#309 |
Drives: Toyota 86 GTS
Updated OP
| The Following 5 Users Say Thank You to Wayno For This Useful Post: | cawith (09-14-2015), chickencornsoup (09-13-2015), ollie (09-13-2015), phrosty (09-13-2015), steve99 (09-13-2015) |
#310 |
Drives: GT86
Hey Wayno thanks very much for your continued hard work. Also just wanted to check what headers are you running. Thanks champ
#311 |
PSR, functionally and quality equivalent to Gruppe-S and Tomei.
| The Following User Says Thank You to Wayno For This Useful Post: | ollie (09-14-2015) |
#312 |
Drives: GT86
Awesome thanks, where did you get them from?
#313 |
PSR. They're in NSW.
#314 |
Drives: GT86
#315 | |
I've no idea mate. At the least make sure you run a stock catted front pipe or after market catted front pipe with them. http://www.prospeedracing.com.au/pro...t-coating.html |
#316 |
Drives: GT86
Thanks champ, yeah I am running the stock chatted front pipe after reading @steve99 post no need to change it as it does not really help with performance and can be to loud if you have a catless header.
Sent from my iPad using Tapatalk |
#317 |
Drives: GT86
Hey Wayno!
I'm currently taking a glance at the changes in the new v86 rom. Is it intended that nearly half of the diagnostic sensors are disabled? |
#318 |
Drives: Toyota GT86
I noticed this also and I compared it with a complete stock rom, the only difference between the stock and the stg2 rom I used was:
P0420 Cat efficiency (because no more cat in the header) U0155 Lost comm (sometimes OFT could create this problem) All the others are on and off just like stock
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#319 |
Drives: Toyota GT86 6M/T
Thanks for the update!
Just adopting the changes to my A00G right now, but have a question: Engine Load Limiter B Maximum and Engine Load Limiter C Maximum are both different for EL/UEL and MT/AT, right? Should I stick with those tables from your v85? I noticed a slight difference in the axis from A01I to A00G on the E85 tune but a big difference on the 98 tune. I'm running catless UEL btw. |
| The Following User Says Thank You to cawith For This Useful Post: | Chimera (09-14-2015) |
#320 |
They're only different between el and uel now. AT and MT are consistent.
| The Following User Says Thank You to Wayno For This Useful Post: | cawith (09-14-2015) |
#321 |
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 09:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 10:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 12:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 05:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 04:26 PM |
