Old 09-14-2015, 11:28 PM   #1
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
Alignment Issues after Lowering Springs
Here's the story, I recently purchased this at the end of July. 2 weeks ago I had the Eibach Pro Kit installed and went to get an alignment today at the Toyota Dealership where I purchased my car.
They said they couldn't align it because they don't have the kit for my car??
I asked what kit and I forgot what he replied with because I was so confused why Toyota couldn't align their own car.
Here's the print out they gave me after the test, and I'm confused. Do I need control arms for the rear? I picked my car up at 6pm so every other shop was closed and I'll be trying again tomorrow, I might go to Subaru maybe?
Any locals in San Diego know of any good alignment places where they could fix this when Toyota couldn't?
I'm just confused! Any help would be much appreciated thank you!
Roneezy is offline   Reply With Quote
Old 09-14-2015, 11:50 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Purchase the front crash bolts,
Take it to a different shop, one that will work with you,
Tell them to max the front camber,
zero toe getting and rear.
Enjoy.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
Roneezy (09-14-2015)
Old 09-14-2015, 11:59 PM   #3
swarb
Read more about alignments on this car.
Stock does not have adjustable camber. If you want to adjust camber, you need camber bolts or camber plates up front, and lower control arms in the rear.
Stock alignment specs are for tire life and not for handling.
Any alignment shop can do an alignment.
I would personally get one or two sets of camber bolts up front, add camber(get an alignment) until its the same or more than the rear and just drive it. And then figure out what kind of alignment you want.
The Following User Says Thank You to swarb For This Useful Post:
Roneezy (09-15-2015)
Old 09-15-2015, 12:01 AM   #4
Roneezy
Roneezy's Avatar
Enjoy.
I'll purchase the SPC Camber Bolts and try to find a performance shop here in San Diego.
So with an alignment, the rear camber will get fixed without the need of a lower control arm? Sorry, just confused to how my rear camber will get fixed since to my knowledge there's no way of adjusting the camber in the back without these.
Thank you for the advice though, I'll try it!
Old 09-15-2015, 12:07 AM   #5
Roneezy
Roneezy's Avatar
Yeah I knew that the car wasn't adjustable in the front and rear unless I had crash bolts or the lower control arm. I just find it odd that Toyota couldn't do it, but I guess I'll be purchasing front bolts.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Old 09-15-2015, 12:26 AM   #6
swarb
Slow your roll.
Stock alignment is for long life tire wear.
Sporty/Track alignment is on the opposite end with more camber and less toe in the front and rear. Adding more camber in the front would make your overall alignment more track oriented. (instead of stockish front and trackish rear, which it currently is at)
Why is it odd that toyota couldn't do it? It's not adjustable to begin with and you have aftermarket springs.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Roneezy (09-15-2015), wparsons (09-19-2015)
Old 09-15-2015, 12:56 AM   #7
Roneezy
Roneezy's Avatar
Slow your roll.
So you're telling me they couldn't fix the toes of my car due to it not being adjustable? To my basic knowledge of cars I at least know that Toyota would've been able to fix the toes up front to the very least correct?
Camber in the front isn't an issue according to this diagnostic, only camber problem seems to be the right rear.
I really don't understand how Toyota couldn't fix the toes in the front. I know you seem very knowledgeable but you're only talking about camber. You aren't really helping fix the main issue here which is the front toes.
Old 09-15-2015, 01:04 AM   #8
swarb
Toe is adjustable.
Did you pay?
And after they fixed the toe, the rear right camber would have been off, which is a red flag for alignment(for Toyota). Do it right or don't do it at all.
You would have paid, then driven, and noticed it not drive right, then complain and take it back only to be told they can't adjust it. Only to ask for a refund etc etc... not worth the headache.
Old 09-15-2015, 01:10 AM   #9
Roneezy
Roneezy's Avatar
Toe is adjustable.
Did you pay?
No they just gave me my keys back lol.
The guy kindly pointed me out to some shops down the street, but it was the afternoon and most of the shops were closed so I'll just wait until I get the crash bolts and try again sometime this week.
Yeah you're right about that though, he saved me the headache by just not doing it at all. I guess I'll have to wait until my crash bolts come. I'm going to order some SPC adjustable control arms and get the camber fixed while I'm at this so I don't have to deal with this later down the line.
Thanks for the help.
Old 09-15-2015, 05:00 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Wow you should thank that tech for not charging and pointing you in the right direction. Most dealers and volume shops will just toe and go.
Rear camber is not adjustable stock and most cars vary left to right. If you just street drive its probably fine. Buy the $20 bolts, Max out front camber. Fix the toe to your liking and that's that.
I started that way. Toe out front toe in rear. It was good but I moved up to raceseng camber plates and SPL rear LCA. That's about 1000$ though and 120$ for a custom alignment at a good shop. That may be more than you want to spend but there are a lot of options in between.
I track my car so for me and my $ it was worth it. What do you intend to do with your car?
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
Roneezy (09-15-2015), strat61caster (09-15-2015)
Old 09-15-2015, 10:03 AM   #11
Roneezy
Roneezy's Avatar
Yeah I now realize I'm pretty lucky for them to not touch the car. My car is mostly just a daily, I also like to go to some curvy roads and do some spirited driving here and there but thats about it. It will never see the track.
Old 09-15-2015, 02:55 PM   #12
Roneezy
Roneezy's Avatar
Well I ordered SPC Rear Lower Control Arms and SPC Camber Bolts.
I'll post my new alignment when that gets taken care of sometime this week.
Old 09-18-2015, 11:58 PM   #13
Roneezy
Roneezy's Avatar
I'll finally get my alignment on Monday since I just received my camber bolts and my control arms.
I've been browsing through the forums and found that people recommend -3 camber in the front and -2 in the rear with 0 toes for front and rear.
Does this sound good? I'll be telling them to align to these specs on Monday if these are good, or if anyone has some good recommendations I'd appreciate the help thank you.
Old 09-19-2015, 12:50 AM   #14
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Are you going to be on the track or autox every weekend and not daily drive your car? If not and just daily driving, just stick to stock specs. Ride would be better and tires will last longer.
Unless you want to be cool like the stance nation or hellaflush guys, cause you need all that camber for extra grip while parking hard bro. /sarcasm
Lowering and Alignment Question DieselDog Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-24-2015 12:40 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
For anyone not getting an alignment after lowering... wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-16-2014 12:13 AM
Alignment After Lowering mjsivee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 12:12 PM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 03:57 PM
