Old 03-16-2015, 07:47 PM   #43
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Eneos 0w-20.
KalbiCool88 is offline   Reply With Quote
Old 03-16-2015, 09:14 PM   #44
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
AMSOil 0w-20 here. AMSOil what my brother uses in his Integra Type-R, plus he is an AMSOil dealer now so I can buy oil from him.
Keep calm and drive safe
Last edited by housecat; 03-16-2015 at 09:16 PM. Reason: forgot to mention what viscosity
housecat is offline   Reply With Quote
Old 03-16-2015, 10:27 PM   #45
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I've been running Mobil1 0w30 with E85 for a good while. I alternate between RP 0w20 occasionally. 0w30 seems to hold up much better.
TruRace is offline   Reply With Quote
Old 03-16-2015, 10:55 PM   #46
wheelhaus
wheelhaus's Avatar
"Hold up better" how so? Do you notice less consumption or have you sent some out for analysis? Just curious if its perception or if you're seeing actual measurable differences.
Old 03-17-2015, 11:38 AM   #47
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Should i go with the OEM Subaru Oil with OEM Subaru oil filter or Go with the Castrol Edge Full synthetic with K&N Oil filter?
I used Castrol edge full synthetic with k&N oil filter in my celica, so im thinkin on going that same route with the BRZ.
Jfheisenberg is offline   Reply With Quote
Old 03-17-2015, 12:20 PM   #48
D_Thissen
D_Thissen's Avatar
Originally Posted by RickyBobby View Post
Does it ever get down to -40C in Thunder Bay, Ontario?
Not quiet -40C. I've seen -30's a few times this winter before the wind though.
Old 03-17-2015, 01:38 PM   #49
TruRace
TruRace's Avatar
What motor oil are you running in your car?
Mainly just perception. Not sure if these motors a prone to burning oil but it seems like I burn a noticeable about when I run 0w20 on e85. Also the 0w20 seems to get broken down much quicker. I change oil every 3k and 0w20 is like water. 0w30 seems to hold its viscosity a little better. And for the record I am no expert on the subject.
Old 03-17-2015, 03:26 PM   #50
wheelhaus
wheelhaus's Avatar
Personally I think you'd be fine either way, but I remember looking into K&N filters and decided to go with Mobil1 filter (# M1-104 for the 86) as it filtered to finer particles. Not sure how it stacks up against OEM or other brands but its worth looking into what your local auto parts stores have and doing some quick research.
Ah OK, yeah its hard to tell what's actually working better, but 5w30 would be noticably thicker at any temp. I don't run E85 but I have heard concerns over the alcohols causing dilution in the oil. If that is the case, a 5w30 makes more sense, unless the breakdown affects it chemically (not just dillution). I don't use e85 and haven't researched it much, but it might be a good idea to send a sample to blackstone just for their insight and to know what's actually going on in your engine. I want to as well, but I always seem to conveniently forget..
Old 03-17-2015, 04:19 PM   #51
2013GTRNate
2013GTRNate's Avatar
I run E85 and use 0w20. I have had zero issues concerning oil breakdown; Blackstone confirmed. I too change my oil every 3k miles. I just put a Turbo kit on my BRZ and still am running 0w20. I added a Kite Oil Cooler and will pay close attention to the Blackstone results of my first oil change after going turbo.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 03-17-2015, 05:14 PM   #52
TruRace
TruRace's Avatar
That's good to hear. I did see an oil analysis with 0w20 (amsoil I think) a member posted on here and there was nothing alarming on there. What brand have you been using? And do you track your car at all?
The Following User Says Thank You to TruRace For This Useful Post:
2013GTRNate (03-17-2015)
Old 03-17-2015, 05:34 PM   #53
2013GTRNate
I was using the high quality OEM stuff but recently switched to Mobile1 synthetic. I use 0w40 Mobile1 in my GT-R so I figured why not use 0w20 Mobile1 in my BRZ. Thus far that oil is just as good as the dealer oil. I have used Mobile1 forever in all of my cars.
I do track my car. That is why I had to get the Oil Cooler. Time will tell whether a radiator upgrade is necessary.
The Following User Says Thank You to 2013GTRNate For This Useful Post:
TruRace (03-17-2015)
Old 03-17-2015, 05:42 PM   #54
YUZU(c2z)0097
YUZU(c2z)0097's Avatar
Drives: 2015 Scion FR-S RS 1.0
TRD knows best
TRD when finances permit. Motul and Toyota worst case. That's what I suggest if you dog your motor all day like recommended in the frs dealership pamphlet.
YUZU(c2z)0097 is offline   Reply With Quote
Old 03-17-2015, 05:47 PM   #55
YUZU(c2z)0097
Old 03-20-2015, 06:41 PM   #56
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
0w20 eneos for winter (stored this year) and motul 5w30 summer/track use. Might be just me but I feel it runs much smoother on 5w30 and when I was driving last week I swore I heard like a rattle/knocking sound or something (still on the 0w20 eneos). Might just be hearing things most likely lol I'll see what happens when it warms up a bit and I change the oil.
Sweet48 is offline   Reply With Quote
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 08:18 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 10:56 PM
Something running while car is off. grostoine Issues | Warranty | Recalls / TSB 5 04-11-2014 09:56 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 08:35 PM
