Old 03-29-2015, 08:44 PM   #1
DCStorm
DCStorm's Avatar
Drives: 2013 FR-S (RIP), 2017 Toyota 86
For those with Aftermarket Headunits
Hello all. I am probably one of the biggest noobs you'll meet when it comes to a cars electronics. However I'm really interested in upgrading the headunit in my FRS. I was considering the Pioneer AppRadio 3. However this is the first time I've ever done this mod and I'm a little confused on what exactly is needed. My question is, once I buy the radio itself and whatever contents are in the box, is there anything else that's needed? I know with my first car it was a little more complex cuz there was adapters needed for the steering wheel controls and all this yada yada. I'm thinking it should probably be simpler for the FRS but I'm not sure what else, if anything, is needed? Any help here from any of our car tech guru's would be greatly appreciated
Link to headunit:
http://www.pioneerelectronics.com/PU...28SPH-DA210%29
DCStorm is offline   Reply With Quote
Old 03-29-2015, 08:54 PM   #2
MaudDib
Drives: White, Toyota
Not a car tech but when I have replaced a headunit, Crutchfield shipped all the adapters I needed.
On a side note, not sure if you use an Android or Apple but there is some advances coming with both of these incorporating auto functions. Both look pretty nice and add some pretty neat functionality. If you can wait it out a bit, there will be a lot more options out there.
MaudDib is offline   Reply With Quote
Old 03-29-2015, 09:05 PM   #3
DCStorm
DCStorm's Avatar
Ah ok so they just shipped everything else you needed along with your order?
Oh and I'm currently using an iPhone 6 and will probably continue with Apple for the foreseeable future
Old 03-30-2015, 04:01 AM   #4
DCStorm
DCStorm's Avatar
Anyone?
Old 03-30-2015, 06:51 AM   #5
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I do Apple (some say its the other way round). Simply paid an installer and went with a http://www.pioneer.com.au/au/product...0DAB/page.html
Had a reverse camera installed, replaced all the speakers with JL's and had a small 4 channel amp put in. Could not be happier. They made up some brackets for the rear so I could upgrade to 5.25" ones. Wow what a difference it made.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 03-30-2015, 09:45 AM   #6
fitcious
When installing aftermarket head units I would suggest making sure all of your ports still work, such as USB and Aux. I checked with best buy last time and they told me there's not current adapter to make the stock usb work- not sure how true is that. Make sure the Bluetooth works with the in-car mic too.
Also, you are right in that our car is simpler without the steering wheel controls to worry about.
There were a lot of new head units featuring Apple car play and android auto shown at CES this year, I would suggest researching whether you want those feature or not. If you do, I suggest waiting as a lot more aftermarket head units will have those and prices sure will drop a bit.
fitcious is offline   Reply With Quote
Old 03-30-2015, 10:39 AM   #7
MaudDib
Crutchfield sent everything I needed but this was a few years ago and it could have changed. As noted above, things like the USB port and aux port might not work with the headunit.
Installation should be pretty easy though.
Old 03-30-2015, 11:02 AM   #8
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
yes crutchfield will send you everything you will need
wireharness, dash kit, etc etc
when i replaced my headunit i was to lazy to use the factory USB/AUX cable... only real reason is i never used them to begin with
if you dont trust yourself doing the job, its not expensive to get it done,
the shop i go to charges $75 an hour to do the job, 90% of the time, it takes us less than an hour to do it
Old 03-30-2015, 11:49 AM   #9
Porcupint
Drives: 13 GBS BRZ
There are DIY's on how to get the USB and AUX working with the stock ports.
Bluetooth will have to use the mic that usually comes with the head unit.
Porcupint is offline   Reply With Quote
Speed camera database available for stock/aftermarket headunits +DIY DoomsdayJesus Electronics | Audio | NAV | Infotainment 38 09-06-2016 10:27 PM
Toyota standard size (200mm wide) headunits for FR-S/GT86/BRZ Efferalgan Electronics | Audio | NAV | Infotainment 50 08-02-2016 07:47 PM
Besides Torque, what apps do you guys have on your Android headunits? Ruckus Electronics | Audio | NAV | Infotainment 7 09-30-2015 01:33 AM
DIY: gaming setups on OEM headunits lbroskee DIY (Do-It-Yourself) Guides 46 12-10-2014 12:11 AM
Any headunits the same dimesions as stock? Hanakuso Electronics | Audio | NAV | Infotainment 25 07-20-2013 10:03 AM
