Old 05-12-2015, 08:39 AM   #155
rlpaul
Drives: point A to point C. Screw point B!
[quote=wsites;2245459]
Originally Posted by slicktop View Post
Can't make up my mind on tire compound for the street.
275/40R17 rear
MT ET Streets
Nitto 555R
Continental ExtremeContact DW
245/45R17 fronts
Nitto 555
My only question, surprisingly, is how well do you think 245s and 275s will fit? I feel like they will rub but I could be wrong... Any clarification would be appreciated, have you test fitted them before or something? Or perhaps you're going wide body?Anyway, awesome build!
Depending on wheel offset, the 245s will fit just fine. I'm running 245/40/17 no issue, and several people on here are running 255s. As I recall, 275s in the rear require rolled fenders, but that's all.
rlpaul is offline   Reply With Quote
The Following User Says Thank You to rlpaul For This Useful Post:
wsites (05-25-2015)
Old 05-12-2015, 11:41 AM   #156
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
As @rlpaul pointed out, the 245's should fit fine with minimal camber and the 275's should fit with a roll and maybe a slight pull. The car will be raised to keep the axles inline with the diff.
I'm not going widebody. I'm trying to keep the car as stock body as possible. I may do a lip, side-skirts, and rear spats to make the car appear lower but that might be the extent of exterior modifications next to the fender roll/pull.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 05-12-2015, 11:46 AM   #157
Kkobe2
Drives: 2015 Series.Blue
Any updates on your progress?
Kkobe2 is offline   Reply With Quote
Old 05-12-2015, 01:16 PM   #158
slicktop
They're finishing up integrating the ProEFI. I'm hoping to drive it this weekend, but we'll see. The A/C system still needs to be installed as well.
-slicktop
2013 Scion FRS
Old 05-14-2015, 02:21 AM   #159
rh9
Drives: red brz
Im running 275s on the back of mine, no problems
I even fit 26inch drag radials
sick setup @slicktop
rh9 is offline   Reply With Quote
Old 05-15-2015, 08:44 PM   #160
slicktop
[ame="https://www.youtube.com/watch?v=T5TlX4h4p5o"]2JZ FRS - Start Up +mod list - YouTube[/ame]
-slicktop
2013 Scion FRS
The Following 3 Users Say Thank You to slicktop For This Useful Post:
Drift&Drag (05-25-2015), R2RO (07-03-2015), Ryaquinn (05-17-2015)
Old 05-15-2015, 08:58 PM   #161
BPAuto
BPAuto's Avatar
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
Your build sounds awesome.
BPAuto is offline   Reply With Quote
Old 05-27-2015, 11:37 PM   #162
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
So, as I said before, I upgrade my feed/return lines. Need to buy MORE fittings (holy christ) as well.
I picked up this fitting to utilize the stock FRS feed fitting and open it to a -8 AN all the way forward.
This is how you install it, very straight forward. This type of quick-disconnect fitting is better because it will not/cannot disconnect due to vibrations. (NOTE: The chances of that happening are slim to none, but I am upgrading my line size so it's warranted).
Installed.
Neat thing about the stock fuel rail brackets. The outboard (stainless braided line to the right as you're looking at this photo) bracket support fits a -6 AN perfectly. However, in order to utilize this spot you need to remove your stock fuel rails. The -8 AN feed line will be fully secured with brackets (zip-ties temporary. Lowes was closed and I didn't have the hardware on hand).
Where'd you get the SS lines ?
PolishFrs13 is offline   Reply With Quote
Old 05-28-2015, 12:42 AM   #163
PolishFrs13
building life
Under the drivers tire is my fuel return line. I stayed up late last night working on my fuel system. I kept trying to figure out the best way to retain the stock fuel lines but it simply adds too many fittings. The stock setup runs a 3/8'' line from the fuel pump assembly, Tees to two 3/8'' down the frame, then hooks up to the FA20. If I kept that, I would have to Tee down to a single -8/-10 to an inline filter, then Tee back out to two -6. That's just too many fittings (I'm running mostly Aeroquip, w/ Earl's and Fragola odds and ends). I ended up buying -8 AN feed which will split to dual -6 with a -6 return.
What size lines did you end up using ?
Old 05-28-2015, 09:44 AM   #164
slicktop
That's exactly the reason why I got rid of the stock lines; I would have ended up with too many fittings. I'm running the same size lines for my setup as well. Should provide plenty of fuel.
-slicktop
2013 Scion FRS
Old 05-28-2015, 09:46 AM   #165
slicktop
Got all my stuff from summitracing.com.
I ended up having to go with different fittings since the ones I mistakenly bought weren't PTFE fittings. All fixed now, though.
-slicktop
2013 Scion FRS
Old 05-28-2015, 12:55 PM   #166
PolishFrs13
building life
thanks for that! gonna be doing my fuel system here shortly once everything is ordered in, trying to find the right parts so i dont make a fitting mistake lol
Old 05-28-2015, 01:15 PM   #167
PolishFrs13
building life
Bulkhead fitting, but it's the @FullBlown return kit.
Happen to have a Part # for the Bulkhead fitting ?
Old 05-29-2015, 12:57 PM   #168
slicktop
Unfortunately, no. Just take some measurements and make sure you grab PTFE compatible fittings.
-slicktop
2013 Scion FRS
The Following User Says Thank You to slicktop For This Useful Post:
PolishFrs13 (05-29-2015)
2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Mr and Mrs FR-S Build jaydee_do_work Member's Car Journals 2 12-04-2013 10:51 AM
86 BUILD, AUS JS86JS Member's Car Journals 9 05-31-2013 09:59 AM
My build... well some of it cruzinbill Electronics | Audio | NAV | Infotainment 41 04-01-2013 05:02 PM
STX build Evil86 Tracking / Autocross / HPDE / Drifting 2 01-08-2013 04:40 PM
