Old 04-20-2015, 08:16 PM   #1
beatgenie
beatgenie's Avatar
Drives: 2015 Scion FR-S
Anyone else having tire pressure issues?
I had the FR-S for about 7 months now and the pressure on the tires go down (to the point that the dash light comes on) like once per month. I never experienced this issue with any of my past cars. Is this just a normal thing with the FR-S?
beatgenie is offline   Reply With Quote
Old 04-20-2015, 08:58 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
What tire pressures are you running usually? And what are they when the light comes on?
JB86'd is offline   Reply With Quote
Old 04-20-2015, 09:22 PM   #3
beatgenie
beatgenie's Avatar
I usually fill it up to the suggested level listed on the sticker in the door panel...I think it's 35? Not sure I'm not around my car at the moment. And the light usually comes on when they get to 25 or so.
Old 04-20-2015, 09:53 PM   #4
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
My light comes on at 29psi, but I've only had it come on once. I have only added air that one time over the 11 months I have had the car. I use a digital pressure gauge. Those slidey ones can be inaccurate.
Vampyre is offline   Reply With Quote
Old 04-20-2015, 09:55 PM   #5
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Sounds like you have a slow leak. A good way of checking is lather your wheel with soapy water. If you see bubbles forming then there's your leak. Make sure to play around with the valve stem since it could be a crack there that wouldn't leak unless bent.
jimmillion is offline   Reply With Quote
Old 04-21-2015, 12:06 AM   #6
Chanpion
Drives: 13 FRS Satin
Rim leak, tire leak or valve stem leak.
Some old alloys on an older vehicle of mine had a corroded rim from all the winter drives and salt. Ask them to give your rim a clean. That's why I run a set of inexpensive rims during the salty months.
Few possibilities, bring it to your nearest tire shop.
Chanpion is offline   Reply With Quote
Old 04-21-2015, 12:42 AM   #7
I've been nursing a very slow leak in one of my tires. Close enough to end of tire life and it's a teeny nail. Only leaks when wheel sits overnight in the exact right position. Sometimes it goes a couple weeks before tpms triggers. 29 psi every time.
I think I picked it up around January. Meh.
Old 04-22-2015, 03:39 AM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
No idea where the cove is but if you have an americas tire near, they can fix it for free if it's in a repairable zone.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Ultramaroon (04-22-2015)
Old 04-22-2015, 01:55 PM   #9
I'm just lazy about it.
Old 04-22-2015, 02:37 PM   #10
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
In general, one will lose a pound (sometimes two) of air over a month. This is normal. I can't point to it but you may find it on a AAA site or some other site that covers things like that.
Casey10s is offline   Reply With Quote
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
aftermarket oil cooler, pressure issues? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 05-05-2014 11:36 AM
Tire Pressure for PSS? Pacific Auto Tracking / Autocross / HPDE / Drifting 12 01-22-2014 11:50 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 11:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 06:47 AM
