Old 05-06-2015, 10:52 PM   #57
Ashikabi
Ashikabi's Avatar
Well I have been past sideways and it didnt kick on that I could feel or see. It doesn't stop me from spinning at autocross or save my rear tire from a curb so I'd say it's pretty well off. Disabling auto LSD isn't exactly traction control but I digress. If you want to be right then go ahead
Old 05-07-2015, 12:25 AM   #58
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I'm not trying to "be right," I'm just saying that it will still intervene, but it doesn't do so intrusively, and it take a pretty significant slip angle for it to happen, but it does kick in. I'm not the only one it happened to. I went ice racing with group of Toyobarus, and they all had the same experience. The TCS will eventually kick in, and that will set off the indicator on the dash.
Stang70Fastback is offline   Reply With Quote
Old 05-07-2015, 01:43 AM   #59
ryoma
ryoma's Avatar
why does it sound so scary when traction control turns on? the gear grinding sound from the diff always makes me cringe whenever I hear it. might start driving with traction off all the time lol
Old 05-07-2015, 02:56 PM   #60
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I wonder if when the TCS is off (both TCS and VSC yellow) there is a jump feature. I've read some where that some newer cars have a vertical sensor for high vertical G-loads that indicate flight, and it causes the car to go into safe mode until traction is restored? With the one wheel getting air with a heavy bump could this be the issue?
Gords_zenith is offline   Reply With Quote
Old 05-07-2015, 03:21 PM   #61
CoupedUpSubie
Drives: 2013 BRZ Limited
So I have had various experiences with traction/stability control across a couple manufacturers now. One key factor in how it kicks in with it "off" is how much horizontal force is allowed. Chrysler actually has a very restrictive TC/VSC setup compared to the one in the 86. The trick to getting a good drift if that is what you want is to have enough wheel slip before actually entering the drift. This worked on an 06 Charger(I was not driving). I actually have the TC off when I drive as 90% of the ends of the roads I drive have dirt and I hate the power cut and inability to get up and go while taking off. I have experienced vsc kicking in when really pushing the car through exits. I now keep it just below that threshold if I am having fun.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 05-07-2015, 04:03 PM   #62
stugray
Drives: 2013 GBS BRZ Limited
You are spouting crap that is NOT FACTUAL.
If you use the button press (ANY COMBINATION THEREOF) you have NOT completely disabled the systems.
1 - I have experienced at least once where the system re-enabled itself after the 5-second button press and it spun me into oncoming trraffic in the snow.
2 - EVEN IF the system remains "disabled" via the button press SOME of the systems (ABS, Brake-bias) are STILL ACTIVE.
3 - EVEN THE PEDAL DANCE (a step ABOVE the 3-second button press) leaves SOME systems enabled
4 - The ONLY way to truly "disable" the systems is to remove the ABS fuse.
Read some of the threads where people have posted their experimentation on the track in all of the above scenarios before you make any more false statements.
The Following 2 Users Say Thank You to stugray For This Useful Post:
fika84 (05-07-2015), Tcoat (05-07-2015)
Old 05-07-2015, 04:10 PM   #63
Ashikabi
Ashikabi's Avatar
Did it re enable or are you just a bad driver?
Old 05-07-2015, 04:14 PM   #64
fika84
fika84's Avatar
Let the battle begin!
fika84 is offline   Reply With Quote
Old 05-07-2015, 04:17 PM   #65
Ashikabi
Ashikabi's Avatar
I'm just saying... why would a traction control system kick in right that second and make him "lose" traction?
Old 05-07-2015, 04:20 PM   #66
Somebody else's turn!
Good luck Stu.
Old 05-07-2015, 04:21 PM   #67
fika84
fika84's Avatar
This car does some weird shit in the snow sometimes.
The Following User Says Thank You to fika84 For This Useful Post:
SirBrass (05-11-2015)
Old 05-07-2015, 04:22 PM   #68
fika84
fika84's Avatar
Good luck Stu.
Definitely got my money on Stu on this one.
Old 05-07-2015, 04:25 PM   #69
Old 05-07-2015, 07:46 PM   #70
stugray
Well lets see:
I held both buttons until both dash lights WERE LIT.
Then I drove, and DURING THE SPIN the VSC & TC Lights began blinking furiously.
Then when I stopped spinning in the middle of the road and came to a stop, they were NOT LIT.
What do you suppose that means?
AND you only commented on my item 1,
what about the others?
Did you even READ the rest of the thread?
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Turn off Traction Control FR_Soldier_77 Scion FR-S / Toyota 86 GT86 General Forum 35 01-22-2013 09:47 PM
So, when does the traction/stability control work against you? NOHOME Scion FR-S / Toyota 86 GT86 General Forum 2 10-03-2012 10:06 AM
Traction Control / Vehicle Stability VSC kicking in when not necessary? WTF Scion FR-S / Toyota 86 GT86 General Forum 15 08-15-2012 05:24 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
