| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 Nissan GT-R, 1985 Porsche 944
17x9 Wheels on stock suspension
Hey guys, I've checked wheels directory, but can't find much info for stock suspension except what offset is flush if there is one. I started autocrossing a month ago and the biggest downfall in the car (except for my skill) is the grip and I want to combat it with good wide tires on wider lighter wheels. I like Enkei TS9s, but not sure if 17x9 will fit, otherwise I'll get 17x8.
If anyone has ever put 17x9s on STOCK SUSPENSION please let me know what wheels and what offset? If not possible please let me know as well. Thanks! |
#2 |
Drives: 2014 BRZ Limited 6M
You will be fine depending on the offset of the wheels. +35 offset on 17x9 will clear the stock suspension and will not poke out like an eyesore. +42 is fine as well; however, I would be wary to push it any further.
Here's the source: http://www.ft86club.com/forums/showthread.php?t=42746 |
#3 |
Hey thanks for the reply! As the offset on those is 45 I see 2 options, 10mm spacers in front (backs supposed to be flush at 42 offset) or getting 17x8 in front (but i'm not sure it won't upset the balance). What would you suggest? I'm new and young so might ask stupid questions
#4 |
Drives: 2017 BRZ
What's your rulebook say about wheel size? SCCA bumps you out of CS for a wheel size change.
Alignment is a pretty important bit too - its what keeps the tire contact patch where it needs to be to grip. If you have plans where to go with the car and mods where this change fits in the grand plan, great. Otherwise, you may find yourself wanting something different. |
#7 |
#8 |
Drives: FRS
17x9 +38 with 245/40/17 tires all around fits no problem also. barely clears the stock suspension, but still clears and no rub even on hard turns.
| The Following User Says Thank You to 8R6 For This Useful Post: | Sigsegv (04-04-2018) |
#10 |
Drives: 2013 Raven FR-S
#11 |
Drives: FRS
when i was on stock suspension, camber was whatever it was straight from the factory which was minimal. im on ST coilovers now and lowered just over 2inches. -2 front, -2.7 rear
#12 |
Drives: 2013 Scion FRS firestorm
17x9 +45 will work fine on stock suspension as long as you don't add any more negative camber (though it would be beneficial if you did).
17x9 +42 will work fine and will allow you to run slightly more negative camber than factory. 17x9 +35 will require you to run -2ish camber up front not to rub (but don't be afraid of the camber as it will help with tire wear if you are autocrossing.
#13 |
Just FYI, I had to run a 5mm spacer on 17x9 +42s with -3.2 degrees of camber to clear the springs (Swift Spec Rs but should be the same diameter as stock).
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#14 |
Drives: 2014 BRZ Limited SWP
17x9 +35 will clear stock suspension or eibach/trd...
+45 you're going to have to be on coils. I have 18x9.5 +45 and also 17x9 +35 Stock is 17x7 +48 Sent from my iPhone using Tapatalk
#TrackDayBro
| 18" wheels on stock suspension | echo419 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 07-17-2017 07:40 AM |
| Pic Request: 17x9 on stock suspension | hmong337 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 02-23-2017 03:24 PM |
| +1 wheels, stock suspension? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 11-15-2013 09:05 PM |
| Perfect Wheels for Stock Suspension | pcamaliga | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 05-12-2013 03:36 PM |
| Aftermarket wheels with stock suspension | Thongpocket | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 01-24-2013 06:08 PM |
