Old 04-27-2015, 10:17 PM   #1
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Remove Engine - Any DIY's?
Hey all - I tried searching not only the forum, but google for a DIY engine pull guide (go figure it doesn't seem to exist) - so i'm looking for a few answers for anyone who may have done this before:
1. Where do you get a bolt / eye bolt to use as the second engine hoist point?
2. Can the engine be removed with the AC intact?
3. Can the engine be removed without draining the power steering?
Thanks! Have to pull my engine. It died at 11k (drinking oil in cyl 1)
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 04-27-2015, 10:25 PM   #2
mrk1
Drives: Sterling BRZ Ltd
-Unbolt the AC compressor from the motor and swing it to the side, system will be untouched.
-After the AC Compressor is out use one of the bolts as a second lifting point.
-There is no power steering fluid, electric
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-27-2015, 10:26 PM   #3
Gopherboy6956
Gotcha. Sorry - i meant brake fluid.
Old 04-27-2015, 10:28 PM   #4
mrk1
brake fluid is untouched when pulling the motor
The Build Thread
Old 04-27-2015, 10:31 PM   #5
Gopherboy6956
lol i must be crazy. What is the little res. just off center of the firewall? Looks like it has a line that sits right on the engine / tranny connection point.
Old 04-27-2015, 10:34 PM   #6
sam69
Drives: GT 86
Might be clutch master cylinder .
sam69 is offline   Reply With Quote
Old 04-27-2015, 10:35 PM   #7
mrk1
These cars have a second fluid reservoir for the clutch master and slave cylinder. Just like the AC, unbolt the clutch slave cylinder and put it off to the side. Just make sure no one pushes the clutch pedal and everything will be fine.
The Build Thread
Old 04-27-2015, 10:36 PM   #8
Gopherboy6956
there we go. and upon closer inspection, it looks like its just ever so on the transmission side.
So just one of the ac compressor bolts will be strong enough to hold half the engine?
I see there is a empty bolt hole just left of that that looks pretty deep.
Old 04-27-2015, 10:56 PM   #9
Gopherboy6956
Also, i've got the AC Compressor free, but it seems like i have to severely twist the lines to rotate it out of the way. Any trick to that?
Totally first time engine puller here, please bear with me. I don't want to damage anything.
Thanks!
Old 04-28-2015, 09:12 AM   #10
Gopherboy6956
Here's a question. What are, and more importantly, how do i disconnect, the three lines just north of the oil filter / filler.
Old 04-28-2015, 09:24 AM   #11
fika84
fika84's Avatar
The service manual is on this site.. why don't you follow it and do it right so you don't break anything?? Especially if this is your first time pulling an engine! You're going to need it when you go back to torque things down anyway...
fika84 is offline   Reply With Quote
Old 04-28-2015, 09:31 AM   #12
Gopherboy6956
Thanks! I had only seen a 5000 page pdf someone posted that was impossible to follow.
I'll definitely download that.
Old 04-28-2015, 09:39 AM   #13
fika84
fika84's Avatar
Absolutely. I have it and it is the best.
Feel free to ask specific questions about "special tools" and such because there is always a way around special tools
Old 04-28-2015, 09:41 AM   #14
Gopherboy6956
Haha thanks.
I have just those fuel lines and the transmission to unbolt, then i'm ready to yank the engine. All in all, it's really not that bad of a process, even for someone who's never done it before. Now, finding the reason I have oil in cyl 1 will be another task in an of itself.
FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit PrimeMotoring Engine, Exhaust, Bolt-Ons 10 11-25-2014 11:38 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
