| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2731 |
Drives: Subaru BRZ
Looking to get the Enkei Kojins. Will the staggered set up 18x8.5/9.5 +45 fit on a 1 inch drop without a camber kit and without body modifications?
Thanks. |
#2732 |
Guest
Posts: n/a
I'm having difficulty following along (all of this seems like a new language to me) so I read it and it's really not registering in my head.
Can someone with the knowledge tell me if these will fit on my car (stock height) what extra things might I have to buy with these particular wheels http://www.discounttiredirect.com/di...r=2&wd=17&rw=7 With these lugnuts [ame="http://www.amazon.com/GODSNOW-1-25MM-ALUMINUM-INFINITI-SUZUKI-UNIVERSAL/dp/B00KGLPDNW/ref=sr_1_10?ie=UTF8&qid=1428456525&sr=8-10&keywords=red+m12+x+1.25+lug+nuts"]Amazon.com: AJP GODSNOW M12 X 1.25MM 20PC ALUMINUM WHEEL RIMS CLOSED END LUG NUTS SUBARU INFINITI SUZUKI-UNIVERSAL FIT WITH M12 X 1.25MM THREAD PITCH ONLY (RED): Automotive[/ame] |
#2733 |
Drives: Black Scion FR-S
#2734 |
Drives: 2015 Subaru BRZ
Gram lights 57dr 17x9 +38 5x100
The car is lowered on Tein S-techs Wondering if these would fit no problem, not sure what tire size to run |
#2735 |
Drift King
Drives: '13 Firestorm FR-S 6MT
I'm currently running 18x8.5 +44 with Michelin Pilot Super Sports 245/35/18 square, I have stock suspension and I am wondering if I can get away with 255/35/18 square with no rubbing?
'13 6MT Firestorm FR-S
#2736 |
Drives: Toyota GT86 SWP
Hi guys,
I want to buy a set of Sparco Assetto Gara, which in Europe are available in 17x7 +38 or 17x7.5 +35. I'll stay with OEM size tires 215/45. I know that to mount the wheels I need the center rings 56.1 - 73.1, and I'll buy a set of aftermarket lug nuts. Do I need anything else, like new studs? Considering the wheels will be 10mm outer with 17x7 +38, or about 20mm outer with 17x7.5 +35, will the car behave differently? |
#2737 |
Not a troll
205/40/17 on 17x8.25 +25?
#2738 |
Along these lines, does anyone know if you can change the parameters in the system so you can change the tire size on the stock rims? I'd like to add some sidewall, but don't want to go down in wheel size to do it.
Some cars let you do this (or let the dealer do it) some don't.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#2739 | |
Drives: 2014 asphalt FRS
18/9.5 rear With 225/49/18 +40 255/35/18 +40 Lowered on tein coils. No rubbing no modifications. So you will be good with only 1 inch drop. I can still fit fingers in between my fender and rubber. I'll ip load a few pics tomorrow when the sun is out. |
#2740 |
Drives: 2014 GTS86
18x9.5 + 40
hey guys im wanting to put the ray grams 18x9.5 + 40 on stock suspension set up but was wondering if they will rub on the struts/ suspension on the inside Fronts! probably gonna run a 245/35 tyre all round if someone could help me out with the fitment that be great!!!!
#2741 |
Matthew FR-S
I need some advice... I want to purchase a set of Niche Verona M150 wheels. They are 18x8 ET 40 (I assume that's the offset). The tire option is 225 40 18. I'm not neccessarily looking to have the wheels protrude from the wheel wells but would like them to be at least flush. How do you think these will fit. I have 13 FRS and I believe stock height though I bought it used and the car seems awfully low. Thanks
#2742 |
Drives: 2014 Scion FR-S Monogram
I'm lowered on BC coilovers, not positive on the dimensions unfortunately.(Picture for drop reference) I want to buy RPF1's in 18x9.5 +38, tires 245/35/18. I don't want my alignment specs to be super far off but I also don't want to be destroying tires or fenders. Will I need toe arms and LCA's? I can get them through a vendor here in town, just not sure if they are necessary or not.
#2743 |
Drives: White BRZ
Hi guys looking at getting enkie Raijin and was wondering if 18 inch by 9.5 inch will fit all round without scrubbing wheel offset is 45 or am I just better off going 8.5 inch wide to stay safe, don't want the hassle of rolling guards and want to stay square, also have coilovers. Also what tryre size best fits both setups. Thanks.
#2744 |
Drives: white scion F-RS
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
