Old 12-14-2014, 08:56 AM   #281
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Took mine to the dealer for some peace of mind. They pressure test and got the coolant levels to the correct specs. After that I've stopped looking at it and it has never need out of wack anymore. When cold is halfway between full and low and when hot is full.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 12-14-2014, 09:13 AM   #282
kodyo
Drives: Scion FR-S
Originally Posted by 2016 Camaro SS View Post
My coolant disappearing issue went away when I changed the hoses to silicon ones and the clamps to t-bolt style. I changed nothing with the overflow tank and it's still at the same full mark when warm.
How difficult/expensive was it to do this? Picture or description of exactly what was replaced?
kodyo is offline   Reply With Quote
Old 12-14-2014, 11:28 AM   #283
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I did the Mishimoto radiator, Mishimoto hoses, and the Mishimoto t-bolt clamps.
Roughly around $350 but you can do just the hoses and clamps for a lititle over $100 and keep the stock radiator.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
kodyo (12-14-2014)
Old 12-14-2014, 01:14 PM   #284
kodyo
Drives: Scion FR-S
Alright, so I added a filter/breather to the tank today. We'll see if this combined with the grommet will keep the fluid level in check and debris out of the tank.
Went to the local auto parts place and they didn't have a small breather valve, so I made my own out of a bike adjusting barrel, some foam, and some shrink wrap (electronics, not kitchen).
Here's the parts:
Shrink wrap keeps the foam from coming out. I left some extra shrink wrap on the tip to make it harder for things to fall into the breather (put's the entrance more under the front lip of the car).
Here's it installed:
To keep the nut from falling into the tank while attaching it, I attached the nut to a piece of tape and positioned it over the hole while I threaded on the 'filter'.
Hope y'all like my ghetto mod.
The Following User Says Thank You to kodyo For This Useful Post:
civicdrivr (02-20-2015)
Old 12-14-2014, 05:26 PM   #285
notout86
Drives: GTS 86 auto
Here's the parts:
Whoa! Hardly ghetto. MINE is ghetto as I used genuine BluTac (not the Chinese knock-off which goes hard) to secure my filter and reduce to size of the o.e. hole. I have also surrounded the bottle with thick Al reflective foil to reduce radiant heat from the engine and radiator. Allow an air gap between bottle and foil and space at the bottom for cooler air to flow up when the engine is off. Also arrange so that hot air from the fans is directed away from the bottle. An inspection slot allows you to check coolant..levels. It looks terrible but hey, if it is good enough for space programs...... NO photos from me as they would make you throw up.
Here's another similar tip ...... shield the battery too but keep the foil away from the terminals.
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
kodyo (12-14-2014)
Old 12-14-2014, 11:46 PM   #286
Ozzman
Drives: old
If you really want to try sealing it, just replace the reservoir with a camelback bladder. Fill the bladder with the same volume of fluid that should be in the tank, and burp the air out of the bladder before closing the cap.
Ozzman is offline   Reply With Quote
The Following User Says Thank You to Ozzman For This Useful Post:
notout86 (12-15-2014)
Old 02-19-2015, 04:30 PM   #287
AznBRZer
Drives: 16 CBS WRX Limited
Another update:
Last time it was topped off was on 11/24/13. Bought a jug of Super Coolant a couple days ago since the overflow tank was empty and gave it about a liter to get to full. I figured spending $20 was well worth not having to deal with waiting at a dealership even though it should've been topped off at the last oil change. Sometimes, it's just easier and save a shitload of time to do it yourself.
AznBRZer is offline   Reply With Quote
Old 02-19-2015, 05:03 PM   #288
tjf
Drives: Toyota 86
After 18 months of ownership I'm having the same issue with coolant disappearing.
Dealership has had to top it up on two occasions, both after long trips of 300 + km.
The following link is interesting: http://www.ft86club.com/forums/showthread.php?t=77916
tjf is offline   Reply With Quote
Old 02-19-2015, 05:13 PM   #289
notout86
Drives: GTS 86 auto
Originally Posted by AznBRZer View Post
Another update:
Exactly. Most service items can be done yourself and you know how thoroughly they have been done (or at all). Then for things you do not or cannot do yourself, or if there are warrantee issues,have the dealer do those. If no w'tee involvement, have a trusted mechanic do those and sign off. Ensure they can plug into the ECU to check for all fault codes.
