go_a_way1
Old 03-18-2015, 12:27 PM   #2717
k1s3k1
Drives: Toyota 86
Need some help.
Car is lowered with eibach pro kit.
I want to put 18x8.5 +48 wheels square. Will there be any rubbing front and rear?
What tyre sizes are recommended for this setup?
Can someone advise. Thanks!
k1s3k1 is offline   Reply With Quote
Old 03-18-2015, 04:38 PM   #2718
Hi_Im_Gosu
Hey All,
I've recently purchased the eibach pro kit, and I'm trying to get a staggered setup going. Naturally, I'd want a setup that doesn't involve rubbing.
My Two options are:
18x8 +35/ 18x9 +38 (F: 225/40/18 R: 255/35/18)
18x8.5 +35 / 18x9.5 +38
Here are my noob questions:
1) I'm looking at ESM 004's or 007's (which is where the wheel sizes come from), OR Enkei Raijin's. Does anyone know if the TPMS can be transferred from the stock to these during installation?
2) Recommended tire sizes for the 8.5/9.5 setup?
3) Will there be any rubbing with the 8.5/9.5 setup?
You guys are awesome, thanks in advance.
Last edited by Hi_Im_Gosu; 03-18-2015 at 04:44 PM. Reason: added another question >.<
Hi_Im_Gosu is offline   Reply With Quote
Old 03-18-2015, 07:45 PM   #2719
thien
Drives: Scion FRS
Will 18x9.5et+35 wrapped with 245/35/18 square rub if I'm lowered on h&r sport springs? I'm new to this but everyone seems to be running coils. Are springs going to clear or will the wheels hit my suspension? The spring should lower 1" in front and 1.2" rear. What are the benefits of running coils? Thanks in advance and sorry if these are dumb questions. Lol
thien is offline   Reply With Quote
Old 03-25-2015, 03:22 AM   #2720
Belzak
Drives: White 2015
Originally Posted by jshadeck View Post
18 9.5 et38 will not hit suspension, i ran those for a year both stock and lowered on eibach springs w zero issues. But they poke, theres no way to fit a 9.5 wide front wheel w out poke unless you get coilovers. 17 9 et35 would also fit, and poke less no spacer needed. Where are you seeing info that these sizes will hit suspension?
Attachment 104563
Top pics are 9.5 et38 bottom pics are 8.5 et44
Those were just based off some super rough calculations I made with what I had. Most of the threads on this forum started by people who have that size/setup are already on coilovers so I wasn't sure if they'd work without them. Based on what you're saying though, I'm pretty much decided on 17x9 though. Less poke, no spacer, cheaper tires. Also, your attachment doesn't seem to open for me.
Belzak is offline   Reply With Quote
Old 03-25-2015, 10:40 PM   #2721
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Originally Posted by Eseigs View Post
Sitting on TRD springs (1.125 inches lowered) and stock struts:
Leaning towards 18x9 +40 (with 245/35/18) squared right now and was wondering if I'd have any problems with rubbing or hitting the struts (especially in the front).
In the same boat as you ordered 18x9
but either between
245/35 or 225/40..
I want to keep the stock feel of being pretty loose in the rear so I dont lose the fun of the car, I'm guessing that would be the 225/40 right?
Also for everyone this is a great site to check tire size http://www.frsproject.com/tire_size.php
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 03-27-2015, 06:27 AM   #2722
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
hey guys
new to this whole fitment thing. I'm running stock struts with RCE yellows springs. I'm wondering if a square setup 18x9.5 +40 with 255/35/r18 would fit and clear without rubbing? if not would spacers be a good solution? or camber plates? or should I just go straight to coils
andrew5826 is offline   Reply With Quote
Old 03-27-2015, 05:40 PM   #2723
TannerW60
Drives: 2015 Scion FRS Release series 1.0
ive searched every thread on the klutch sl14 wheels and still cant seem to find a straight answer. I currently have the trd springs so I am only lowered about 1 inch and am wanting to go with a 18x8.5+38 235/40 in the front and a 18x9.5+42 255/35 in the rear. Im just wanting to know if this setup will work without any rubbing/fitment issues with my trd springs?. i was thinking about getting the eibach sportline lowering springs to bring it down another half inch if need be. a response would be greatly appreciated. thanks
TannerW60 is offline   Reply With Quote
Old 03-27-2015, 07:42 PM   #2724
jxl00
Drives: scion frs 2014
just a question,
anyone can recommend some cheap lugnuts for 20-30 dolllars?
I just bought a set of 12x1.25 cone shaped lugnuts and they were too big!!!
also will 12x1.5 fit??
jxl00 is offline   Reply With Quote
Old 04-01-2015, 12:30 PM   #2725
brzee_vic
brzee_vic's Avatar
Drives: frown slasher
I'm currently researching wheels. I have a stock suspension for now but i would like to run springs later on to have an approximate 1" drop in the near future. I was looking at 17" wheels and came across the VORDOVEN Forme 9 Wheels @ 17 x 9 +35. I understand that 9" might be too much for DD. I do not intend running the car at the track just yet.
Thank you for your input
Also looking into Avid.1 AV-20 17x8 +35.
Last edited by brzee_vic; 04-01-2015 at 01:00 PM. Reason: Added another wheel option
brzee_vic is offline   Reply With Quote
Old 04-01-2015, 03:11 PM   #2726
VakaGT
VakaGT's Avatar
Drives: None
Would 18x8.5 +21 fit
On
225/40/18
I'm using a 8.75 on 225 right now so don't worry about stretch
but will it fit and clear breaks. No rubbing?
18x8.5 +21
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 04-01-2015, 06:11 PM   #2727
torranosaurus
Drives: 2014 FR-S
I am running stock setup and was wondering if a 1 inch spacer out back would make the ride better? Seems like the front has a tendency to wander. Been that way since new.
torranosaurus is offline   Reply With Quote
Old 04-01-2015, 08:40 PM   #2728
GA_Dave
Drives: 2014 Dark Gray Metallic BRZ Limited
Hey guys
I'm looking at ordering a set of Avid.1 AV-20 18x9.5 +38 and Dunlop Direzza ZII's 265/35's. I'm currently lowered about 2.5" in front and 2" in the back on BC Coilovers. If I raise the car about an inch will I be abe to avoid the fender rub, or will I have to go higher?
Thanks!
GA_Dave is offline   Reply With Quote
Old 04-02-2015, 11:58 PM   #2729
Hi_Im_Gosu
Lowered 1 inch. Will this fit without rubbing?
18x8.5 +30 F / 18x9.5 +35 R
225/40/18 and 255/35/18
Old 04-05-2015, 09:27 PM   #2730
CircaBRZ
CircaBRZ's Avatar
Drives: 2013 BR-Z Limited
A lot of people posting, but I figured why not try and post.
New to the BRZ, it's stock at the moment. But looking to get a new set of:
Volk TE37SL black Edition 18x8.5 in front and 18x9 in the back.
I definitely intend on getting coilovers with a 1" drop (which seems to be the normal everyone does)
I know the offset differences for 1" vs stock. It seems that I'll need to run +42 in front and +38 in rear. Will this clear all and be flush?
If not, what additions do I need (spacers, tire size) etc... I'd hate to purchase without knowing if it will fit, Thanks.
CircaBRZ is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
