucky; once-in-a-lifetime lucky.
Old 09-28-2015, 02:08 PM   #5
86Hiro
That even had me gasping when I read this....Lucky Lucky! That would've been customer neglect and out of your pocket!
86Hiro is offline   Reply With Quote
Old 09-28-2015, 02:23 PM   #6
adamg
Drives: brz
Same situation happened to a friend of mine. Im seeing way to many people capping off this section and risking the cap getting sucked into the engine. sketch
adamg is offline   Reply With Quote
Old 09-28-2015, 02:25 PM   #7
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Least it wasnt a sock or cloth like on the Honda forums.
Old 09-28-2015, 04:13 PM   #8
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Seriously?? A sock?
The Twins make me smile
Old 09-28-2015, 04:36 PM   #9
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
thats crazy... You sir are also lucky.
Instagram: trevor.parque
Old 09-28-2015, 04:43 PM   #10
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
WOW! When I did this on the stock inlet tube I used a hard plastic PVC cap with a big hefty lip.
That's crazy!
Glad the Mishimoto inlet I have now gets rid of this.
JazzleSAURUS is offline   Reply With Quote
Old 09-28-2015, 05:10 PM   #11
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
I lol'd
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 09-28-2015, 07:14 PM   #12
aynickay
aynickay's Avatar
Drives: '15 FR-S
Definitely an oh shit moment thats for sure
aynickay is offline   Reply With Quote
Old 09-28-2015, 07:23 PM   #13
Is it irony that your engine could blow by sucking?
The Following 13 Users Say Thank You to Tcoat For This Useful Post:
adamg (09-30-2015), Aztec (09-28-2015), cdrazic93 (09-30-2015), chaoskaze (09-28-2015), Hoahao (09-28-2015), JEDI (09-28-2015), Joyride86 (09-28-2015), new2subaru (09-28-2015), PWBRZ (09-28-2015), RallybluBrz (10-06-2015), soulreapersteve (09-28-2015), Toyarzee (09-30-2015), Ultramaroon (09-28-2015)
Old 09-28-2015, 07:46 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
OHHHHHH SHIIIT XD
You should be thankful that u didn't get That shiny big throttle body kit
Tigermack's SCCA STX BRZ tigermack Member's Car Journals 70 01-15-2020 06:52 PM
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 11:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
