Old 04-13-2015, 04:21 AM   #183
Trettiosjuan
Drives: GT86
I do the above at first, improvement for sure but only seems to work the first time from flash. Then when the engine is on temp, switch off engine, put on ignition fully but do not start and press the throttle fully and release 20 times (in like 15s) and start engine. Throttle becomes lightning like half the time, not sure why not always, but a great feeling 10min after a reflesh. Even if it was successful , it dumbs down again in the next drives, if I notice it being lazy again to the degree it annoys me, I just pull over (or at the lights when I know I've got the time) and do the throttle thing (just waiting 20s x2 doesn't seem to work then), it usually works but not always. Must be doing something differently or it's related to another parameter (ECT?)?
YMMV
Would really love to hear the definitive 'recipe'
Trettiosjuan is offline   Reply With Quote
Old 04-13-2015, 04:28 AM   #184
SoCalArgento
Drives: 2014 Argento FRS
Btw, the steps I posted above^ are from Steve99's post at the beginning of this thread. Don't want to take credit away from the guy.
SoCalArgento is offline   Reply With Quote
Old 04-13-2015, 07:47 AM   #185
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by JDsThatGuy View Post
Flashed my ECU for the first time on Friday and I'm noticing the dead pedal, should I reflash and follow the suggested steps or what is the best approach to correcting this now that I've been driving for a couple days
Should only take about 30 mins of driving in my experience. Are you sure you didn't hit the throttle while the engine started right after flashing? You typically have to give it a minute to idle or you mess up the throttle response. Otherwise, reflash the tune you want (no need to go stock first) then turn on ignition (no start) hit gas 20 times in quick succession, turn off ignition, turn on again (no start), hit gas 20 times again, then start ignition.
Old 04-13-2015, 07:57 AM   #186
steve99
Drives: FT86
Originally Posted by zypher10 View Post
can someone please tell me how to change launch controll to 4.5krevs?
its in the first post of this thread and in Tune Tweaks link below, you will need to use romraider tune editor
Old 04-13-2015, 08:26 AM   #187
JDsThatGuy
Drives: Subaru BRZ Limited
After flashing I turned the car on for 3 minutes or so and just let it idle, never touched the gas
JDsThatGuy is offline   Reply With Quote
Old 04-14-2015, 03:10 AM   #188
winsometang
Drives: Scion F-RS 2013 Asphalt MT
That happens to me too^
winsometang is offline   Reply With Quote
Old 04-15-2015, 01:41 AM   #189
tracerit
Drives: '13 SSM BRZ Limited 6MT
I thought i was imagining things but now i'm fairly certain my logs are missing some data. I drove around for a good hour to three different locations and did a WOT along the way, but that WOT is not showing up at all. All my files are updated, template is on 7.1.
http://datazap.me/u/tracerit/drive-a...0&data=2-10-13
I left the log recording from when i left home and back. I stopped at three locations, but according to the dip in oil temp right in the middle of the log, it only logged one stop.
tracerit is offline   Reply With Quote
Old 04-15-2015, 02:44 AM   #190
steve99
Drives: FT86
Logs are now limited ro 20 minutes each, after 20 mins they jut stop and you have to name and start another one, total time 240 mins i think.
tracerit (04-15-2015)
Old 04-15-2015, 02:47 AM   #191
tracerit
ah, that's right. so it seems the recording may actually stop after 20 minutes, but there is no indication that it has stopped as the blinking disk icon keeps on blinking.
Old 04-15-2015, 04:13 AM   #192
akahenry
akahenry's Avatar
Drives: '18 STi
Can someone make a video of how to adjust the Cold Start quieter? I've done extensive research on the forums about this already and have an idea what to do, but am afraid that if I screw something up... my car would be [insert something terrible/ "bricked ecu"].
akahenry is offline   Reply With Quote
Old 04-15-2015, 06:43 AM   #193
steve99
Drives: FT86
you wont brick your ecu unless you use incorrect definitions and therefore alter the wrong areas of the ecu.
have a read of links below , tune tweaks , romraider tips you will be fine
Old 04-16-2015, 09:30 PM   #194
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Anybody know the difference between the 2.063 and the 1.59 OTS tunes? Like aggressive timing etc? I'm aware the 2.063 is specifically for NA, which is why i'm running that currently. Just curious if anybody has compared them in romraider
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 04-16-2015, 11:33 PM   #195
steve99
Drives: FT86
1.x or 2.x tunes are same the ie not more agressive , just more updates revions and more refined. Best to run the latest revision ie 2.06x, the 2.06x tunes are also based on the later revision factory roms , just make sure you use the matching definition files if your editing tunes .
The Following 2 Users Say Thank You to steve99 For This Useful Post:
CosmicKnight (04-16-2015), flippy (04-17-2015)
Old 04-17-2015, 01:45 AM   #196
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
Why does the website give me an old version?
i tried the control+refresh didnt work
how do i get it to work?
ive been using an old ass template from last year fml haha
im using google chrome btw
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
