Old 04-17-2015, 12:13 PM   #29
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by stevesnj View Post
So where did you get the gears? cost, install pricing....thanks for any info!
I got the gears from MFactory, $750.
Install kit with solid pinion spacer from Weir Performance $380.
I did the labor myself so that saves me money there as its not a quick job, setting up the backlash, pinion height and preload. There are a bunch of shims you need to set the back lash, this is really what makes this not a drive way install. I bought one of every size, not cheap. There are only 2 of these shims in the diff when its done but I had to try a few to get the back lash just right. If you have a shop do the gear set up they would have to have these shims.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 6 Users Say Thank You to mrk1 For This Useful Post:
Griever423 (11-08-2015), Hawk77FT (11-08-2015), jcw99 (03-10-2016), JoeC (04-17-2015), stevesnj (04-17-2015), Ultramaroon (04-17-2015)
Old 04-17-2015, 02:40 PM   #30
linkmaster_13
Drives:
Where's the like button lol
linkmaster_13 is offline   Reply With Quote
Old 04-17-2015, 03:12 PM   #31
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
No likes just thanks 😋
Carlitoz3 is offline   Reply With Quote
Old 04-17-2015, 03:54 PM   #32
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Damnit why do you have to be so far away? Ever considered moving to Cali?
++kudos for the mod!
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-17-2015, 03:58 PM   #33
You'll see it after 10 posts.
Old 04-17-2015, 04:14 PM   #34
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Originally Posted by Carlitoz3 View Post
What are the drawbacks?
Higher RPM at cruising speed and engine/exhaust noise, possibly lower MPG, and possible warranty issues.
Bobblehead is offline   Reply With Quote
The Following 2 Users Say Thank You to Bobblehead For This Useful Post:
Mr.Impreza (12-26-2015), Ultramaroon (04-17-2015)
Old 04-17-2015, 08:22 PM   #35
misooscar
misooscar's Avatar
Drives:
Intrigued...how would this feel on a vortech superchargered model?
misooscar is offline   Reply With Quote
Old 04-17-2015, 09:05 PM   #36
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by churchx View Post
Smaller tires .. good 'tune' for this particular car, as in addition to lower weight/rotational mass [1], some say that it's suspension was developed with 16" in eyes, some even prefer resulting handling with smaller rim size [2]. And some say that it even looks better with meatier tires. Daily drivability/comfort may increase. And of course one will save $$ on tires (which are eaten rather quickly, when drifting). About the only caveat for going 16" - most bigger brake kits won't fit.
1/ As I mentioned above fitting 16" wheels is not a guarantee that you are going to end up with a lighter wheel.
2/ The difference in static diameter is approximately 2mm. I do not know what the difference is on rolling diameter but I am suggesting it is not the panacea that some people claim.
I am going with 16" wheels eventually to bring the final drive down to the true ratio.
True ratio? What is that?
17" 45 profile vs 16" 50 profile: When speedometer reads 60mph (96.6km/h) actual speed will be 59.8mph (96.3km/h): 0.3% slower on the 16". Once again this is static diameter.
Negligible difference in ratios.
I am hypothesing that given the increase in sidewall height a 16" tyre has more angular momentum than a 17" tyre.
Old 04-17-2015, 10:04 PM   #37
stevesnj
stevesnj's Avatar
Not that dramatic a change in RPM but there is enough to notice. Warranty should not be affected at all. Would like to know for sure though.
My 2016 Build thread
Old 04-17-2015, 10:45 PM   #38
mrk1
Any Centrifugal SC car would love a higher final drive. More RPM more power with a centrifugal SC so a higher FD will keep you in those higher more powerful rpms
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
misooscar (04-19-2015)
Old 04-17-2015, 11:10 PM   #39
Kostamojen
Try a 225/45/16 tire with those calculations. Thats what im running.
Old 04-18-2015, 12:51 AM   #40
Captain Snooze
Drives: Red Herring
My apologies.
That is not something I have considered given how few choices TireRack offers in that size.
I do not doubt there are savings to be made with that size.
Old 04-18-2015, 08:52 AM   #41
churchx
churchx's Avatar
Drives: 2014 GT86
1/ As I mentioned above fitting 16" wheels is not a guarantee that you are going to end up with a lighter wheel. ...
Guarantee? Certainly not. But on average similar rim and tire models more often then not turns out lighter. Of course there are exceptions to rule (for example available mostly only in 15" size, rarely in 16" max, very strong rally grade rims - mostly heavier then even some heavy 18-19" rims) and of course one can always artificially choose worse/heavier ones of smaller size and compare with ones on lighter scale part of bigger size.
But how about other bits? Like to some preferable handling changes, daily driving comfort, tire cheapness (imho should matter a lot in this car, as going sideways eats through rubber quickly), wider choice for that size? In my eyes pros/cons of 16" outweigh those for 17", except maybe for BBK fitments bit.
Captain Snooze (04-18-2015), xsnapshot (11-15-2015)
Old 04-18-2015, 11:06 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, that speedometer reading .. does it matter much at all, if even on oem 17" rims & oem prius tyres (and at air pressure as per manual) i saw difference of almost 8-10% vs what i saw on gps? As in 65kmh on speedo, 59 @gps. Yes, with different final drive difference will grow, but if there wasn't any precision to begin with, and main thing - real drive-ability/performance will increase no matter what is displayed on speedometer. And vice versa, putting bigger diameter wheels on car to get speedometer report right numbers will decrease performance of it except maybe top speed, almost no one almost never needs.
P.S.
Great pitty that those rally grade rims are mostly available as 14-15" (those that are 16" look somewhat interim between them and average rims, with much longer spokes/smaller center dish, +usually are for 4x100 nut pattern, except maybe this) almost never as 17" and even greater pitty - that they are THAT heavy. Design-looks wise i prefer them to most other designs (#1, #2, #3). They simply look much meaner then thin spoke "normal" lightweight rims. I know that weight is there for strengthening/rigidity at heavy abuse .. but if there were of such design && lightweight (i'm willing to sacrifice extra durability), i'd jump on purchase right away.
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 01:49 PM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 11:18 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 04:11 PM
Where to buy LSD & Final Drive/Gear? GT86_PRAGUE Transmission and Driveline 0 01-09-2015 09:09 AM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 03:51 PM
