Old 09-22-2015, 01:28 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Let me ask my question again:
What makes you think using a wheel with 14mm lug holes is a safety issue on a car with 12mm studs? Let's assume large-enough lug nuts were used and it is torqued down to manufacturer's spec without an impact gun.
Let's also assume the following:
- wheels have 60 degree lug seat
- lugs have 60 degree taper
- lugs are large enough to center the wheel properly on the lug seat
- wheels have hub-centric rings
- torqued down by hand
What about this setup is unsafe?
-alex
Old 09-22-2015, 01:51 PM   #16
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
M14 wheels on M12 studs
-alex
Uhm the part where they didn't change the studs to M14......
Sent from my toolbox
86kahl is offline   Reply With Quote
Old 09-22-2015, 02:29 PM   #17
mav1178
mav1178's Avatar
Originally Posted by 86kahl View Post
Uhm the part where you didn't change the studs to M14......
Since you know about the subject, mind telling us why it is bad?
Old 09-22-2015, 03:24 PM   #18
86kahl
86kahl's Avatar
I never said it was bad.
I never said it wasn't possible.
It. Is. Not. Safe.
The only safe options imo based solely on my experience is;
1) wheels matching M12
2)changing stud/hubs to match M14
I do not trust aftermarket lug nuts, self centering lugs, spacers, or any other tricks used to make wheels fit. Some people do and for some it works out, I just gave one example of someone it didn't work out for and I'd rather not chance safety.
Old 09-22-2015, 04:48 PM   #19
mav1178
mav1178's Avatar
So... what is the difference between stock 60 degree tapered lug nuts, and aftermarket lug nuts like Kics R26? Or Gorilla? Or something cheap you buy from Autozone?
And you do realize that the factory lug nuts are basically self-centering, right?
-alex
Old 09-22-2015, 11:44 PM   #20
86kahl
86kahl's Avatar
Factory lug nuts are not the same as self-centering lugs.
Like I said before there are people (and businesses) that trust aftermarket solutions for picking the wrong wheels but I am not one of them. We're talking about safety and the safest thing would be to start with M12 sized wheels imo.
Old 09-23-2015, 11:18 AM   #21
mav1178
mav1178's Avatar
So what is the difference between a self-centering lug nut and the factory lug nut?
Old 09-23-2015, 11:41 AM   #22
86kahl
86kahl's Avatar
One is safe and the other is a shoddy attempt to center wheels with the wrong stud bore😪
It's like arguing for the use of daytons imo😂
Old 09-23-2015, 11:44 AM   #23
mav1178
mav1178's Avatar
You do realize that any lug nut with a tapered lug seat is a self-centering lug nut, right?
That's what I am getting at... it is NOT unsafe if large enough lug nuts are used.
Old 09-23-2015, 11:54 AM   #24
86kahl
86kahl's Avatar
I think you might have the terms confused. Tapered lug nuts are not the same as self centering.
Self centering have a little shank that goes deeper than the actual lug to keep bore in place, typically seen with a washer attached.
Okay I think an agreement can be reached before this thread goes on for 10+ pages.
It is not UNSAFE to use the proper aftermarket lugs with M14 wheels on M12studs
But starting with an M12 wheel is a SAFER set up when using factory lugs on M12studs
Old 09-25-2015, 05:07 AM   #25
Varelco
Drives: '15 GT86 & '22 GR86
Reigniting this thread as I just made one for the same thing because I didn't search properly...
86Kahl what is it exactly that makes it unsafe? My understanding is that the hole in a wheel whether its M12 or M14 is a clearance hole and has nothing to do with securing the wheel to the hub. The tapered face is what holds the wheel on with the centre bore used to centralise the wheel. From what I can see you lose 2mm of taper face with a M14 hole over an M12, so if using a regular wheel nut you're losing surface area to bolt up to (which I can see as unsafe). However if you compensate with a larger nut (like 21mm) you recover that loss of surface area and therefore you are back to square one, its all good.
Varelco is offline   Reply With Quote
Old 09-25-2015, 07:12 AM   #26
Dihudaxia
Drives: 86
Woah!
Didn't mean to start a debate.
But good points from both sides.
Still confused though.
I emailed Yokohama (maker of Advan wheels), hopefully they bother to reply me. Will update here once they respond to my emails.
Dihudaxia is offline   Reply With Quote
Old 09-25-2015, 08:16 AM   #27
Varelco
Not Models 5s by any chance?
Old 09-25-2015, 11:24 AM   #28
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I really don't get why people would add possible failure point to their cars, will it fuck up if you do what the OP wants to? probably not, but there are a number of cases (improper install, other shop not knowing this was done, etc.) that could cause problems, failures or people getting hurt down the line.
Whether or not it bound to happen at 99% certainty is not the issue here mav, the issue is that there IS a higher probability of failure than oem recommended specs. Tell me this why would you ever recommend something with a higher chance of failure (don't care if it's only 5-10% more likely to fail, it is more likely to fail and again not necessarily due to product itself but anyone who works with them).
Is it safe? probably. Should you do it from a probability/statistical perspective? no as you are increasing the odds for failure. Now OP figure out what is more important to you, the wheels you want or knowing that the probability of failure for your wheels and hubs is at the lowest value it could be.
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
86kahl (09-25-2015)
I keep breaking lug studs!!! Guff Issues | Warranty | Recalls / TSB 59 12-30-2015 12:34 AM
ARP Wheel Studs FR-S Matt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-09-2015 06:50 PM
Brand New ARP wheels studs part number 100-7716 Gen3MR2 Wheels and Tires 3 09-21-2015 03:44 PM
At what point do we need to upgrade head studs and main studs? Amir Ghadiri Forced Induction 5 03-03-2015 11:13 AM
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 11:29 AM
