| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2015 Scion FR-S
Anyone else having tire pressure issues?
I had the FR-S for about 7 months now and the pressure on the tires go down (to the point that the dash light comes on) like once per month. I never experienced this issue with any of my past cars. Is this just a normal thing with the FR-S?
#2 |
Drives: JAWS
What tire pressures are you running usually? And what are they when the light comes on?
#3 |
I usually fill it up to the suggested level listed on the sticker in the door panel...I think it's 35? Not sure I'm not around my car at the moment. And the light usually comes on when they get to 25 or so.
#4 |
Drives: 2014 FR-S Asphalt
My light comes on at 29psi, but I've only had it come on once. I have only added air that one time over the 11 months I have had the car. I use a digital pressure gauge. Those slidey ones can be inaccurate.
#5 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
Sounds like you have a slow leak. A good way of checking is lather your wheel with soapy water. If you see bubbles forming then there's your leak. Make sure to play around with the valve stem since it could be a crack there that wouldn't leak unless bent.
#6 |
Drives: 13 FRS Satin
Rim leak, tire leak or valve stem leak.
Some old alloys on an older vehicle of mine had a corroded rim from all the winter drives and salt. Ask them to give your rim a clean. That's why I run a set of inexpensive rims during the salty months. Few possibilities, bring it to your nearest tire shop. |
#7 | |
I think I picked it up around January. Meh. |
#8 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
| The Following User Says Thank You to N1rve For This Useful Post: | Ultramaroon (04-22-2015) |
#9 |
#10 |
Drives: 2013 white limited BRZ
In general, one will lose a pound (sometimes two) of air over a month. This is normal. I can't point to it but you may find it on a AAA site or some other site that covers things like that.
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 11:27 PM |
| aftermarket oil cooler, pressure issues? | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 05-05-2014 11:36 AM |
| Tire Pressure for PSS? | Pacific Auto | Tracking / Autocross / HPDE / Drifting | 12 | 01-22-2014 11:50 PM |
| what is your tire pressure? | abling2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-03-2013 11:49 AM |
| What Hot Tire Pressure? | gbgracer | Tracking / Autocross / HPDE / Drifting | 24 | 05-14-2013 06:47 AM |
