Old 09-01-2015, 11:53 PM   #1
Wyattkb
Drives: 2014 Whiteout FRS
Vibrations After Spacer Install
This weekend I installed my RCE yellows and 20/25mm spacers.
I drove the car to work today and anything over 70mph creates quite noticeable vibrations, especially in the steering wheel. Once I hit 80 the vibrations become much more severe making my passenger seat bounce back and forth.
The spacers are the V3 spacers from corner garage. Anyone have any input on what to check or what could be causing this?
Sent from my SM-G900V using Tapatalk
Wyattkb is offline   Reply With Quote
Old 09-02-2015, 12:06 AM   #2
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Alignment? Usually needed after lowering. + I'm sure the spacers didn't help if you didn't get an alignment.
Rifle is offline   Reply With Quote
Old 09-02-2015, 12:35 AM   #3
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Check your factory studs.
They might be too long that contact your rims (also depends one what rims you have). So that your wheels can not be installed correctly. There will be a gap between wheel and rotor because the factory studs push the wheels outward.
If everything is good, re-install everything to make sure that they are installed and torqued properly.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-02-2015, 02:25 AM   #4
jc0522
Drives: 2014 BRZ
I assume you're using the spacers to push out the stock wheels? If so...if you're using the nuts/bolts that comes with our cars....it might not be sufficient.
I think I actually received one of the first batches of the newly designed V3 spacers at corner3. When they were installing it, the tech noticed that the spacer studs were too long for the stock nuts to be used. So we fixed that problem by using Muteki extended closed lug nuts. It's been 10k miles since I been running the spacers, no issues whatsoever.
jc0522 is offline   Reply With Quote
Old 09-02-2015, 11:16 AM   #5
8R6
8R6's Avatar
Drives: FRS
which wheels are you on?
8R6 is offline   Reply With Quote
Old 09-02-2015, 06:51 PM   #6
Wyattkb
So I got a chance to check it today. The back wheels contact the spacer and hub perfectly, but the front looks like the wheel is not contacting the spacer fully.
I have the Blue Series STI wheels. I will have to wait until Saturday to pull them off and see whats contacting to prevent a flush mounting point. I am using the lugs it came with which are open ended generic lugs.
The front are 20mm spacers too.
Old 09-02-2015, 06:59 PM   #7
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Would not drive without the wheel/spacer/hub all sitting flush and suggest to remove spacers until you can remedy.
There may not sufficient room behind the wheel where the original studs are coming into contact with the wheel.
asdf is offline   Reply With Quote
Old 09-02-2015, 07:03 PM   #8
Wyattkb
I am not going to drive it until I fix it. I will post results this weekend in case anyone else runs into this.
Old 09-04-2015, 04:41 PM   #9
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
I literally just bought this setup yesterday but with the H&R Trak spacers, so I'm very interested to hear what is causing your issue. Did you get an alignment after the install?
avishenoy1 is offline   Reply With Quote
Old 09-04-2015, 05:54 PM   #10
Porcupint
Drives: 13 GBS BRZ
Sounds like you may have cross threaded a lug nut or not tightened them down completely.
Porcupint is offline   Reply With Quote
Old 09-06-2015, 01:56 AM   #11
Wyattkb
Alright well I found the culprit.
The front spacer lugs are not seating into the spaces on the back of the wheel. I don't know if its a matter of getting different lugs or spacers. Here are the some pictures to help you understand, you can see where the lug nut was pressing into the back of the wheel. Anyone have some input?
Old 09-06-2015, 02:04 AM   #12
Wyattkb
After looking on the manufacturers website I noticed it says "will not fit STI models" I guess I overlooked that not thinking about how I have the blue series STI wheels.
If you look at the picture of the OEM wheel it has much larger recesses and the spacer + lug does in fact fit.
So anyone know what bolt on spacer I can use with my blue series wheels? A quick google search and someone said the only ones that fit for 20mm are H&R and B2Designs, can anyone confirm this?
Old 09-06-2015, 02:07 AM   #13
swarb
A couple options.
1. add another spacer. 5mm or so. sandwich it between the bolt on spacer and rotor.
2. find a shorter lug nut.
3. machine down the hole on the spacer which the lug nut sits on a few mm.
I would do #1 or try to return the 20mm, order another pair or 25 or 30mm(and put the 25 you have on the rear on the front). Too many spacers makes it look really sketchy/unsafe.
Old 09-06-2015, 02:15 AM   #14
Wyattkb
I think I am going to purchase the 20mm from b2designs and just sell the set I have.
So if anyone needs 20mm spacers I will hook it up cheap.
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
Anyone having problems with vibrations? ShibaYuki CANADA 22 01-21-2014 09:06 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
Rattles & Vibrations brian_c_m AFRICA 65 03-22-2013 03:07 PM
