| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2017 Subaru BRZ
Engine Oil for DD/Track
I am looking for suggestions on what type of oil to run for DD w/2-3 track days per oil change in SoCal climate. Engine is stock and I am going to be running a Jackson Racing oil cooler. Temps shouldn't be an issue considering most are not seeing anything above 220 degrees with an oil cooler in NA form.
Ice Silver 2017 BRZ w/PP 6MT | Driver Mod |
#2 |
Drives: 2023 BRZ
Any quality full synthetic should get the job done. 5-30 will work, as will 0-20.
You would be well-served to search before asking questions. There is a lot of great information already out there, including this. |
| The Following User Says Thank You to Pat For This Useful Post: | JohnJuan (06-10-2015) |
#3 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
i'm using motul 300v now but had 8100 eco energy before that.
#4 |
@midnight23 Did u ever track on 8100? If so what were the max oil temps?
#5 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I run and recommend Millers Nanodrive CFS 0W-30 NT. It's a true race oil that can be used on the street for longer intervals. It features nanotechnology that allows significant friction reduction that adds measurable power with added durability. It's dyno proven to add 6wp and 3wtq to a stock 86 and myself and others have UOAs showing clean bills of health after 3k miles of E85 fueled track abuse and 7k miles of spirited street driving. Product link: http://performanceracingoils.com/cfs-0w20-nt-p-48.html FAQ's: http://performanceracingoils.com/faqs-ezp-2.html Case study on longevity: http://performanceracingoils.com/PDF...case_study.pdf Dyno proof: http://www.millersoils.co.uk/news/20...Power-Test.asp |
#6 |
Drives: '15 BRZ RA
Don't go more than 0W30 or 5W30. You can find a detail analysis by Total and Subaru here:
http://www.pleiades-zero.com/ They say that in racing applications 0w30 is ideal for the FA20 engine. Motul 300v 5W30 also has similar specs. Last edited by nikitopo; 06-11-2015 at 02:29 PM. |
#7 | |
Drives: '23 BRZ Limited
Nice! Quite pricey though. With an oil cooler you're looking at $160 oil changes. Although with my typical mileage that would only be 2x a year at this point. |
#8 |
Drives: '15 BRZ RA
#9 | |
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | driftking96 (05-19-2016), texasbound972 (10-05-2015) |
#10 | |
Drives: '15 BRZ RA
| The Following User Says Thank You to nikitopo For This Useful Post: | texasbound972 (10-05-2015) |
#11 |
Are you saying that 8100 is not up to the task of track duty, even with an oil cooler? If so, is Motul 300V my only option? Seems like overkill for a DD with light track duty. Surely there is something in between that fits my intended use. I plan on sticking with 0w20, is there any reason why I should go with a 0w30 or 5w30 instead?
#12 |
Drives: 2005 Toyota Camry
300V is great but if you have to ask if it's good for DD or not, you generally would not need it.
https://www.motul.com/ca/en-us/community/446 |
#13 |
Or you can resort to Google to find gems like this:
http://www.bobistheoilguy.com/forums...Number=1817829 |
#14 | |
| track driven car - Engine noise - click on driver side - vid | philooo | Tracking / Autocross / HPDE / Drifting | 1 | 04-27-2015 08:09 PM |
| LSx engine swap for track use, thread | foodman | Tracking / Autocross / HPDE / Drifting | 77 | 03-16-2015 03:23 PM |
| Engine 11 Track Bike (Socal) | Cop | Miscellaneous | 0 | 09-24-2014 09:49 PM |
| Check engine light at the track | Thongpocket | Issues | Warranty | Recalls / TSB | 7 | 05-12-2014 08:54 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
