Drives: Scion Frs
Need some help with some wiring
![]() ![]() Im trying to hook up my led drl fog lights. But i have no idea how to connect these 2 red wires? Do i just shove the metal piece inside and put the clear plastic piece over it? It doesnt seem to fit when i try it. Thanks in advance |
#2 |
Slow Learner
Drives: 15 Halo FRS
Yep, its called a bullet connector. Push hard.
| The Following User Says Thank You to RustySocket For This Useful Post: | timmydatooth (08-11-2015) |
#3 |
Drives: 2014 Scion FRS
| The Following 4 Users Say Thank You to WhiteFRS69 For This Useful Post: |
#4 |
Drives: 2013 Scion FR-S (Raven) MT
Penetrate the male end into the female end until it's so deep that you can't easily pull it out...and make sure it's wrapped tight with the rubber glove
My Car Journal: Raven FR-S w/ TRD Flavour ![]() Click for my AVIC Z150BH Head Unit DIY Install ![]() |
| The Following 7 Users Say Thank You to tiz22 For This Useful Post: | chas3wba0 (08-11-2015), jamies31 (08-11-2015), MisterSheep (08-11-2015), Porcupint (08-12-2015), RustySocket (08-12-2015), timmydatooth (08-11-2015), WhiteFRS69 (08-11-2015) |
#5 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#6 |
Drives: Scion Frs
Thank you so much! Now while i have your attention guys which one of these wire do i tap in to so that my fogs will be on when i turn on the parking lights? Theres red black and green. I was assuming red but maybe its green...
#7 |
Drives: '15 Halo FR-S
Test with a multimeter and see which one receives about 12VDC with the key on and the light switch in the desired position. . Tap into that one.
#8 |
Drives: Scion Frs
#9 |
Time Traveller
#10 |
Drives: Scion Frs
Im about to say screw it and tap into the red one...i doubt the power wire would be green...is that ever the case tho?
#11 |
Green is most often a ground
#12 |
Take the time find out what is right or pay the price! BCUs are not cheap as many here have found out. I don't know what is what but I do know that with the number of wires used in modern cars the "standard" colour references can go out the window. Red could very well be a ground in this case or maybe not but don't wire by guessing.
#13 |
Drives: Scion Frs
Whats the worse that can happen if i tap into the wrong wire?
#14 | |
Bad - Blown control module, very expensive Moderate - Blow a 50 cent fuse, finding which is the fun part Best - It works no issues
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Porcupint (08-12-2015), Ultramaroon (08-11-2015) |
| How to use the OEM amp Wiring | RandomHero | Electronics | Audio | NAV | Infotainment | 258 | 07-04-2024 01:34 PM |
| Wiring in IAT for SD | mrk1 | Software Tuning | 13 | 04-14-2023 09:15 AM |
| Wiring for DRL | Yap | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 01-19-2015 02:13 AM |
| LF VA Wiring Help | OURO3OROS | Mid-Atlantic | 0 | 02-23-2014 09:24 AM |
| Wiring a sub in a BRZ | Shizuma | Electronics | Audio | NAV | Infotainment | 22 | 06-08-2013 02:02 PM |
