go_a_way1
Old 04-06-2015, 07:57 PM   #2731
Subaru_BRZ13
Subaru_BRZ13's Avatar
Drives: Subaru BRZ
Looking to get the Enkei Kojins. Will the staggered set up 18x8.5/9.5 +45 fit on a 1 inch drop without a camber kit and without body modifications?
Thanks.
Subaru_BRZ13 is offline   Reply With Quote
Old 04-07-2015, 10:27 PM   #2732
ButeraFRS
Guest
Posts: n/a
I'm having difficulty following along (all of this seems like a new language to me) so I read it and it's really not registering in my head.
Can someone with the knowledge tell me if these will fit on my car (stock height) what extra things might I have to buy with these particular wheels
http://www.discounttiredirect.com/di...r=2&wd=17&rw=7
With these lugnuts
[ame="http://www.amazon.com/GODSNOW-1-25MM-ALUMINUM-INFINITI-SUZUKI-UNIVERSAL/dp/B00KGLPDNW/ref=sr_1_10?ie=UTF8&qid=1428456525&sr=8-10&keywords=red+m12+x+1.25+lug+nuts"]Amazon.com: AJP GODSNOW M12 X 1.25MM 20PC ALUMINUM WHEEL RIMS CLOSED END LUG NUTS SUBARU INFINITI SUZUKI-UNIVERSAL FIT WITH M12 X 1.25MM THREAD PITCH ONLY (RED): Automotive[/ame]
Old 04-09-2015, 02:25 PM   #2733
MQCDoc
Drives: Black Scion FR-S
Originally Posted by Hi_Im_Gosu View Post
Lowered 1 inch. Will this fit without rubbing?
18x8.5 +30 F / 18x9.5 +35 R
225/40/18 and 255/35/18
almost same question except for offset that is +35 and +38
any idea?
MQCDoc is offline   Reply With Quote
Old 04-10-2015, 08:11 PM   #2734
SkyBRZ
SkyBRZ's Avatar
Drives: 2015 Subaru BRZ
Gram lights 57dr 17x9 +38 5x100
The car is lowered on Tein S-techs
Wondering if these would fit no problem, not sure what tire size to run
SkyBRZ is offline   Reply With Quote
Old 04-12-2015, 11:15 AM   #2735
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I'm currently running 18x8.5 +44 with Michelin Pilot Super Sports 245/35/18 square, I have stock suspension and I am wondering if I can get away with 255/35/18 square with no rubbing?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-13-2015, 07:23 AM   #2736
ShadowTS
Drives: Toyota GT86 SWP
Hi guys,
I want to buy a set of Sparco Assetto Gara, which in Europe are available in 17x7 +38 or 17x7.5 +35. I'll stay with OEM size tires 215/45. I know that to mount the wheels I need the center rings 56.1 - 73.1, and I'll buy a set of aftermarket lug nuts. Do I need anything else, like new studs? Considering the wheels will be 10mm outer with 17x7 +38, or about 20mm outer with 17x7.5 +35, will the car behave differently?
ShadowTS is offline   Reply With Quote
Old 04-13-2015, 11:54 AM   #2737
Cole
Not a troll
Cole's Avatar
205/40/17 on 17x8.25 +25?
Cole is offline   Reply With Quote
Old 04-13-2015, 02:05 PM   #2738
Along these lines, does anyone know if you can change the parameters in the system so you can change the tire size on the stock rims? I'd like to add some sidewall, but don't want to go down in wheel size to do it.
Some cars let you do this (or let the dealer do it) some don't.
Dadhawk is online now   Reply With Quote
Old 04-13-2015, 09:51 PM   #2739
Stevens
Drives: 2014 asphalt FRS
any idea?
I just put on 18/8.5 front
18/9.5 rear
With 225/49/18 +40
255/35/18 +40
Lowered on tein coils. No rubbing no modifications. So you will be good with only 1 inch drop. I can still fit fingers in between my fender and rubber. I'll ip load a few pics tomorrow when the sun is out.
Stevens is offline   Reply With Quote
Old 04-16-2015, 02:47 PM   #2740
brandon.n
Drives: 2014 GTS86
18x9.5 + 40
hey guys im wanting to put the ray grams 18x9.5 + 40 on stock suspension set up but was wondering if they will rub on the struts/ suspension on the inside Fronts! probably gonna run a 245/35 tyre all round if someone could help me out with the fitment that be great!!!!
brandon.n is offline   Reply With Quote
Old 04-20-2015, 09:40 PM   #2741
sydious
Matthew FR-S
I need some advice... I want to purchase a set of Niche Verona M150 wheels. They are 18x8 ET 40 (I assume that's the offset). The tire option is 225 40 18. I'm not neccessarily looking to have the wheels protrude from the wheel wells but would like them to be at least flush. How do you think these will fit. I have 13 FRS and I believe stock height though I bought it used and the car seems awfully low. Thanks
sydious is offline   Reply With Quote
Old 04-26-2015, 06:32 PM   #2742
TB
TB's Avatar
Drives: 2014 Scion FR-S Monogram
I'm lowered on BC coilovers, not positive on the dimensions unfortunately.(Picture for drop reference) I want to buy RPF1's in 18x9.5 +38, tires 245/35/18. I don't want my alignment specs to be super far off but I also don't want to be destroying tires or fenders. Will I need toe arms and LCA's? I can get them through a vendor here in town, just not sure if they are necessary or not.
SASKYSASKATCHEWAN SK86BRZ / TB BUILD THREAD MY BUILD
TB is offline   Reply With Quote
Old 04-27-2015, 07:19 AM   #2743
Jamesbrz
Drives: White BRZ
Hi guys looking at getting enkie Raijin and was wondering if 18 inch by 9.5 inch will fit all round without scrubbing wheel offset is 45 or am I just better off going 8.5 inch wide to stay safe, don't want the hassle of rolling guards and want to stay square, also have coilovers. Also what tryre size best fits both setups. Thanks.
Jamesbrz is offline   Reply With Quote
Old 05-07-2015, 10:43 AM   #2744
marshallferguson1994
Drives: white scion F-RS
Originally Posted by JoeBoxer View Post
+32 would be 6mm poke if +38 is flush, not 6mm sunken.
How would 18x8 +35 look? On sportline springs pretty flush on the front and need about a 5 mm spacer for the back to be flush?
marshallferguson1994 is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
