Drives: 2013 WRB BRZ 6MT
Tie rod ball joint stuck
I'm trying to replace my tie rod ends using thw Whiteline bump steer and roll center correction kit, but I can't get the ball joint on the end of the driver-side tie rod to separate from the hub assembly. I removed the cotter pin and castle nut, but nothing I do seems to move the ball joint. Am I being stupid or missing something?
#2 |
Drives: 2024 GR86
Put the castle nut on an try hitting it with a hammer. . Be careful not to damage the treads. Make sure the tie rod is flush with the nut to ensure maximum thread engagement.
| The Following User Says Thank You to Fishbone For This Useful Post: | whataboutbob (07-17-2015) |
#3 |
This doesn't seem to help at all. I mean, there is no movement between the ball joint and the hub. Do I just need to hit it harder or something? I put a block of wood between the ball joint and the hammer, and i'm mostly just putting dents in the wood.
#4 | |
Frosty Carrot
Drives: The Atomic Carrot
For stuck ball joints, here's my strategy:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#5 | |
That Guy
Drives: 2013 asphalt FRS MT
In bold. |
#6 | |
Drives: 2024 GR86
If that still does not work, use a jack to raise the hub and hit the nut again. Its possible the dropping suspension on jack stands in binding the tie rod in the knuckle. |
#7 |
buy a ball joint puller tool. you can buy one at harbor freight or amazon for like 10 bucks. it's a U-shaped tool with a threaded bolt in the middle (use a wrench to turn the bolt) and it applies pressure to push the other end out. make sure you buy the right size though so that the tool has leverage. I haven't changed anything suspension-wise on my BRZ, but it made everything so much easier on my MR2 when I replaced the ball joints and tie rods.
#8 | |
Shift it or lose it
Drives: 2014 FRS, 2003 Celica GT
I like to put the castle nut on upside down if I feel I need to hit it but usually when you hit the knuckle where the tie rod end goes into it usually just falls out. 70% of the time. lol |
#9 |
I'll get back on it tomorrow morning, but the whole thing feels like it's welded together. It's probably not safe to take a torch to it right next to that dust boot. It and a few nuts are soaking up PB Blaster tonight.
#10 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | GhostRai (07-18-2015) |
#11 |
I was able to get it out using a too-small, clamp-style ball joint separator and a hammer to keep it in place. Thanks for all the help.
#12 |
It was a bitch, wasn't it?
#13 |
Drives: GT86
For future reference, I often find the success of a hammer is usually down to the size chosen and the anger behind it. Tickling it with a toffee-hammer seldom results in much.
| The Following User Says Thank You to Uncle Benz For This Useful Post: | Ultramaroon (07-19-2015) |
#14 | |
Member of the year - 2016
Drives: Scion FRS
The biggest issue with removing the tie rod is removing other parts first, some people will remove the strut housing from the steering knuckle, it's best to keep that all in place and remove the tie rod first.
| Need some help, how to disingage the rear UCA ball joint. | Calum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 05-07-2015 04:52 PM |
| Rear upper control arm ball joint? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 01-06-2015 08:17 AM |
| Ball Joint Replacement, The fun way. | FRSPacNW | DIY (Do-It-Yourself) Guides | 2 | 06-28-2014 04:04 AM |
| Front ball joint dimensions | J-W | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-02-2013 06:31 PM |
| loose ball joint | Grip Ronin | Issues | Warranty | Recalls / TSB | 15 | 07-09-2013 02:16 PM |
