Old 11-14-2013, 08:20 PM   #29
whataboutbob
AutoX-10/10ths every run
I put anti seize on early on when I got the car and haven't had my lug nuts back out. I always torque them properly when mounting the wheels. YMMV
Build thread:Here
Old 11-14-2013, 09:00 PM   #30
zimzim
Originally Posted by fasterthanu View Post
Don't listen to this guy or you will keep breaking studs.
The lubricant will not allow the lugs to break their specified torque on their own,it will only allow the nut to be successfully removed without damage occurring to the threads.
I work in the industrial field and use never seize on applications to over 2000ft lbs of torque. The only way you can reach that torque is with a lubricant on the threads otherwise the friction and force will literally gore the metal before the specified torque is reached.
Now do you understand the purpose of thread lubricant?Or do you need a more scientific explanation?
If you're torquing to 2000 ft-lbs you're yielding the bolts to get clamping force, the never seize won't do anything to get them off.
zimzim is offline   Reply With Quote
Old 11-14-2013, 10:07 PM   #31
GarageBRZTuning
GarageBRZTuning's Avatar
Drives: 2013 Subaru BRZ Limited Silver MT
I work at a Discount Tire Company in Colorado and I recently worked on my car at the shop and our computer states torquing the lugs at 80ftlb... I am not quite sure why the manual says 89. Also the studs on a Subaru/Toyota/Honda are very fragile and really easy to break. I've seen some studs easily breaking off at around 100ftlb. Really the only advise I give to you is that Discount Tire/Americas Tire will bolt on wheel assemblies for free.(Or at the very least my store does!) Oh and also, if a Discount/Americas tire breaks a stud they will call the nearest Brakes Plus and have them put new studs in for you for free!
GarageBRZTuning is offline   Reply With Quote
Old 11-15-2013, 10:24 AM   #32
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by RAWR BRZ View Post
You guys serious? The reason why they break is because the studs are steel and i assume you have after market lugs nuts that are aluminum. Steel + aluminum will galvanize which means 89ft/lb will equate to something like 150 (guessing) after awhile. The anti seize is so that it isnt direct steel to aluminum contact so they dont galvanize. That way it can be easily removed. This happened to a friend and he broke probably 7 studs. He finally started to use anti seize and it fixed his issue. He tracks his car hard too with the lugs torqued to 89ft/lb and no backing out issues.
Aluminum lug nuts? That's nuts.
Btw that's electrolytic corrosion, the opposite of galvanizing. Galvanizing is done to prevent electrolytic corrosion.
Suberman is offline   Reply With Quote
Old 05-25-2015, 08:48 PM   #33
donoman
donoman's Avatar
Drives: '13 FR-S
Yo WTFFFF I just snapped 2. I have broken 1 lug in 15 years of working on cars. What is the deal with these???
donoman is offline   Reply With Quote
Old 05-26-2015, 10:00 PM   #34
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Anti seize works brilliantly to stop them from binding up. ARP studs all around is the best solution though.
- The Ancient BRZ Sacrament
by Zaku
Old 05-27-2015, 01:53 AM   #35
ryoma
ryoma's Avatar
wait the torque for this car is 89 ft/lbs? I've been doing it to 80 this whole time lol
Old 05-27-2015, 11:20 AM   #36
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Reading the comments about anti seize, bad idea. Id u lube them with anti seize and torque them to 89lbs ur actually going way over.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 05-27-2015, 02:19 PM   #37
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
My family owns an automotive shop for the last 45 years and have always used anti-seize with great success.
I always torque it to about 3-5lbs less than dry torque spec.
I have taken my wheels off of my frs about 10 times with no problems.
Pacific Auto is offline   Reply With Quote
Old 05-28-2015, 09:36 PM   #38
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I you use any lubricant on wheel studs here in UT you get failed on your safety inspection. The factory torque spec is for dry application. Using any sort of lubricant will cause the lugs to be overtightened.
Not that I'm against using it, but I've never used it and I've never broken a stud. Are these on vehicles using factory wheels? How about aftermarket with or without centric rings? Can't imagine something as cheap as a wheel stud being made of low quality metals from factory.
Coheed is offline   Reply With Quote
Old 12-24-2015, 02:36 AM   #39
Astroboy
Astroboy's Avatar
Drives: None
Yeah, it pisses me off how these cars are so delicate. One of my studs is pealing from the end, and the other got some of its threading shaved. Seriously, wtf! And if you're slightly off on the jack point when lifting it up, the jack point will slightly bend. Smh bro.
Astroboy is offline   Reply With Quote
Old 12-24-2015, 03:04 AM   #40
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The price you pay for cheap cars.
My theory is if you're not careful taking the wheel off the studs the wheel and stud will grind against each other and remove material (probably from the wheel) which will get caught in the threads if it isn't brushed away before the lugs go back on, it's probably the root of the threads getting wrecked.
I've had two strip, never snapped any. Went ahead and replaced them with those bigass ARP studs for the WRX in the hopes that I would never have to replace them again.
ineedyourdiddly
Old 12-24-2015, 03:08 AM   #41
Astroboy
Astroboy's Avatar
Drives: None
How do you change them? You just need to remove the wheel and replace them from the back correct without removing the hub correct? Never really looked black there so Idk. I'm more worried about that bent jack point! I how it doesn't bend this week while it's on the lift when I'm replacing the clutch this week and kill me...
Sent from my LG-D850 using Tapatalk
Old 12-24-2015, 03:21 AM   #42
swarb
You should read the WHOLE thread.
Extened Studs? BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-29-2013 11:29 AM
Down hill breaking... ABS? shaofis Issues | Warranty | Recalls / TSB 11 10-22-2012 04:28 PM
Breaking Bad: Season 5 |-Goku-| Off-Topic Lounge [WARNING: NO POLITICS] 15 07-22-2012 01:02 AM
Breaking Bad Season 4 tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 4 10-10-2011 08:17 PM
