Old 06-12-2015, 08:53 PM   #1
LS1M
Drives: 2015 BRZ
Scan tool ate my TPMS
The dealer was re-mounting my tire (after they forgot a chunk of rubber in it) and re-programming the tire pressure system, when the service manager came out holding my obd2 Bluetooth adapter. Said every time they plug it in, the flat-tire light comes on. So for about an hour, there are a half-dozen guys hovering around my car & the service manager says the TPMS module is dead, and he thinks my scan tool broke it but can't prove it. They ordered me a new one & installed it, but is that possible? I was wondering if there was a pin dedicated to the tire pressure system, and if so, then I guess it's feasible that the scan tool might have tried to talk on that pin when testing for the right protocol. So... I decided to avoid the problem. I made an extension cable that just carries pins 4, 5, 6, 14 & 16 (two grounds, canbus high & low, plus power)
So far so good. And at least I can see the lights on the BT without standing on my head
btw, I have part numbers if anyone is interested
Red shell: Delphi 12110252
Retaining clip: Delphi 12110254
Cap: CaPlugs VRF-500x1250-16
Male pins: Delphi 12047581
Female pins: Delphi 12129373-L
Black (female) connector: Delphi 12110250
Cable was a euthanized cat5
LS1M is offline   Reply With Quote
Old 07-27-2015, 07:02 PM   #2
LS1M
Drives: 2015 BRZ
It happened again. I bought an Android tablet and a holder, put it in the car this morning. Went to start up after work and 3 or 4 lights were on - ABS, traction, engine - and the a/c wouldn't get cold. Turned the car off, unplugged the BT adapter, started it back up & everything is fine. Cleared the code with Torque - said something about network failure. Sounds like the BT adapter is messing up the CAN bus.
Anybody else ever seen this happen??
Old 07-27-2015, 07:33 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
I've seen something like this before, but not this specifically. Sucks. Got warranty on the adapter?
Old 07-27-2015, 08:25 PM   #4
LS1M
Drives: 2015 BRZ
Yes. You think the adapter is bad?
Old 07-27-2015, 09:25 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
Well, if it doesn't seem to actually cause permanent damage, try it on another car for a bit? (loan it to someone or something?) Who knows exactly what's up with it, possibly nothing. But, I can say that I've seen odder things over the years working with electronics and computers. I've seen a monitor that worked everywhere but an electrician's home, peripherals or hardware that, when plugged in, caused random stupid-ness or outright failures (even brand-new stuff!)
Otherwise, reach out to the company and inquire. It looks like it's not a cheap knock-off so hopefully they're actually responsive and whatnot.
C
Does anybody have a TPMS tool I can use/borrow? Grimlock Mid-Atlantic 11 09-02-2015 03:56 PM
ATEQ QuickSet TPMS tool B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-25-2014 09:17 PM
FS: ATEQ Quickset TPMS flashing tool abutterman Wheels and Tires 3 03-27-2014 01:34 PM
Bluetooth OBD2 scan tool? Fast_Freddy Electronics | Audio | NAV | Infotainment 2 08-11-2013 11:34 PM
