Old 08-19-2015, 06:51 PM   #1
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
TESTED- Perrin Master Cylinder Brace
We had a spare analog input, a spare shock pot, a Perrin master cylinder brace, and some time to kill. Let's find out if it actually works!
First thing we did was mount a shock pot horizontally in line with the master cylinder:
Interestingly enough, we had marginal deflection. On the order of a few thousandths of an inch. Watching it, we noticed the master cylinder was actually deflecting upwards, not forward like you'd think. It rotates around a point on the firewall, roughly, so that the end is pushed upwards. So we got a little creative with some machining measurement fixtures, and wound up with this:
Despite the angle of the picture, the shock pot was perfectly vertical and in line with the front face of the master cylinder. Once we had that setup, we definitely recorded some deflection.
The tests were performed with the engine off (no vacuum assist). The brake pedal was pressed several times at varying pressure. Brake line pressure was monitored via OBD2 at a resolution of 1 bar (14.7 psi), and the master cylinder deflection was measured via analog channel at a resolution of 0.001" (4 inch linear potentiometer at 12 bit resolution).
You can see here, despite what may be a structurally inefficient position, it's absolutely effective, reducing master cylinder deflection by 57%. Could it be better? Maybe, but the returns would be minimal. You guys already know it improves feel, here's why.
GSpeed is offline   Reply With Quote
The Following 50 Users Say Thank You to GSpeed For This Useful Post:
aegisdrgn (08-23-2015), akyp (08-20-2015), Aztec (10-28-2015), Bergen23 (08-20-2015), bhmax (09-28-2015), calmtigers (08-20-2015), Calum (08-19-2015), Captain Snooze (08-20-2015), ck-GT86 (08-20-2015), Createddeleted (08-20-2015), CSG Mike (08-20-2015), DAEMANO (08-20-2015), Danklvr (08-20-2015), Decay107 (08-20-2015), DocWalt (09-19-2015), drewbot (08-23-2015), DustinS (08-20-2015), emutcfut (08-21-2015), Ernest72 (08-07-2020), Fareast auto part (08-23-2015), Freeman (08-19-2015), FrX (08-20-2015), Griever423 (08-26-2015), Hyper4mance2k (08-20-2015), JB86'd (08-21-2015), JD001 (08-08-2020), JonAvalon (08-20-2015), Jonsey (08-19-2015), JS + BRZ (08-27-2015), kch (08-19-2015), MrSkubi (01-23-2018), OkieSnuffBox (08-20-2015), PandaBRZ (08-20-2015), Pekingduck (08-22-2015), PNW FRS (08-27-2015), Pointmutation (06-10-2018), Purist (08-13-2020), PWBRZ (08-25-2015), R2RO (10-30-2015), Racecomp Engineering (08-20-2015), Shankenstein (08-19-2015), solidONE (08-19-2015), T-Steve (08-05-2017), TheVoiceOfReason (08-20-2015), tintumz22 (08-07-2020), waterbison777 (08-21-2015), Wepeel (08-21-2015), WhiteFRS69 (08-20-2015), why? (08-20-2015), wparsons (08-19-2015)
Old 08-20-2015, 10:49 AM   #2
Chazzzy
Drives: TBD
VERY Cool!! Thanks for the Info!
Chazzzy is offline   Reply With Quote
Old 08-20-2015, 02:39 PM   #3
Rameus
Drives: 2015 FR-S
Practically every thread by you guys provides real data or at least truly useful information.
Thanks for taking such a comprehensive approach to developing the platform, and above all, sharing the results with us on a regular basis.
If I had 10 posts to my name I'd just click thanks, but this probably gets my point across better anyway.
Rameus is offline   Reply With Quote
The Following 3 Users Say Thank You to Rameus For This Useful Post:
CSG Mike (08-20-2015), DAEMANO (08-20-2015), Griever423 (08-26-2015)
Old 08-20-2015, 07:12 PM   #4
waltco
waltco's Avatar
Drives: 2013 Subaru BRZ
This is awesome! Thank you so much for sharing!
waltco is offline   Reply With Quote
Old 08-20-2015, 08:51 PM   #5
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
that is total win.
why? is offline   Reply With Quote
Old 08-23-2015, 09:47 PM   #6
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
The numbers don't lie! Thanks for making the test results available!
aegisdrgn is offline   Reply With Quote
Old 08-24-2015, 02:49 PM   #7
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
This is why I love this community. Great information
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 08-27-2015, 09:34 PM   #8
JS + BRZ
Drives: 2010 MS3
Awesome stuff. Thank you so much.
Old 08-07-2020, 04:23 AM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Sorry to necro this old thread, but do you happen to remember how to monitor brake pressure via OBD2?
Old 08-07-2020, 08:17 PM   #10
7c8
This is only available over the CAN:
Address: 0x0d1
Length: 1 byte
Offset: 2 bytes
7c8 is offline   Reply With Quote
Old 08-07-2020, 09:09 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Address: 0x0d1
Length: 1 byte
Offset: 2 bytes
Got it, thanks! I was thinking you knew some trick to get it via OBD-II without CAN
Old 08-08-2020, 01:27 PM   #12
7c8
Haha, unfortunately I haven't seen it available through OBD. Good luck!
Perrin Master Cylinder Brace clintavo Brakes, Suspension, Chassis 2 05-28-2015 01:58 AM
Perrin master cylinder brace jack43 Brakes, Suspension, Chassis 1 11-30-2014 12:51 PM
Perrin master cylinder brace SubaSteve Brakes, Suspension, Chassis 9 01-11-2013 11:46 PM
Perrin master cylinder brace for sale SubaSteve Mid-Atlantic 0 01-07-2013 08:52 PM