Forget the "capped price service" idea and save money.
Old 02-19-2015, 06:14 PM   #290
notout86
Drives: GTS 86 auto
If your car is seeming to lose coolant over the first few months I suspect it may be due to 2 things
1)air pockets from failure to fill correctly at assembly, which will eventually be expelled (remove the cap & top up the radiator itself)
2)dissolved air in the coolant which will form pockets as it gradually come out of solution (as the coolant becomes hot) and be expelled (remove the cap & top up the radiator itself).
The dealer might give you some coolant to keep for this.
Once you no longer find a gap in the radiator itself you should only top up the bottle.
If it doesn't settle down after a few months or if very severe, then more sinister causes need checking.
Old 03-23-2015, 01:22 AM   #291
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Hmmmmm.....I noticed the coolant level is on low. My car has been sitting for the last 7 hrs. Is this somewhat normal since I checked it when car is cold? Do I need to use the Toyota Genuine 50/50 pre-mixed super long life coolant Blue? I'm assuming if I have to then I need to buy it from the dealer. I've never had a brand new car that's only 5 months old have coolant disappear in a short amount of time. I only have a little over 2000 miles.
I'd appreciate any advice. Thanks in advance.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 03-23-2015, 02:05 AM   #292
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
No, you checked it at the right time. Coolant level should be checked when the engine is cold. The level should be between the LOW and FULL level. When I fill to the middle of the two lines and then drive for a while, the reservoir level rises to the FULL mark (the level in the reservoir doesn't really matter as long as it doesn't get too far below the "LOW" line - it's the level in your radiator that counts)
General advice I hear regarding coolant : don't mix types.
That being said, the Subaru and Toyota coolant is the same for our car. When I bought it at my dealer (my reservoir was basically empty, needed some right away), it was $38 bucks, Amazon was $4 dollars cheaper, but now Amazon has it more expensive...
[ame="http://www.amazon.com/Genuine-Toyota-Fluid-00272-GTBC1-Coolant/dp/B00AKYP114/ref=sr_1_1?s=automotive&ie=UTF8&qid=1427089837&sr= 1-1&keywords=toyota+00272gtbc1"]Amazon.com: Genuine Toyota Fluid 00272-GTBC1 Blue Super Long Life Coolant - 1 Gallon: Automotive[/ame]
Price history:
http://camelcamelcamel.com/Genuine-T...uct/B00AKYP114
Toyota Part # 00272-GTBC1
Looks like Subaru's pricing is better than Toyota's.
Subaru Part # SOA868V9270
[ame="http://www.amazon.com/Genuine-Subaru-SOA868V9270-Super-Coolant/dp/B007NLOZAU/ref=pd_sbs_auto_4?ie=UTF8&refRID=0JM06Z9H90JNJ4YKR TSP"]Amazon.com: Genuine Subaru SOA868V9270 Super Coolant: Automotive[/ame]
Amazon Price history:
http://camelcamelcamel.com/Genuine-S...uct/B007NLOZAU
Subaru official pricing:
http://parts.subaru.com/p/Super-Cool...A868V9270.html
aegisdrgn is offline   Reply With Quote
The Following 2 Users Say Thank You to aegisdrgn For This Useful Post:
86geek (03-23-2015), civicdrivr (03-23-2015)
Old 03-23-2015, 02:13 AM   #293
86geek
86geek's Avatar
Price history:
Thanks for the advice and providing the links. I appreciate it! I'll check out the dealer tomorrow and see if they can just top it off for me. Or if I'm forced to buy a gallon from them I have no choice. Only one Toyota dealership here in Honolulu and they own Subaru as well.
Old 03-23-2015, 10:20 AM   #294
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Check the Subaru dealer. I'm always amazed by how much cheaper they are compared to the Toyota dealers.
For example: coolant from the Toyota dealer is $34/gallon. From Subaru, it's $20/gallon.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
86geek (03-23-2015)
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 07:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-13-2013 11:33 PM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 08:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
